Like Tree9Likes
Old 02-09-2012, 11:02 PM
  #29131
Brushless420's Avatar
Trader Rating: 176 (100%+)
Originally Posted by KTMDirtFace
K thanks.
Also wouldnt it be the battery that goes poooof if your running to little C rating? how the heck would the motor/esc blow up?
Also Ethan5050, why does your SCTE chassis a brownish color? is that not stock?
Yes the battery most likely would puff first before anything else. Thats the TLR4000 flex tuned chassis on Ethans truck. Upgrading the shock towers and chassis are the must haves on this truck.
Brushless420 is offline
Old 02-09-2012, 11:39 PM
  #29132
Thanks the info.
I just got my SCTE used from a member here. Roller. has Carbon fiber rear shock tower. and most of the upgrades(i cant remember them all ) I think that are required and a TON of spare parts new in bag. and some skid plates front and rear still in the bag.
Viper Copperhead Motor and ESC gets here tomorrow.
Whats a quality servo I should throw in it? Whats a good torque and speed for this truck?
KTMDirtFace is offline
Old 02-10-2012, 01:07 AM
  #29133
.AJ.'s Avatar
You wont go wrong with a Spektrum H6040 servo
.AJ. is offline
Old 02-10-2012, 01:25 AM
  #29134
vasidudu's Avatar
Default LOSB3590 - Diff Grease
Ryan or Casper,
How much diff grease do you put in the diffs when rebuilding.
I think I will stay with this as it feels ok.
This is the grease I am talking about: LOSB3590.
Thx for your help, much appreciated.
V
vasidudu is offline
Old 02-10-2012, 01:34 AM
  #29135
.AJ.'s Avatar
Originally Posted by vasidudu
Ryan or Casper,
V
Losi smart grease would be a better choice
.AJ. is offline
Old 02-10-2012, 01:50 AM
  #29136
The grease he is looking at is the same grease used to build the truck at the factory. Why is the smart diff grease a better choice?
LosiMadMan is offline
Old 02-10-2012, 02:41 AM
  #29137
vasidudu's Avatar
Any ref pls?
vasidudu is offline
Old 02-10-2012, 02:58 AM
  #29138
3Q
3Q's Avatar
Default Which motor?
Hi there, I've just purchased a new Ten-scte and I've got a MMP, Hitec 7940 servo but no motor as yet. I've got some idea what motor to get for it but I was wondering if I could use a CC 4800kv 540 motor or CC 2200kv 1/8th motor untill I get a 550 sized motor for it? Your help would be greatly appreciated.
3Q is offline
Old 02-10-2012, 03:16 AM
  #29139
dtr
dtr's Avatar
If you want to race, then you are usually limited to 2s lipo, among the Castle motors the 1410 3800kv is the best for you. Is you can us 3s, then the 1415 2400kv is your friend. I would say that the 2200 is too much
dtr is offline
Old 02-10-2012, 03:30 AM
  #29140
3Q
3Q's Avatar
Thanks for your reply, I am thinking of getting the 1410 3800kv but I'm keen to have a drive of my new sct and already have the two motors mentioned above. Will the 2200kv CC fit? Or is it too big? Will the little 540 sized 4800kv 2pole work or is it too small?
Cheers,
Kris
3Q is offline
Old 02-10-2012, 04:35 AM
  #29141
cavg's Avatar
Cheers,
Kris
I'm gonna recommend the Tenshock SC411 4600kv. Go for a sensored motor since you've got an esc that can handle it. I got mine from www.funshobby.com, quick shipping with EMS.
I'm not sure, but i would think you can run the 540 4800kv with very conservative gearing and strict control on temps.
cavg is offline
Old 02-10-2012, 05:04 AM
  #29142
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by gawith0413
Definitely wouldn't do anything less than 50C, you can ruin the motor/esc!
Yeah, no.
lowroad is offline
Old 02-10-2012, 05:21 AM
  #29143
roblupo's Avatar
Those Gen Ace 5000mah 40C batts with the timing turned up on my Novak system actually feel the best as far as punch and discharge in the quals. I have some 6000 60c batts that dont feel this good.
roblupo is offline
Old 02-10-2012, 06:43 AM
  #29144
Briguy's Avatar
Trader Rating: 125 (100%+)
Anyone know the rates of the silver , gold , and black springs ? All I can find id soft med and hard .
Briguy is offline
Old 02-10-2012, 07:15 AM
  #29145
jf45's Avatar
Trader Rating: 93 (100%+)
Originally Posted by "Smiley"
Here is my Set-Up:
Front:
30wt, #3 Piston, Green Spring, Out on Tower and Arm for Shock Positions, Lower Camber Link Hole on Tower, Full Droop (Unscrew Shock Ends 2 Turns), 27mm RH, 7K Diff, Stock Sway Bar.
Center:
7K
Rear:
27.5wt, #4 Piston, Green Spring, Out on Tower and Arm for Shock Positions, Lower Camber Link Hole on Tower, Full Droop (Unscrew Shock Ends 2 Turns), 27mm RH, 3k Diff, Next Thicker Sway Bar from Stock (Forgot what size).
Using "BCE Chassis"
Castle MMP, Tekin 4600, 14T Pinion, Integy IP 6200 2S Batts, Easy 10 mins every time.
I use the Hot Bodies Megabite Tires 99% of the time. This is a very easy to drive setup that you can push hard. Give it a try.
Hi
Im going to try your set up.
What camber link hole are you using on the rear hub?
jf45 is offline
