Like Tree9Likes
Old 02-09-2012, 07:40 PM
  #29116
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Dano628
IMO you would want a higher c rating I run 60c I wouldn't run less then 50 myself .
Definitely wouldn't do anything less than 50C, you can ruin the motor/esc!
gawith0413 is offline
Old 02-09-2012, 07:46 PM
  #29117
kman16jr's Avatar
Trader Rating: 56 (100%+)
I run the trinity 65c 6500mah 2s and it has plenty of time to spare after a hard 10 minute a-main
kman16jr is offline
Old 02-09-2012, 09:23 PM
  #29118
Brushless420's Avatar
Trader Rating: 176 (100%+)
Originally Posted by Feint Motion
I run a metal spur in my SCTE. and love it. people will say "why do that? Your gaining rotation mass", blah blah. I don't really feel a difference and I still win races with it.
Ofna Hyper 9 metal spur fits perfect, uses the same teeth as the stock spur. (dont have the part number), you'll have to so some modifying, but the 4 holes will mount up perfectly. You have to cut the center of the gear out. The metal is hardened, so you'll need a nice powerful cutting tool.
Heres mine, sorry, my truck is still dirty
My pinion gears last, You have to mesh it up perfectly to reduce metal -metal wear.
cant see myself going back to a plastic spur, feels like a driving a buggy lol also love the sound.
Just wondering why you would want to run a metal spur? There is absolutely no advantage. Ive been running the stock spur since the scte was released and have a couple spares in the box but the stocker is barely worn. Proper gear mesh is all that is needed especially in MOD 1 gearing. If you looking for more noise run nitro.lol
Brushless420 is offline
Old 02-09-2012, 09:24 PM
  #29119
Feint Motion's Avatar
Trader Rating: 24 (96%+)
I like the sound.
Feint Motion is offline
Old 02-09-2012, 09:36 PM
  #29120
Originally Posted by HighLife420
I got them from my Local hobby shop, im going there tomorrow, i know they had another center, I didnt check on the FR. Check hobbycrap.com thats their site. The are right down the street from my office, so i go there regularly to pick up parts/tires.
Do you need LOSB3571 (Front ring and Pinion) to seal the diff?
I bought a roller with some parts, so i have the gear set, the diff seals. I wanted the lightened outdrives, so all i needed was the housing to build another diff. Well, minus the mentioned above, LOSB3571.
The front and rear diffs are the same right? Minus the Rings/Pinon (LOSB 3571/3572) of course.
Also, friend recommended i seal it with a very small amount of RTV sealant, Red version. Anyone else use this? Tips?
1. No but you will have to take the screws out then put the ring gear on, then put the screws back in. I don't know if the screws will bottom out without the gear.
2. Yes the front and rear are the same the center uses different out drives.
3. I don't use it but some people do.
LosiMadMan is offline
Old 02-09-2012, 10:04 PM
  #29121
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
ryan or casper,
when can we expect to see the new parts (shock shafts, steering posts, hinge pins) in stock at retailers?
RC*PHREAK is offline
Old 02-09-2012, 10:07 PM
  #29122
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by RC*PHREAK
ryan or casper,
Late March.
Casper is offline
Old 02-09-2012, 10:19 PM
  #29123
I'm getting a Viper Copperhead combo 4500kv tomorrow, what batteries needed for that?
I have two Gens Ace 2s 5000mah 40C's
that good enough? they are plenty for my Flux HP which is basically 1/8 scale Mamba Monster stuff. Why would you need over 50c? my Flux requires 100amp miniumum which would be like 25c.
KTMDirtFace is offline
Old 02-09-2012, 10:28 PM
  #29124
Those would be fine. Saying you need 60C is ludacris.
In fact I beta tested the Copperhead system for the last 2 months with the 5150kv on 2s and ran those exact packs. So no worries.
Old 02-09-2012, 10:34 PM
  #29125
Ethan5050's Avatar
Trader Rating: 54 (98%+)
Talking
ok well heres an update of my scte.. Well I added a tekin 1900kv motor and 4s lipo.. I also did the emulsion shocks on it... Can you guys tell a good gearing for this setup, and also if that motor is gonna kill the plastic spur gear? Let me know any tips you guys might have for me with this setup thanks...
Ethan5050 is offline
  #29126
Default lol
LOL
Old 02-09-2012, 10:43 PM
  #29127
Heres a tip
I would go 14T or 15T
http://scriptasylum.com/rc_speed/top_speed.html
Old 02-09-2012, 10:49 PM
  #29128
RC*PHREAK's Avatar
Originally Posted by Casper
Late March.
thanks! really looking forward to the steering posts and shock shafts.
Old 02-09-2012, 10:53 PM
  #29129
K thanks.
Also wouldnt it be the battery that goes poooof if your running to little C rating? how the heck would the motor/esc blow up?
Also Ethan5050, why does your SCTE chassis a brownish color? is that not stock?
Old 02-09-2012, 10:55 PM
  #29130
Its the TLR Flextune chassis. (watch out for cracks)
Im going to use my TLR chassis, and see if I get the dreaded "crack'd " chassis this weekend on my other scte.
