Like Tree9Likes
Old 02-04-2012, 08:24 PM
  #28756
Originally Posted by fourseventeen View Post
I just got a new SCTE this week and I went to swap out the diff grease with Losi fluid instead. When I opened the diffs all of the metal parts inside looked rusted on 2 of the 3 diffs Is this the norm coming from Losi?
And I am reading there there were 2 different versions of the truck...one with soft or weak pins and then the newer truck with the upgrade pins? How do I know which one I have? I just got it on Wends but whos to say how long the shop had it for before I bought it. So I dont know if I have the updated version or not?
I had the same thing but I don't remember which ones had rust. I asked my brother and he said he didnt have any rust. I just figured there was nothing I could do about it anyway. I just cleaned them out and filled them with silicone. I have 4-5 full packs on the truck with a night of practice and it ran fine.
Oh yeah my truck does have a little white sticker on the side of the battery tray. So I guess I have a newer one...
Mark K is offline
Old 02-04-2012, 08:30 PM
  #28757
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by darryl80 View Post
doesnt that sleeve make the shaft smaller? i am looking for the sleeve that makes my sheft into a 5mm shaft.
i know what you want. i gave you a link. if you don't believe me or don't trust the info, i don't know what to tell you.
RC*PHREAK is offline
Old 02-04-2012, 08:32 PM
  #28758
darryl80's Avatar
Trader Rating: 24 (100%+)
i was reading the description wrong my bad.
darryl80 is offline
Old 02-04-2012, 08:36 PM
  #28759
R/C Tech Elite Member
rcaddiction's Avatar
Trader Rating: 351 (100%+)
Default scte rear chassis brace upgrade
has anyone thought of using part number ASC89069 for a rear brace?
all you have to do is grind out a little of the stock mounting area on the rear diff housing and use the other hole on the chassis it looks cool and holds the rear diff better to the chassis In my option check out the pictures
Attachment 873365
Attachment 873366
Attachment 873368
rcaddiction is offline
Old 02-04-2012, 08:40 PM
  #28760
Default 3mm to 5mm adapter
this is what i am using part number OFN30669 you can find it on amain
Old 02-04-2012, 08:48 PM
  #28761
Trader Rating: 29 (100%+)
Originally Posted by dmwilson09 View Post
Ok, I am stumped, I installed a cc bec after not being able to get the glitching to go away on my MMP/Pro 4 4600 set-up. I did a few full throttle pulls from a dead stop to make sure the glitching went away and then on the last pull, bam, nothing. The esc would not turn back on, nothing. So i switched out the battery and everything work turned back on. I looks like the battery shorted out or something, but there is no charge and I cannot even charge the battery. I was running a gens 2s 40c 5000mah. Any advice would be great??
My setup
MMP
Pro 4 4600
External BEC (6.0 v)
S6040 Servo
Spektrum sr300 RX
Spektrum DX3 Tx
Gens Ace 2s 5000 mAh 40C
What version firmware are you running? Maybe try dropping back to an older version (non-beta)?
Jay13 is offline
Old 02-04-2012, 09:12 PM
  #28762
Trader Rating: 15 (100%+)
Default shock mod
Has anyone drilled the shock cap and used the foam under the bladder to smooth the shocks out? I have done this on my 1/8th scale and touring cars and it works great.
mdhyams is offline
Old 02-04-2012, 10:26 PM
  #28763
HighLife420's Avatar
Trader Rating: 49 (100%+)
Originally Posted by LosiMadMan View Post
Try 5k in the front and if you want more steering go to 3k.
so run it 553 or change the others?
Thanks for the help.
HighLife420 is offline
Old 02-05-2012, 12:54 AM
  #28764
vasidudu's Avatar
I think he means 553 / FCR.
V
vasidudu is offline
Old 02-05-2012, 02:02 AM
  #28765
Had my second practice day yesterday with the truck. I am now running everything the same as the Phend set up sheet on the losi site. The only thing that I am running different are the RC Shox 2 stage pistons.
The first time out I had a lot of problems with uncontrollable over steer. That was with 553 in the diffs and no end points set on the radio. This time I went with the 753 in the diffs and reduced the steering throw.
On bald super soft Rebar tires the car was turning and performing better than I could have expected. This was blue grove conditions at the Coral Springs R/C car track. Yeah, thats right. They run blue grove conditions for practice day.
There is alot of positive and negative comments out there about the two stage pistons. So far I like them.
oldschoolnewb is offline
Old 02-05-2012, 05:17 AM
  #28766
Ethan5050's Avatar
Trader Rating: 54 (98%+)
Ok well this is my first short course truck, and I'm surfing the web for the best motor setup, but it really seems to be hit and miss. I'm looking for purely runtime, I want a setup that will give me the most runtime. I don't care about racing, or lipos, or motor size. Please tell me what you guys think would be the best with that being said.... Thanks....
Ethan5050 is offline
Old 02-05-2012, 05:41 AM
  #28767
cwilkinson's Avatar
1/8th motor like 2650 on 2s probably get you decent runtime compared to 540 and 550 can motors
cwilkinson is offline
Old 02-05-2012, 05:46 AM
  #28768
goehm's Avatar
Trader Rating: 45 (100%+)
The Castle 1410 motors seem very efficient. Though unsensored, they're a great price / performance option for bashing. Runtime will be determined greatly by batteries, so a Turnigy Nanotech 6600mah seems like a good fit. Maybe a Hobbywing 120A Xerun ESC.
Looks like you have some money in performance parts/tires for a non racing rig...
goehm is offline
Old 02-05-2012, 06:44 AM
  #28769
You going to practice today? Look out for me if you are...I sit next to Thomas and Dex. ll be the tall asian guy with the Associated shirt on...
Old 02-05-2012, 06:51 AM
  #28770
rcus3r's Avatar
Originally Posted by BashemSmashem View Post
That is the dreaded brown out , try a spektrum cap first , if that doesnt work then get a BEC ......
My 'brownouts' follow the radio. I have SCTE RTR. I experience momentary loss of power at full throttle, but only at 20+ yards. Seems to work fine close by. Cap did not help. Put in Traxxas radio, no glitching; put the Spektrum radio into a different truck, glitching.
Send it to Horizon. They found nothing wrong and send it back to me. Installed it, glitching.
rcus3r is offline
