I hope you dicks are happy because I just bought a tekin pro4 4600. I still think it's too much motor for 90% of us including me, but for the $95 I paid (used) I will check it out first hand. Maybe. Or maybe I will sell it and keep my 5.5 550 trinity monster. We shall see.
when crackin into my diffs to just swap grease for oil (seems to work fine besides play in my center out drives) can someone tell me what i parts i need like shims or O rings and what you guys are doin that helps dial them in with no leaking
its my first 4x4
i know its been said but this thread has a redic amount of posts! and its hard to keep up!
its my first 4x4
I must also be one of the lucky ones with diffs that don't leak. I fill my completely full (with side gear in and oil all the the very edge of housing). The only two tricks I did are sanding the diff housing flat (removing mold lines) on gasket surface and glued in the metal outdrive bushings. Where are you guys having the leaks from the outdrives or gasket?
BulldogSRT
BulldogSRT
Diff case and outdrives are quite loose after many runs. I bet that diffs are leaking from outdrives. By the way. Why there is groove on outdrives? Is it for smaller O ring or just for nothing?
I will test diff leaks (almost like wikileaks
) with colored water. I have leaking problem as well. I havent put black grease to outdrives but I have greased them with littlebit different grease.
Thought this would cheer up everyones day, watch this video.
http://www.youtube.com/watch?v=5FWEY...eature=related
I run an SCT-pro hobbywing esc. If comes to that much detuning, it's the wrong motor, in my opinion.
I really like the idea of having a bigger motor and tune down, so when i need it, its there....
temps are low also.
+1
I've been waiting to see one and I did some hunting around on Boobtube today and came across that one thought it was pretty funny lol. Curb's and R/C car's going fast dont mix.
What type of Foams are people running in their tire's with the AKA ( Grid-Iron's) ??
I was looking closed cell foam's and also I think made by Proline a Double Foam, which the inside foam is hard then the Outside is softer for jumps and bumps. I don't know what type of foam's I've ran before as I just run whatever comes with my Tire's.
Does Proline give Closed cell foams with their tire's ? or what type of foam usally comes with them?
You kids and your four poles get off my lawn!!!
