Like Tree9Likes
Old 02-15-2012, 03:52 AM
  #29356
dtr
dtr's Avatar
Originally Posted by Suteki View Post
I dropped the car from about a foot and it bottomed out, not greatly but enough for me to think that coming off the jump from anything around 5ft is going to be a serious knock to the chasis. Is there usually something to be done about this? Stiffer springs, heavier shock oil?
You are right, the suspension needs heavier oil and/or smaller hole pistons from the piston pack (LOSB2909) to absorb the landings.
dtr is offline
Old 02-15-2012, 05:00 AM
  #29357
I use lighter oil and a bigger piston myself, but my track is a smaller 10th scale track.
LosiMadMan is offline
Old 02-15-2012, 05:06 AM
  #29358
Suteki's Avatar
Whats the relationship between spring, shock oil and shock bore size? If i increase oil weight it is obviously harder for the shock to compress, if i go a heavier oil, should i not go a heavier spring to ensure faster rebound?
Suteki is offline
Old 02-15-2012, 05:38 AM
  #29359
rcus3r's Avatar
Originally Posted by .AJ. View Post
can anyone help?
While back I needed the same info. 'Motor mount screws' search of this thread produces results - LOSA6262
rcus3r is offline
  #29360
FLHX1550's Avatar
Default VX4 Motor Exchange Program
I know there are several people here who are using the Copperhead, so I thought I would share this here:
In an attempt to be "Pro-Active" vs. being "Re-Active", Viper has setup an exchange program on the first run VX4 motors to insure that the best possible solution is available to the customer. Our goal is to ensure that all new VX4/VX4R production will meet the quality commitment and make sure that all customers will enjoy the product without worries.
It has been discovered that there is a problem with the attachment of the magnet to the rotor shaft, and the problem arose in the transition from R&D (motors built by the design engineers) to production (motors being built by production staff). It is a training issue where the magnet may be damaged during installation.
Extensive testing and R&D was done on the development of the VX4 motors and the Copperhead Speed Controls to ensure the utmost reliability and performance from the system. And though the problem with the magnet on the rotor lies in a very small number of units when compared to the number of units that are working just fine, Viper is going to institute an exchange program to insure that the end user ends up with what they deserve.
Steps have been taken to ensure there will not be any future problems with the use of a new fixture in the assembly process, and Viper is going to load and dyno every motor that comes off the line. The failure will come very early on if the magnet is damaged, and will show up in the first few moments once in use on the dyno.
If you have a VX4 or VX4R motor and believe you are having a problem with it, please begin the exchange process by:
1. Please visit Viper RMA system on the web site and fill up your detailed information and press enter.
Viper RMA Form
2. Contact Viper tech support at [email protected] with your RMA number and a copy of your original invoice (scanned image or detailed photo) for your Copperhead system.
3. You do not need to send back the motor. We will send you the replacement as soon as we verify your shipping address with original proof of purchase.
4. The Program will run until March 31st, 2012.
Every qualified case will receive a brand new VX4 or VX4R motor as quickly as possible. In the meantime, Viper will send you a ProGauge with free of charge as compensation of this matter.
Again, we sincerely apologize for this problem, and hope to get all customers back to the track with good products soon!
More information can be found on the Viper Facebook page here
FLHX1550 is offline
Old 02-15-2012, 05:43 AM
  #29361
FLHX1550's Avatar
can anyone help?
If you are talking about the screws that hold the plate on the end of the motor, they are 3mm diam metric screws.
FLHX1550 is offline
Old 02-15-2012, 06:21 AM
  #29362
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by JPG View Post
How tight is the blue collar supposed to be?
Well seeing as they dont make all that much money im guessing pretty tight!!
BDRMBULLY is offline
Old 02-15-2012, 09:16 AM
  #29363
.AJ.'s Avatar
Not them, the screws which go through the chassis to hold the motor mount
.AJ. is offline
Old 02-15-2012, 09:18 AM
  #29364
snwchris's Avatar
I usually screw it on pretty tight to where the spring is compressed really good and then put some blue locktite on the threads/collar so it doesn't back off.
snwchris is offline
Old 02-15-2012, 09:37 AM
  #29365
ScottKelly911's Avatar
Lock it down all the way and use some locktite. Most use blue, but this particular part, I've heard a lot of people using Red locktite just to make sure it never comes loose. In a hobby where you're almost never supposed to use Red locktite, that tells you how important it is to go ahead and lock that thing down
BTW, just for fun, here's a pic of my newest body on my SCTE. It's the JConcepts Hi-Flow body painted by Jgo Paintz http://www.facebook.com/JGOPAINTS?ref=ts Photo by A Kercher Photography at the TLR Winter Series at OCRC last week
ScottKelly911 is offline
Old 02-15-2012, 09:47 AM
  #29366
Trader Rating: 33 (100%+)
nice
dgrobe2112 is offline
Old 02-15-2012, 10:16 AM
  #29367
chucko's Avatar
on the long ackerman arm..... does the spacer go in to the arm from the top or bottom before the screw ?? Thanks cant find it on the manual..
chucko is offline
Old 02-15-2012, 10:21 AM
  #29368
FLHX1550's Avatar
Pretty sure they are #8-32
FLHX1550 is offline
Old 02-15-2012, 11:03 AM
  #29369
cavwrench's Avatar
Trader Rating: 128 (100%+)
Hey guys what are you doing to to paint the rings? What paint etc? Some of your paint jobs with the painted rings look sick.
cavwrench is offline
Old 02-15-2012, 11:16 AM
  #29370
.AJ.'s Avatar
do mean the beadlock rings?? the yellows are available as a optional part
.AJ. is offline
