i just got my new flo tec body and i would like to make sure the dimples are correct to fit my losi scte it says to use the 3rd hole for the front and the 1st hole on the back can someone please verify this for me.then my second question is about the aka enduro tire i have seen some racers drill or use a leather punch to put a hole into the tire.what are the differences between hole and no hole.i will be using the stock losi wheels.
any help will be great thanks
I have 2 Floteks....the mounting holes are the 2nd (front, from front to back). The rear is the first set of holes (Rear, front to back).
I have the scte rtr and have ran it for a month now with original electronis. Last night at the track it started cutting out with 3 different 2s batteries all different c ratings in no particular amount of throttle. I read on another thread about receiver/transmitter issues out of the box. Ive checked all wire connections and haven't found anything that looks out of place there. It also seems to be effecting steering to. Anyone heard anything like this or have any ideas.
thanks
thanks
thanks
thanks
Meantime, I have been running my Traxxas RX/TX on the SCTE without any issues. By the way, I tried the Spektrum on a different truck, and had the same cutting out issues.
Il be honest just get rid of the SCTE rtr speckum radio and get a Airtronics MX-3 radio trust me man its a lot better ! I know from using speckum radios and the modules for my other radios.
If you decide to go this route, make sure it's the MX-3X. Very fast response time.
Il be honest just get rid of the SCTE rtr speckum radio and get a Airtronics MX-3 X radio or the MX-3 sport radio both are good. Trust me man its a lot better ! I know from using speckum radios and the modules for my other radios.
also.. on the Flotek body, in the rear.. its the farthest forward hole. i had to use my body reamer, and put a hole sideways into the rollbar for the body clip to push through
What are you guys running for settings on the RX8 with the pro4 4000kv to keep temps in check?
Is the DX3e really that bad? I've been running Spektrum gear in all my RC's (along with just about everyone else in my area) and haven't had a single issue nor has anyone else that I've heard.
Granted, everyone that I know uses the DX3s or DX3Pro's.
Its been a while since I was in rc. just bought a scte roller. need tips on battery motor esc. servo. basically the works. I understand some.about lipo batts but the brushless motors and esc's confuse me. please help. thanks
