Like Tree9Likes
Old 02-23-2012, 09:41 PM
  #29881
Kevin_M's Avatar
Hobbywing ESCs? Anyone using one of these? How will it perform with the Tekin pro 4. Is there a difference between the sct pro and the one for 1/8 cars?
Kevin_M is offline
Old 02-23-2012, 10:21 PM
  #29882
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Originally Posted by htrd03
I am ordering the HA pivot balls, should I replace the rod end also or will the slop issue be fixed with just replacing the pivot balls with the HA ones?
If your spending 20 or so on ha balls then you may as well spend another 7 for rod ends. Keep it tight bro.!!
BDRMBULLY is offline
Old 02-23-2012, 10:25 PM
  #29883
Thanks bro. Any other tips I can get on this thing would be great
htrd03 is offline
Old 02-23-2012, 10:48 PM
  #29884
cavg's Avatar
I run a Tenshock SC411 4600 kv which is also a 4-pole motor like the pro4. This together with a sct pro and they run great together.
Difference is that the 1/8 esc is 2-6s capable, but not recommended with 2s, whereas the sct pro is 2-4s capable and recommended for 2s application. They do however share firmware.
cavg is offline
Old 02-23-2012, 10:52 PM
  #29885
cavg's Avatar
Is it ok to run a rear ring gear that has gotten a bit sharp from wear, or is it time to replace it?
cavg is offline
Old 02-23-2012, 11:20 PM
  #29886
.AJ.'s Avatar
Where did you read or here that its not recommended to run 2s on a Xerun 150a??? mine works perfectly on 2s
.AJ. is offline
Old 02-23-2012, 11:24 PM
  #29887
cavg's Avatar
Stated by Hobbywing.
http://www.hobbywing.com/product_show.asp?id=238
Although that could very well be a marketing move in order to "create" a need for the 2s recommended systems
cavg is offline
Old 02-23-2012, 11:35 PM
  #29888
.AJ.'s Avatar
Think you are right, i cant remember them stating that when i got my Xerun, but that was before the SCT Pro came out lol
.AJ. is offline
Old 02-23-2012, 11:38 PM
  #29889
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
hobbywing has a 4 pole motor? 56mm long. 4000kv. interesting...
RC*PHREAK is offline
Old 02-23-2012, 11:39 PM
  #29890
Suteki's Avatar
Does anyone have any recommendations on socks for the shock absorbers? The pillow socks that cover the shaft on the standard shocks keep slipping off, so was looking for something that covers the entire spring.
I know outerwears do them but does anyone else?
Suteki is offline
Old 02-23-2012, 11:40 PM
  #29891
.AJ.'s Avatar
spec of mine off ebay sale
Specification
Model: XERUN-150A
Dimension: 58mm(L) x 46.5mm(W) x 35mm(H)
Cont. / Burst Current: 150A / 950A
Resistance: 0.0002 ohm
Suitable Motor: Sensored and sensorless brushless motors
=>4.5T, KV<=3000 (Works with 4S Li-Po), =>6T, KV<=2400 (Works with 6S Li-Po)
Battery: 6-18 cells NiMH or 2-6 cells Li-Po
BEC Output: 5.75V/3A Switch mode built-in BEC
Cooling Fan Working Voltage: 5V, max. 8V (The fan gets the power supply from the built-in BEC)
Suitable Model: 1/5, 1/8 on-road, off-road, monster, Super powerful applications
.AJ. is offline
Old 02-23-2012, 11:50 PM
  #29892
.AJ.'s Avatar
Ive got some on mine, but i got them off a supplier in the UK
.AJ. is offline
Old 02-24-2012, 12:01 AM
  #29893
Suteki's Avatar
Doesn't seem to matter where they come from because I doubt I will be able to get them in Australia. What brand are they? Online?
Also what socks actually fit these shocks by means of comparable models?
Suteki is offline
Old 02-24-2012, 12:58 AM
  #29894
.AJ.'s Avatar
They are ment for a Slash but fit perfect
http://www.ebay.co.uk/itm/Traxxas-Sl...ht_3061wt_1157
.AJ. is offline
Old 02-24-2012, 01:55 AM
  #29895
Suteki's Avatar
Just checked them out but they didn't list an international shipping price.
Badhorsie had socks from $10, then it was $30 postage
Thinking maybe the rc-skins rubber socks but I am curious as to whether rubber will bind or eventually stretch.
Suteki is offline
