Like Tree9Likes
Old 02-22-2012, 02:02 PM
  #29806
gawith0413's Avatar
Trader Rating: 86 (100%+)
Hey Scoobie,
You work @ amain right? When are you guys going to list the new TLR losi parts for preorder?
gawith0413 is offline
Old 02-22-2012, 02:08 PM
  #29807
tc5 man's Avatar
Originally Posted by AgroAMG
Yea thats what it looks like just curious of what kind of grease it is im looking to go to Pep Boys and get it.
tc5 man is offline
Old 02-22-2012, 02:10 PM
  #29808
Casper's Avatar
Trader Rating: 34 (100%+)
I see that Losi finally has a pic up. So yeah looks like you'll want both.
I am pretty sure the stock piece is alum as well. The huge benefit to this one is the tolerances for the bearing fit are much better and this takes some of the slop out of the steering system!
Casper is offline
Old 02-22-2012, 02:14 PM
  #29809
Originally Posted by tc5 man
Anybody know ?
The grease that is used on the diffs is sepcific to this car and has been posted on here many times and is also listen under the parts for the SCTE on the Losi website.
http://www.losi.com/Products/Feature...rodId=LOSB3590
hacker07 is offline
Old 02-22-2012, 02:17 PM
  #29810
tc5 man's Avatar
Ok thanks i guess i should go with a grease thats made for r/c parts so il get two conaters of the losi tan grease. Im not using it on my SCTE just my 2wd slash gear diff.
tc5 man is offline
Old 02-22-2012, 02:49 PM
  #29811
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by dgrobe2112
also.. on the Flotek body, in the rear.. its the farthest forward hole. i had to use my body reamer, and put a hole sideways into the rollbar for the body clip to push through
Also - what works well is to move the post up on a hole in the mount, then move the collar back down a hole so that essentially you have one more hole available sticking out of the body to put your body pin into.
I thought the body would clatter like hell, but as long as your holes aren't too wide (so that the posts sit snug into the holes) then it doesn't make any crazy sounds or doesn't really move much at all. You can always add a foam sticky ring under the body to snug things up.
goehm is offline
Old 02-22-2012, 02:53 PM
  #29812
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
I broke my body posts and had spare traxxas ones ( rpm) laying around , never looked back just use a long enough screw and a washer and whoila.
BDRMBULLY is offline
Old 02-22-2012, 03:34 PM
  #29813
Originally Posted by rcus3r
I had the same problem. Send the Spektrum to Horizon. They found nothing wrong and shipped it back to me. Still the same problem; send it to Horizon again; this time, although they found nothing wrong, they are replacing it. I will know next week...
Meantime, I have been running my Traxxas RX/TX on the SCTE without any issues. By the way, I tried the Spektrum on a different truck, and had the same cutting out issues.
Make sure your end points are set on your remote.Or itll draw to much juice and cut out.I actually had to go from a savox to a xp 1015 to cure my bbrown outs.when i would set my end points with the savox i barely had any steering.Now i have a ton of steering throw with the low consumption servo.
Losi57 is offline
Old 02-22-2012, 04:48 PM
  #29814
thanks for the info on my rx/tx problem sounds like alot of people have already narrowed the same issues down. Now I just need to decide what rx/tx to replace it with and get the most bang for my buck. Until then I am switching out with my traxxas 4x4. I hope this fixes the problem I felt like throwing it on the ground and jumping up and down on it like the little girl in walmart that didnt the barbi she wanted when it was giving me fits lastnight. thanks for again for the help
scoobymx79 is offline
Old 02-22-2012, 04:59 PM
  #29815
tc5 man's Avatar
Best bang for your buck i whould have to say the Airtronics MX3 sport radio with a good Rx and quality also $99 the last time i checked.
tc5 man is offline
Old 02-22-2012, 07:12 PM
  #29816
I haven't looked it up yet is that 99 for both or just the transmitter?
Old 02-22-2012, 07:16 PM
  #29817
tc5 man's Avatar
Yes
It includes the RX also for $99.00
The only thing i dint like about the radio is the small steering wheel so i changed it for a JR radio wheel and it fit and its bigger ! Both of the radios use only 4 alkulines so its light but you can use a battery pack also.
Heres the MX3-X for $179 with the Receiver also its the 2nd pic.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-airj1920.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-airj1930.jpg
tc5 man is offline
  #29818
rcus3r's Avatar
Originally Posted by dzstr
Anyone from Losi know when the HD outdrives will be back in stock?
I just hardened my own; got tired of waiting. Pretty simple painless process. Only did it on the center outdrives so far. Put about 5 pacs through them. So far so good. Time will tell. Once I am ready to rebuilt rear and front diffs, I will do it to them as well.
rcus3r is offline
Old 02-22-2012, 07:25 PM
  #29819
Dano628's Avatar
RPPHOBBY.com has HD lightened outdrives in stock . I just picked up fr ,rr,and center . They also have tuned flex chassis's for 84.99 .
Dano628 is offline
Old 02-22-2012, 07:29 PM
  #29820
SoCal Jared's Avatar
I have been off the boards for awhile and was wondering if hacker or others could answer a few questions for me.
1. Unfortunately I have cracked my TLR chassis, it started between 2 unused holes for the nitro build. What is the warranty on these, and how would I go about getting a replacement? BTW it was purchased at WCRC approx 6 weeks ago. I also cracked a lower hole on my front CF tower, not sure how.
2. Are the HA steering balls and new ends worth the upgrade? Seems like the stock ones wear easily and I'm trying to clean up the slop.
3. Anyone running without the front sway bar? Im trying to get more steering radius on this thing.
4. Are variations of the Lane setup still the choice for indoor high bite clay like WCRC?
Thanks in advance
SoCal Jared is offline
