Like Tree9Likes
Old 02-09-2012, 08:58 AM
  #29071
Trader Rating: 23 (100%+)
Originally Posted by HighLife420
Anyone have a metal servo horn that fits their scte?
I cant see if to find one thats high enough to not rub the servo casing...
I use dynamite alum horns
nitro0619 is offline
Old 02-09-2012, 09:02 AM
  #29072
.AJ.'s Avatar
i use one of these with out any problems
http://www.ebay.co.uk/itm/Losi-8ight...item3f10210bc2
.AJ. is offline
Old 02-09-2012, 09:04 AM
  #29073
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Lighter diff oils, softer front springs, softer or no front sway bar, shorter rear camber link.
Originally Posted by FLHX1550
Any ideas on how to decrease the turning radius on the SCTE?
ChrisAttebery is offline
Old 02-09-2012, 09:08 AM
  #29074
You should mention the surface that you're running on. From the MegaBites I'd assume you're on a loose surface.
I think your setup would have way too much steering and traction roll like crazy at my track.
Originally Posted by "Smiley"
Here is my Set-Up:
Old 02-09-2012, 09:12 AM
  #29075
Lighter front diff fluid will decrease turning radius on power for sure. When I just went from 5 5 3 in the diffs to 7 5 3 it decreased the over steer / turning radius. Perfect for my driving style.
oldschoolnewb is offline
Old 02-09-2012, 09:22 AM
  #29076
Originally Posted by Suteki
How do you know you're not?
Also, kind of ironic comment coming from LosiMadMan
That just means I like Losi stuff. I don't come on here and plug other products every other day.
LosiMadMan is offline
Old 02-09-2012, 09:43 AM
  #29077
FLHX1550's Avatar
Ok, again. Not really looking for any suspension settings to gain more steering at speed.
I want to know if anyone has a solution to decrease the turning radius and the utmost slowest speed. Like is there any what to grind the knuckles, C-Hubs, etc....
Unfortunately this truck at low speeds cannot turn a tight arc at low speeds. I'm talking like 5-10% throttle at most. Where I race is tight and technical, VERY tight. We have 2 corners that are 180's that come one right after at very low speed. Good tires and such, just not enough steering through (probably down 25% on the AE Truck
FLHX1550 is offline
Old 02-09-2012, 10:15 AM
  #29078
HighLife420's Avatar
Trader Rating: 49 (100%+)
BTW, if anyone is interested, i have some Alu shock tops and collars from a tuning kit. I had them already, so have another set. Both in the plastic, never used.
Will sell them for $30 plus a few dollars to ship, or might trade for some other hop ups.
HighLife420 is offline
Old 02-09-2012, 10:17 AM
  #29079
zippygraphix's Avatar
Default Awesome New Chassis
hey guys just want to throw this out there.. a new chassis design.
http://www.kingheads.com/product_inf...36f1fc0b510e54
more efficient drive train. great strength. and gave me faster laps
they also make a metal cvd pin cover to keep that pin where it needs to be
http://www.kingheads.com/product_inf...4976047789c25f
More to Come!!!
zippygraphix is offline
Old 02-09-2012, 10:22 AM
  #29080
.AJ.'s Avatar
More to Come!!!
that chassis got linked on this thread a few days ago
.AJ. is offline
Old 02-09-2012, 10:36 AM
  #29081
vasidudu's Avatar
Got these last week...
They are NOT silver... Black anodized.
Need some spare time to rebuild diffs, install HD outdrives F/C/R and install these...
Best,
V
vasidudu is offline
Old 02-09-2012, 10:37 AM
  #29082
.AJ.'s Avatar
Best,
V
Link doesnt work for me
.AJ. is offline
Old 02-09-2012, 10:41 AM
  #29083
lowroad's Avatar
Trader Rating: 79 (100%+)
More to Come!!!
I run the cvd sleeves, and yes, they are pretty slick. That chassis though doesn't look so hot to me with the motor hanging out over the edge of the chassis and even more off center than stock. The angle of the driveshafts has never bothered me, nor have I ever heard a complaint about how it works. Other than looking a little funky, the stock arrangement seems fine.
lowroad is offline
Old 02-09-2012, 10:52 AM
  #29084
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
skyler hays- It does very well with tight 180's.
dmwilson09- No problem. You should like it.
dgrobe2112- Forgot those, lol. -1 Camber all around, Stock Antisquat, 3.5* Rear Toe. I'll go down to 3* on a very high bite track. Give it a try Daniel, I'll bet you'll like it.
"Smiley" is offline
Old 02-09-2012, 11:20 AM
  #29085
Trader Rating: 90 (100%+)
Setting your travel/EPA on your transmitter should be the first thing you do.
Kuya_Kimo is offline
