Like Tree9Likes
Old 02-03-2012, 06:27 PM
  #28711
what would be a good setup for this track? the guys that run it are really fast!
http://www.facebook.com/photo.php?v=10150533699073759
http://www.youtube.com/watch?v=8zcKzLHYtQw
skyler hays is offline
Old 02-03-2012, 06:43 PM
  #28712
Default Modded Front Hinge Pin Holder Screws
The roller I bought apparently had the wrong length screws on the front hinge pin holder. They where to short and one ripped out of the diff case on a hard hit. Luckily there was plenty of meat left in the diff case for a longer screw.
There where no local shops that carry the 5-40 5/8" screws that are supposed to go there, and I want to practice tomorrow. So I improvised. I went to the hardware store and got some #6 3/4" sheet metal screws.
I had to make the hole in the hinge pin holder slightly larger to fit the thick threads through, but they worked out perfect. Because there is so much more meat to the threads, you can get the screws so much tighter without stripping the plastic.
I am now considering swapping out the other diff screws for these. The fine threads on the stock screws are just not right for that soft plastic. You have to be so freaking gentle or they just strip right out. These sheet metal screws don't strip!
oldschoolnewb is offline
Old 02-03-2012, 06:54 PM
  #28713
Trader Rating: 163 (100%+)
i would try the phend setup from roar nats, has worked well for me indoor or outdoor
cjm1126 is offline
Old 02-03-2012, 07:00 PM
  #28714
easye's Avatar
Originally Posted by namewasdallas View Post
+1
I've been waiting to see one and I did some hunting around on Boobtube today and came across that one thought it was pretty funny lol. Curb's and R/C car's going fast dont mix.
What type of Foams are people running in their tire's with the AKA ( Grid-Iron's) ??
I was looking closed cell foam's and also I think made by Proline a Double Foam, which the inside foam is hard then the Outside is softer for jumps and bumps. I don't know what type of foam's I've ran before as I just run whatever comes with my Tire's.
Does Proline give Closed cell foams with their tire's ? or what type of foam usally comes with them?
aka molded or team epic" bomb 1" firm
easye is offline
Old 02-03-2012, 10:14 PM
  #28715
Trader Rating: 25 (100%+)
I got sick of searching 1900+ pages so I will ask here though I am sure its been mentioned before.
fourseventeen is offline
Old 02-03-2012, 10:17 PM
  #28716
Default ecs link to computer
What is the link wire called that hooks to computer and where can I get one
scoobymx79 is offline
Old 02-03-2012, 10:58 PM
  #28717
Depends which ESC?
Tekin is "Hotwire"
Castle is "Castle link"
ebay, Amain Hobbies, etc...they all have them or you could prolly find a used one here on the for sale forums.
  #28718
I just got a new SCTE this week and I went to swap out the diff grease with Losi fluid instead. When I opened the diffs all of the metal parts inside looked rusted on 2 of the 3 diffs Is this the norm coming from Losi?
And I am reading there there were 2 different versions of the truck...one with soft or weak pins and then the newer truck with the upgrade pins? How do I know which one I have? I just got it on Wends but whos to say how long the shop had it for before I bought it. So I dont know if I have the updated version or not?
Old 02-03-2012, 11:13 PM
  #28719
cavg's Avatar
Look for a little sticker on the battery tray with numbers on it. If there is one it's one of the new ones you got a hold of.
cavg is offline
Old 02-04-2012, 02:20 AM
  #28720
Was it NEW or new to you? Did the diff have any grease in it? If it was brand new in the box call Horizon Tech support they will take care of your rusted gears.
LosiMadMan is offline
Old 02-04-2012, 07:58 AM
  #28721
thanks.. esc is the original that comes in the truck. I just want to know what i was looking for when i search a few shops today. thanks again
Old 02-04-2012, 08:06 AM
  #28722
Trader Rating: 15 (100%+)
Default esc and motor
I am looking for an originial factory ESC and Motor for my son if anyone has one laying around they would like to sell.
mdhyams is offline
Old 02-04-2012, 08:16 AM
  #28723
.AJ.'s Avatar
The stock esc is a rebranded Castle MMP
.AJ. is offline
Old 02-04-2012, 11:18 AM
  #28724
Default SCTE Issue
I just got an SCTE and I have the MMP and Pro 4 4600 combo, with a spektrum s4060 servo, sr300 rx, and DX3 tx. I am also running a spektrum cap to try and prevent glitching. I have never had glitching problems so I am not sure what is considered glitching. The issue I have right now is when going to full throttle from a dead stop, the truck accelerates for a short period of time and then nothing. It is like ever thing quits. Is this a glitching problem, a brown out problem? Any input would be most helpful.
dmwilson09 is offline
Old 02-04-2012, 11:27 AM
  #28725
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
That is the dreaded brown out , try a spektrum cap first , if that doesnt work then get a BEC ......
BashemSmashem is offline
