Like Tree9Likes
Old 02-20-2012, 11:32 PM
  #29686
wcrase101's Avatar
tim bump chassis on the way hope they come off back order here soon!!!!!!!!
m2c pistons on the way
king headz pin keepers too!!!
few additions to the already bad azz first gen scte!!
can't wait to hit the track this spring!!!!
wcrase101 is offline
Old 02-21-2012, 01:44 AM
  #29687
vasidudu's Avatar
These are pretty cool and useful.
V
vasidudu is offline
Old 02-21-2012, 01:51 AM
  #29688
.AJ.'s Avatar
Hi
what is the difference to the steering if i add the longer drag link????
.AJ. is offline
Old 02-21-2012, 01:53 AM
  #29689
cavg's Avatar
V
I just got these, haven't installed them yet. Together with that i got a set of the center/rear CVD pins aswell since i've been going through 3 of the pins, and i got the new version with a set screw. That construction looks so stable that i'm already regretting spending the dough in the Kings heads keepers.
cavg is offline
Old 02-21-2012, 03:30 AM
  #29690
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by fastchvy View Post
who do you order the batteries threw and how long does it take to get them?
Here are a couple links.
6600's
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
6000's
I would reccommend either the air mail or the 3 day shipping if you need them quickly, I usually allow a week for processing and either 3 days shipping time (with the 3 day air) plus a day or two waiting in customs = 11-12 days total. If you go regular air mail; a week processing, 10 days shipping time, and a couple days in customs = 18-19 days. So it all depends on how fast you need them. I have also heard standard shipping is about a month to a month and a half...
Keep in mind those times may vary... It also depends if there is a chinese holiday in there... My last order I went with the 3 day shipping (did cost a bit more) but I got it to my door in a total of 7 bussiness days. That's pretty quick for an extra $30 in shipping charges!
thecman26 is offline
Old 02-21-2012, 07:10 AM
  #29691
Default CVD's
I'm not having too good of luck with my center and axle cvd's.
3-4 race days is about it and they are worn out or broken. Typically the front CVD pin will let go first and then the rear axle cvd's need rebuilt. The track is pretty gritty sandy so I would assume some amplified wear but this is just too much. I tried to change my brake/burst speed driving style to a more rolling through the corners style and the wear just seems the same. I did find that leaving them bone dry will help a little.
Do you have any suggestions? Are there after market parts holding up better?
gmackhurry is offline
Old 02-21-2012, 07:17 AM
  #29692
Trader Rating: 20 (100%+)
Something doesn't sound right. Our track tends to get dusty as well, and even after running 10-12 packs through mine every Sat. for the past three months my cvds are still in good shape. The only wear I had was the stock outdrives, but after I hardened a set that issue has gone away as well. On the center shafts you might try putting some heat shrink on to act as a dust boot and see if that helps. If it still does it, then you have other issues.
MX304 is offline
  #29693
Grandturk's Avatar
Have you checked your trannies and hubs for frozen bearings? If te drivetrain isnt spinning freely extra stress on the CVDs can speed up the wear process.
Grandturk is offline
Old 02-21-2012, 07:38 AM
  #29694
Yes - all three diffs are very free and spinning with ease. I have been working with 3-3-2, 5-5-2, 5-3-2 oils for a while so the diffs are always opened, clean and inspected. I wish I could shows pictures of it. Just imagine the tee drive end of the front center cvd at the center diff coupler. The steel bar (tee) is worn 1/3rd of the way through.
Maybe it is just the grit and sand?
Has anyone else had low race time issues?
Old 02-21-2012, 07:39 AM
  #29695
namewasdallas's Avatar
Originally Posted by SCTRacerX View Post
Man this new xray 4x4 sct looks a lot like the SCTE just hopped up to the moon. Is it me or did they really use the SCTE for some inspiration on this thing? Lack of originality aside this thing looks like a beast.
http://www.liverc.com/news/new_produ...RC_Xray_XSCT!/
That truck does look like the Losi, The one thing I like about it is that you have the ability to change the Ring/Pinion gears to get different Ratio's. I never owned a r/c car where that is possible but could possibly come in handy.
namewasdallas is offline
Old 02-21-2012, 07:40 AM
  #29696
The heat shrink sounds like a great idae - thanks.
How did you harden your out drives? Did just just turn them red and dunk em in oil or water? I have to try that.
Old 02-21-2012, 07:58 AM
  #29697
mrgunz's Avatar
http://www.amainhobbies.com/product_...Outdrive-Set-2
mrgunz is offline
Old 02-21-2012, 07:59 AM
  #29698
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
If you do make sure its oil NOT water . IDK how much it works though , when we heat treated parts at work it took a lot more than just heating them up and dunking them in oil to harden them .
BashemSmashem is offline
Old 02-21-2012, 08:00 AM
  #29699
Suteki's Avatar
From those pictures, I am struggling to see any difference between the two. Obviously the bumpers are exactly the same as they said but just the lay out of the car from what can be seen in those pics is identical. It would probably be easier to point out what's different rather than the same.
Suteki is offline
Old 02-21-2012, 08:06 AM
  #29700
XRay pretty much copied the 8ight when the released thier 808 buggy , but the difference is really in the materials used , the XRay has parts made out of Unobtainium and powdered Unicorn horns , while the Losi cars are just made out of plastic and metal .
