Like Tree9Likes
Old 02-22-2012, 11:20 PM
  #29836
cavg's Avatar
Originally Posted by mcgrath280 View Post
2 questions:
1. Is the airtronics mt-4 a good radio? If not what should I be looking at? I've been using a spectrum Dx3s I got with rtr 8ight couple years ago but ready to upgrade.
2. I've seen a lot on here about emulsion shocks. My question about this style is can they handle big 1/8 scale jumps? Or better suited for smaller jumps?
1. Yes. I recently purchased one and i'm very happy with it. I went from a Fly-sky gt3b, and the difference is huge. Lap times have improved considerably!
2. Depends on what oil and piston you put in them. Can't see why they should have any problems with larger jumps.
cavg is offline
Old 02-22-2012, 11:31 PM
  #29837
Aoh
Trader Rating: 16 (94%+)
Originally Posted by SoCal Jared View Post
4. Are variations of the Lane setup still the choice for indoor high bite clay like WCRC?
run ryan dunford's setup, u will get all the steering u will ever need. WCRC is also my home track, i tried the aaron lane setup, and ryan's setup is what i prefer.
Aoh is offline
Old 02-22-2012, 11:57 PM
  #29838
cwilkinson's Avatar
Originally Posted by Jethro32 View Post
How do you harden the outdrives?
Heat them up red hot with a torch not gonna accomplish this with a bic lighter
Heat red hot dip in motor oil
cool off
heat red hot cool in water
heat them up red hot one more time cool them in water
when you're done grab the torch and 2 butter knifes and heat the butter knifes up and.. ohh wrong forum crap
cwilkinson is offline
Old 02-23-2012, 04:55 AM
  #29839
One modifications to the instructions above. Make sure it is used Motor oil, carbon in the oil is what makes it hard. Besides that it is correct.
Jammin_Xtream49 is offline
Old 02-23-2012, 05:26 AM
  #29840
BradS's Avatar
How is a different TX improving your lap times?
BradS is offline
Old 02-23-2012, 05:31 AM
  #29841
cavg's Avatar
Precision steering and faster throttle/brake effect.
Especially after hitting full throttle and then instantly maxing the brakes, there was a slight delay that caused all sorts of problems. I suspect that that was some compatibility issue with the Fly-sky rx and Hobbywing esc.
cavg is offline
Old 02-23-2012, 05:40 AM
  #29842
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
I can vouch for that too. Went from a futaba 3pm to a MT4 and got faster. Faster reacting radio = faster lap times. For me at least.
I believe the same goes for your steering servo. I used to believe the futaba 3305 was more than sufficient for steering on a sc truck. I am now using a futaba bls351. I got faster lap times when upgrading the servo as well. The faster the truck reacts to your input, the more you are connected with the vehicle.
alvinsmith75 is offline
Old 02-23-2012, 06:35 AM
  #29843
Trader Rating: 15 (100%+)
cool off
Thanks Ill have to give this a try. Dont think I want to know what the butter knives are for though...
Jethro32 is offline
Old 02-23-2012, 07:47 AM
  #29844
Well, for those of you that dont want to try burning your garage down, they HD lightened outdrives came in stock and we filled the BO's to the shops so most of the local shops that had some on BO should have them now.
hacker07 is offline
Old 02-23-2012, 07:54 AM
  #29845
Trader Rating: 20 (100%+)
There is also oil that is made specifically for hardening metals. A local machine shop gave me enough to do my out drives with.
MX304 is offline
Old 02-23-2012, 08:23 AM
  #29846
goehm's Avatar
Trader Rating: 45 (100%+)
cool off
So you think a MAP torch will work? I have my old outdrives laying around - I think I'll give that a shot.
goehm is offline
Old 02-23-2012, 09:00 AM
  #29847
.AJ.'s Avatar
Yea easily, i used my plumbing gas torch to straighten a bent SHD savage dog bone and retemper it without any problems
.AJ. is offline
Old 02-23-2012, 10:11 AM
  #29848
Aoh
easily, heat it until its cherry red then dunk!
Aoh is offline
Old 02-23-2012, 10:12 AM
  #29849
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Default Help
Looking for a good indoor set up to try out any help would be greatly appreciated.
Thx,
Kevin
Slimsh8t is offline
Old 02-23-2012, 11:03 AM
  #29850
man those out drives didnt last long at nitrohouse.com lol
black05stxjt is offline
