Like Tree9Likes
Old 02-08-2012, 04:52 AM
  #28981
FLHX1550's Avatar
Originally Posted by Mxer59 View Post
I also saw these they look good and priced very well anyone running these, is sensorless a big deal? Or sensored better I was looking at 4600kv or 5100kv
Viper did allot of R&D to get the Copperhead to be very smooth and drive-able, and kind of took a "clean-slate" approach to developing a sensor-less system. Though it is a "sensor-less" system, it performs nothing like sensor-less systems that came before it.
Reminder, neither the 540/3900kv, the 550/5150kv or the 550/4500kv systems ARE ROAR LEGAL!!!!
The systems were really focused at the basher / hobbyist level market to replace and/or upgrade people in the RTR market. With those thoughts in mind, Viper built the motors to be as efficient as possible at a fair price. Unfortunately that required going outside of the ROAR spec's for the motors, but that was never the intent with the system.
Given the durability/performance of the Copperhead, we are finding they are kind of filling a "void" in the racing market for a simple and affordable system for the 4wd SCT class. Where they are and are not allowed to run is up to the people having the races, and I suggest you check with them to determine if they are legal or not to race there.
FLHX1550 is offline
Old 02-08-2012, 05:02 AM
  #28982
Trader Rating: 41 (100%+)
I am talking about the small piece that bolts flat to the shock tower with 4 screws around the diff housing, and the front bumper braces to it with two screws.
TheRevolution is offline
Old 02-08-2012, 05:33 AM
  #28983
shinnbad12's Avatar
This piece would be nice to see it in a cnc alluminum upgrade.
Scott
shinnbad12 is offline
Old 02-08-2012, 06:39 AM
  #28984
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Look up Kick Angle on any of the available tuning guides.
Originally Posted by HighLife420 View Post
Hey guys, got my tuning kit installed, all but the front hinge pin holder. I was wondering something, looking at the diagram, it shows the the values as
Angle 8-9-10-11-12
What do these values represent?
ChrisAttebery is offline
Old 02-08-2012, 06:50 AM
  #28985
Scott
Yes, yes!!! This one of the piece's I keep breaking!!!!! It should be made aluminum. 100%
LosiMadMan is offline
Old 02-08-2012, 07:05 AM
  #28986
HighLife420's Avatar
Trader Rating: 49 (100%+)
Ah, thank you...couldnt figure the name of the adjustment.
What is the stock front give you in terms of value? (8-9-10-11-12)
Im hearing that 0 inserts for both (10) is the normal and best setting overall?
HighLife420 is offline
Old 02-08-2012, 07:19 AM
  #28987
Originally Posted by "Smiley" View Post
Another win for the scte. This past weekend was Rd 1 of the Rc Pro Texas State Series hosted by Mikes Hobby Shop/Gulf Coast Raceway in Porter, Tx. I TQ'ed and Won with the scte. There were almost 60 entries in the 4wd Sc Class. The truck was flawless all weekend.
What setup do you run at Mikes?? I dont know if I will ever race but would like to setup my truck to perform well at that track.
dmwilson09 is offline
Old 02-08-2012, 07:41 AM
  #28988
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Casper View Post
I would start there for sure. It is a great base setup.
Hey Casper,
What does it mean on Aaron setup:
http://www.losi.com/ProdInfo/Files/L...Lane-JBRL4.pdf
The rear suspension anti-squat: 3(using aluminum pivot supports). Is 3 the insert your suppose to use. Front or back? Thanks
gawith0413 is offline
Old 02-08-2012, 07:45 AM
  #28989
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
SNR Graphite is offline
Old 02-08-2012, 07:52 AM
  #28990
FLHX1550's Avatar
Originally Posted by gawith0413 View Post
Hey Casper,
3 is the angle (3 degrees of Anti-Squat). Use a #1 pill in the front block on the rear bulkhead, with the hole in the "up" position
0 pill is 2 deg Anti-Squat, .5 up is 2.5, 1 up is 3. .5 down is 1.5, 1 down is 1 deg
The pills in the back block are for adjusting rear toe-in
FLHX1550 is offline
Old 02-08-2012, 08:06 AM
  #28991
gawith0413's Avatar
I think I'm starting to understand this. Thank you very much!!!
Old 02-08-2012, 08:08 AM
  #28992
Originally Posted by easye View Post
I boiled all my bumper peices for 30 mins havnt broke a single peice since.
Right, I have yet to try this, but it was recommended to me by someone at Losi who posts on this thread.
AgroAMG is offline
Old 02-08-2012, 08:13 AM
  #28993
Default broken tlr rear hinge pin holder
I'm probably the only person to have ever broken this piece. Once this happens even if you replace the plastic insert, it just continues to break the new plastic inserts as the aluminum isn't there to provide support anymore.
AgroAMG is offline
Old 02-08-2012, 08:26 AM
  #28994
gawith0413's Avatar
That sucks!!!
Old 02-08-2012, 08:59 AM
  #28995
.AJ.'s Avatar
what is the diff ratio of this truck?????
.AJ. is offline
