Like Tree9Likes
Old 02-22-2012, 07:37 PM
  #29821
Trader Rating: 35 (100%+)
For those that were waiting for the AKA Cyclone wheels for the SCTE, I just got 2 sets in the mail (8 wheels). After a close inspection of the wheels, I'll probably be sticking the the DE wheels. The AKA wheels looks nice and seem like good plastic, but they seem to have approximately 1mm more backspacing than the DE wheels. That is, the truck will be about 2mm narrower with the AKA wheels. Now what I don't know is where the stock wheels fit into the mix. It could be the AKA wheels are fine and the DE wheels actually make the truck wider. Regardless, it doesn't seem like narrower would be better. The other thing I don't like about the AKA wheels is that they fit very loose on my wheel hexes. Where I have to actually press the DE wheels onto the hex when they are new, the AKA wheels slid right over the hex and kind of flop around until you tighten them down.
kazuaki is offline
Old 02-22-2012, 07:50 PM
  #29822
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Originally Posted by Dano628
RPPHOBBY.com has HD lightened outdrives in stock . I just picked up fr ,rr,and center . They also have tuned flex chassis's for 84.99 .
Now out of stock on f/r outdrives
wrightcs77 is offline
Old 02-22-2012, 07:51 PM
  #29823
Trader Rating: 23 (100%+)
Thx for the heads up w the aka's!!! Ill stick w/ the de's ive been using. Considering tryin the hazzard wheels for a bit wider stance though once we go outdoors
nitro0619 is offline
Old 02-22-2012, 07:55 PM
  #29824
symmetricon's Avatar
Trader Rating: 27 (100%+)
Thanks for the heads up.... and they have great prices to boot.
symmetricon is offline
Old 02-22-2012, 07:57 PM
  #29825
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Kyosho rims also work on the rear but give a wider stance, tried them on carpet with long schumacher spikes
BDRMBULLY is offline
Old 02-22-2012, 08:01 PM
  #29826
scracer68's Avatar
I just ordered center, front and rear from nitrohouse.com.
scracer68 is offline
Old 02-22-2012, 08:08 PM
  #29827
wrightcs77's Avatar
I did just find them in stock at Nitrohouse and ordered a full set f/c/r and the light weight steering tubes from Jammin.
Old 02-22-2012, 08:09 PM
  #29828
wrightcs77's Avatar
Too funny. I hope they have enough in stock for both of us
Old 02-22-2012, 08:43 PM
  #29829
2 questions:
1. Is the airtronics mt-4 a good radio? If not what should I be looking at? I've been using a spectrum Dx3s I got with rtr 8ight couple years ago but ready to upgrade.
2. I've seen a lot on here about emulsion shocks. My question about this style is can they handle big 1/8 scale jumps? Or better suited for smaller jumps?
mcgrath280 is offline
Old 02-22-2012, 09:46 PM
  #29830
Aoh
Trader Rating: 16 (94%+)
Originally Posted by rcus3r
I just hardened my own; got tired of waiting. Pretty simple painless process. Only did it on the center outdrives so far. Put about 5 pacs through them. So far so good. Time will tell. Once I am ready to rebuilt rear and front diffs, I will do it to them as well.
i hardened all my outdrives myself too. i have ~25 packs through the truck now and show little to no wear at all.
Aoh is offline
Old 02-22-2012, 09:50 PM
  #29831
Trader Rating: 15 (100%+)
How do you harden the outdrives?
Jethro32 is offline
Old 02-22-2012, 11:20 PM
  #29832
cavg's Avatar
Originally Posted by mcgrath280
2 questions:
1. Yes. I recently purchased one and i'm very happy with it. I went from a Fly-sky gt3b, and the difference is huge. Lap times have improved considerably!
2. Depends on what oil and piston you put in them. Can't see why they should have any problems with larger jumps.
cavg is offline
Old 02-22-2012, 11:31 PM
  #29833
Aoh
Originally Posted by SoCal Jared
4. Are variations of the Lane setup still the choice for indoor high bite clay like WCRC?
run ryan dunford's setup, u will get all the steering u will ever need. WCRC is also my home track, i tried the aaron lane setup, and ryan's setup is what i prefer.
Aoh is offline
Old 02-22-2012, 11:57 PM
  #29834
cwilkinson's Avatar
Heat them up red hot with a torch not gonna accomplish this with a bic lighter
Heat red hot dip in motor oil
cool off
heat red hot cool in water
heat them up red hot one more time cool them in water
when you're done grab the torch and 2 butter knifes and heat the butter knifes up and.. ohh wrong forum crap
cwilkinson is offline
Old 02-23-2012, 04:55 AM
  #29835
One modifications to the instructions above. Make sure it is used Motor oil, carbon in the oil is what makes it hard. Besides that it is correct.
Jammin_Xtream49 is offline
