Like Tree9Likes
Old 02-14-2012, 09:25 AM
  #29341
snwchris's Avatar
Originally Posted by Jethro32 View Post
Im having a problem with my turn radius when making left turns. Turns to the right are pretty tight. TO the left are much wider. I have the servo centered and the drag link seems to be centered. Not sure if Im missing something. Any advice would be greatly appreciated.
Also check the servo saving, maybe the blue screw colloar backed off.
snwchris is offline
Old 02-14-2012, 09:26 AM
  #29342
Trader Rating: 15 (100%+)
On the spring you mean?
Jethro32 is offline
Old 02-14-2012, 09:27 AM
  #29343
.AJ.'s Avatar
I locked my servo saver with threadlock
.AJ. is offline
Old 02-14-2012, 09:29 AM
  #29344
FangsCPO's Avatar
Check your servo saver, it tends to come loose and it will cause you to have reduced steering. Also make sure your servo is perfectly centered before you put the servo arm on. Good Luck!
FangsCPO is offline
Old 02-14-2012, 09:31 AM
  #29345
Ill have to check the saver. The servo seems to be centered and the wheels turn freely left and right. Just doesnt turn as tight to the left on the track. Ill check the saver and see what I find
Jethro32 is offline
Old 02-14-2012, 09:40 AM
  #29346
i had an issue with the servo horn linkage hitting the servo body. i moved the horn back one tooth and all is well now.
gen3busonoma is offline
Old 02-14-2012, 10:03 AM
  #29347
Also, check to be sure that the ackerman screw is not a little loose and thus interferring with turning both ways...something we should all check every full day or so anywho...
hacker07 is offline
Old 02-14-2012, 08:13 PM
  #29348
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
What servo are you using? If everything else checks out, try a different servo with more torque.
KIK is offline
Old 02-14-2012, 08:18 PM
  #29349
R6cj69's Avatar
Trader Rating: 20 (100%+)
Default 10 minute main battery suggestions.
Ok guys, I run a medium size outdoor track that is usually on the loose side. I've been running the Tekin RX8 with the T8 2050 buggy motor on 4S for a few months now and ready for a change. I'm going with the Tekin Pro4 4600KV motor with my RX8 but I'm concerned about battery selection. We always run 10 minute mains so with a 4S thats not a problem but dropping down to
2S I'm worried I won't make the full race. So what are you ten minute main guys running with this motor/esc combo?
R6cj69 is offline
Old 02-14-2012, 08:19 PM
  #29350
kman16jr's Avatar
Trader Rating: 56 (100%+)
I run the same setup with a trinty 65c 6500mah pack and that definately makes the race.
kman16jr is offline
Old 02-14-2012, 08:43 PM
  #29351
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
There are also the new 6600mah 65C Turnigy Nanotechs! I bet those would make it too! I can get 10 or 12 minutes practice with my 6000mah 65C Turnigys...
thecman26 is offline
Old 02-14-2012, 10:57 PM
  #29352
JPG
JPG's Avatar
How tight is the blue collar supposed to be?
JPG is offline
Old 02-15-2012, 12:22 AM
  #29353
.AJ.'s Avatar
Originally Posted by .AJ. View Post
what size are the screws which hold the motor plate to the chassis, ive looked at the exploded diagram which come with the truck but it is very unclear, a losi part number would be handy as well
can anyone help?
.AJ. is offline
Old 02-15-2012, 12:37 AM
  #29354
Suteki's Avatar
I don't know whether I have asked this before but having the chasis bottom out after jumps, is this considered the norm?
Reason I ask is most of the tracks around here are designed for 1/8 buggies. My Emaxx brushless bottoms out constantly and that worries me, I haven't run my Losi SCTE over anything yet, just up and down the road, but when I do eventually take it out the idea of having it slap the ground after landing freaks me out a bit, especially with expensive electronics in it.
I dropped the car from about a foot and it bottomed out, not greatly but enough for me to think that coming off the jump from anything around 5ft is going to be a serious knock to the chasis. Is there usually something to be done about this? Stiffer springs, heavier shock oil?
Suteki is offline
Old 02-15-2012, 03:44 AM
  #29355
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
I run the mmp with 4600 and a 13t pinion on a med outdoor 8th scale track and I have made a 10min main with my gensace 5000mah packs. This was with no warm up laps and nothing left after 10min. With that being said 6000mah should be plenty. I now run the nanotech 6600's and have run a 10min main, then 6 extra laps and the battery had 24% left at that point.
alvinsmith75 is offline
