Like Tree9Likes
Old 02-07-2012, 12:55 PM
  #28921
fastchvy's Avatar
Trader Rating: 15 (100%+)
Ryan, what are the stock piston numbers for the truck....I switched mine to #3 in the front and #4 in the rear
fastchvy is offline
  #28922
AbstractZen's Avatar
Originally Posted by hacker07 View Post
That chassis does look pretty good. It is certainly another option and something I considered trying as well but I could not get over the motor being cock-eyed in the truck, lol. One thing to keep in mind is bone bind does come into play and changing that certainly affects the way the car works.
I haven't seen anyone complaining about any problems related to drive shaft angle on here (and you know somebody would've by now). It appears to me to be a solution to a problem that doesn't really exist.
AbstractZen is offline
Old 02-07-2012, 12:56 PM
  #28923
Trader Rating: 19 (95%+)
Just a little side note on this weird china discussion going on in here...
I work in design. I design things that operate at over 1000 deg F and have a tendancy to blow up and kill alot of people if they arent built with the proper materials. I have NEVER seen a company willing to accept our product if it is made by materials supplied from China. In fact only Japanese material is acceptable from the Asian area. Additionally, it is very, very rare that we can get a customer to accept our product if it is manufactured in our China factory, even if the materials are sourced from North America (only a mexican company has ever accepted it and only once).
Of course, in here we are talking about little toy cars, so take it for whatever you will, but chinese materials and/or workmanship is not highly regarded in any product in any field of manufacturing. Of course it does keep our costs for our hobby down too.
Regards,
Proud BCE owner
RedDevil13 is offline
Old 02-07-2012, 12:58 PM
  #28924
Trader Rating: 33 (100%+)
i think stock is #3 all around..
dgrobe2112 is offline
  #28925
Casper's Avatar
Trader Rating: 34 (100%+)
7-5-3 is a great option as traction gets high. Tames down the car some and helps it be a little more stable. 5-5-3 is a better general diff setup though. The Lane setup was posted after we ran on a track they literally glued together with what looked like school glue. Traction was pretty high as we were basically running on a layer of rubbery material.
All the other arguments on here are why I stopped checking in. One good relevent question per page and the rest is bickering about nonesense. No one is forcing anyone to buy anything here and the info is out there. Make an informed choice that lets you sleep at night!
Casper is offline
Old 02-07-2012, 01:16 PM
  #28926
gawith0413's Avatar
Trader Rating: 86 (100%+)
Casper,
So which set up would you suggest I start out with on a pretty large 1/10th indoor track. It smooth and pretty sticky. If your not set up right your can definitely roll in the corners. I'm trying to determine what diff fluid to go with along with, springs, shock oil weight, ride height, everything. Thanks guys for all the help, I truly appreciate it.
gawith0413 is offline
Old 02-07-2012, 01:22 PM
  #28927
Casper's Avatar
Originally Posted by gawith0413 View Post
Casper,
If you like lots of steering 5K. If you like a car that is a little a little more stable and easier to drive 7K. Sounds like your track could go either way.
Casper is offline
Old 02-07-2012, 01:27 PM
  #28928
Brushless420's Avatar
Trader Rating: 176 (100%+)
Default sensor cable
What length sensor cable are you guys running with the rx8 pro4 combos?
Brushless420 is offline
Old 02-07-2012, 01:36 PM
  #28929
cavg's Avatar
I tried running 3-10-2 today. I kind of liked it.
Are there any negative handling characteristics when having such large differences in diff oil?
cavg is offline
Old 02-07-2012, 01:42 PM
  #28930
Something like this will react more like a 10th scale electric buggy where you can adjust the front and rear diff and other than that, you have 4 wheel drive. Just rotates through the corner a little differently is all. The lighter oils will tend to drive through the whole turn. With the heavy center, you likely want to drive in hard, brake, swing, and then stab the throttle.
hacker07 is offline
Old 02-07-2012, 02:48 PM
  #28931
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Sounds like how I drive now! Perfect!
DoogieLee is offline
Old 02-07-2012, 02:49 PM
  #28932
gawith0413's Avatar
So should I just run the whole Aaron Lane setup?
Old 02-07-2012, 02:59 PM
  #28933
ckrdflg's Avatar
Does anyone know of any plans by Losi, or any aftermarket parts, to replace the dogbones? Or is there anything, short or grease, that can be done to quiet the dogbones?
ckrdflg is offline
Old 02-07-2012, 03:00 PM
  #28934
HighLife420's Avatar
Trader Rating: 49 (100%+)
Just curious guys, anyone here run a RX8-Pro4 4600 combo with a 15/40 gear setup? Just wondering your temps (approx).
HighLife420 is offline
Old 02-07-2012, 03:18 PM
  #28935
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by lowroad View Post
Last I heard, Taiwan is well within the ROC (China). So, now you are arguing semantics? So maybe the material was incorrect, but clearly it's made in China, by your own words.
http://en.wikipedia.org/wiki/Taiwan
Ya know... the more you talk the less I believe anything you say.
goehm is offline
