Like Tree9Likes
Old 02-12-2012, 06:39 AM
  #29251
lowroad's Avatar
Trader Rating: 79 (100%+)
Snapped another hinge pin yesterday. Front this time. You can tell by looking at the break it's just crappy steel. Looks all granulated and almost die cast. Back to the drill blanks, since the ones I made for the rear are holding up great.
Sidenote..I ran the tekin 4600, and it's not light years ahead of the 550 trinity or anything, but it is a bit stronger and the"pull" is different too. Hard to explain, but it's nice.
lowroad is offline
Old 02-12-2012, 06:47 AM
  #29252
BradS's Avatar
Originally Posted by LosiMadMan
Try some of these http://www.amainhobbies.com/product_...-Head-Screw-10
left handed screws. I put some in mine and haven't had any problems since.
I had the same problem and ended up dabbing with super glue to get through the day, will try these. Did you put the lefty screws in all 4 arms?
BradS is offline
Old 02-12-2012, 07:05 AM
  #29253
Integra's Avatar
The LHT screws ONLY Go in the Front Right and Rear Left shocks.
Integra is offline
Old 02-12-2012, 07:15 AM
  #29254
BFoley's Avatar
Originally Posted by krash'um
Does anyone else have a problem with the screws that attaches the shock shaft to the arms backing out? My left rear and right front always backs out. What or how did you guys fix it? My 2.0 buggy and truggy had the same problem but I just put another screw to hold it down but I'm trying to see if there is another or better fix.
The underlying problem is that the pivot ball is binding/frozen in the lower shock ballend. This results in the ball turning counter clockwise (rather than the ballend pivoting around the ball)as the suspension is compressed and eventually backs the screw out. Free up and lube the ball in the ballend and the issue is gone.
BFoley is offline
Old 02-12-2012, 08:08 AM
  #29255
timannnn6's Avatar
Trader Rating: 140 (100%+)
My balls are loose and they still come out (uhhhh that didn't sound right). Left hand thread is fix.
timannnn6 is offline
Old 02-12-2012, 08:11 AM
  #29256
BradS's Avatar
That's what she said... could not resist
BradS is offline
Old 02-12-2012, 08:12 AM
  #29257
BradS's Avatar
Has anyone found other diff gaskets that fit well on this truck. Was kind-of surprised to see losi bundles it with other stuff in a rebuild kit.
BradS is offline
Old 02-12-2012, 11:15 AM
  #29258
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Decided to dust off my TLR chassis and give it a spin. -BCE lover
Feint Motion is offline
Old 02-12-2012, 12:55 PM
  #29259
timannnn6's Avatar
That looks cracka-lackin (no pun intended)
Old 02-12-2012, 01:05 PM
  #29260
Default spare parts lists
i have no spare parts for my truck. short of buying a roller for spare parts, what should i buy to keep on hand? a -arms?,etc,etc. i have the tlr kit so i shouldnt bust a rear hub or shock towers.
skyler hays is offline
Old 02-12-2012, 01:11 PM
  #29261
lowroad's Avatar
The only real spares I seem to need are hinge pins. Arms are basically bullet proof. Maybe pick up a bumper set toom
lowroad is offline
Old 02-12-2012, 01:23 PM
  #29262
BradS's Avatar
Maybe some body posts, set of arms, shock ends, turnbuckle ends and a spur. This would cover some of the stuff that normally wears out and you would use even if it didn't break. I also like to keep a spare diff around in case one goes out, sucks to get out and race and then break in a qual and not finish the day.
BradS is offline
Old 02-12-2012, 01:50 PM
  #29263
Wear and Tear
Get-
*HD outdrives
*Bumpers (F/R)
*Center Driveshafts
*Shock rebuild kits
*Few sets of Diff gears if your running a HI powered system
*A screw Kit.
*Skid plates for longer chassis life.
*Body Posts
Things that aren't really needed-
*Arms- they are tough, they last, only way to break them is if your being foolish on the track.
*Hinge pins- Never bent one, again don't hit anything at 100+MPH and your good.
*Axles- bulletproof
*Spur gear- Mesh it right, make sure your motor mount is treadlock'd and tight.
Old 02-12-2012, 02:40 PM
  #29264
Trader Rating: 70 (100%+)
Default replacement parts
Just get the T-Bone Bumpers - bullet proof and lifetime warranty.
Krafcik is offline
Old 02-12-2012, 02:50 PM
  #29265
lowroad's Avatar
Wear and Tear
Get-
*HD outdrives
*Bumpers (F/R)
*Center Driveshafts
*Shock rebuild kits
*A screw Kit.
*Body Posts
*Axles- bulletproof
I have broken 3 hinge pins. No pipes, no wall, no where near a hundred, I assure you, they break.
lowroad is offline
