Like Tree9Likes
Old 02-02-2012, 04:18 PM
  #28666
Trader Rating: 15 (100%+)
Originally Posted by Gas Rat Racin View Post
I just bought 2 new 6600 nano techs. Does know if there is a "Break In Period" for these? If so what do I need to do?
How did you get them? Ive been waiting for over a month for them to come off backorder
Jethro32 is offline
  #28667
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by omenwolf View Post
I have a set of rulux that i use for racing, I have about 20-30 packs through them and no cracks at all.
And what do mean silly beads, you have to look good going around the track too sometimes
Thanks, makes more sense. One person who never ran themsaying they're crap becuase he read about a couple people with issues should'nt sway me like it did. I know better. I still hate the trim rings :-D
lowroad is offline
Old 02-02-2012, 04:21 PM
  #28668
lowroad's Avatar
Originally Posted by AgroAMG View Post
Enlighten me on this screw vs going with bare aluminum (how it is now). How can I do what you suggest? Any pics? Any part numbers, sizes, etc. ?
4-40 tap and drill from the hardware store. part numbers for screws on the first page.
lowroad is offline
  #28669
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
I read it on here awhile back that they were in stock so I went to Hobby King and ordered them. It did take a long time to get them because I chose the cheapest shipping option. I guess I was just lucky.
Gas Rat Racin is offline
Old 02-02-2012, 04:22 PM
  #28670
I also have a set of relux wheels with no issues
Old 02-02-2012, 04:25 PM
  #28671
Originally Posted by NitroLuver View Post
Raced my car last night and I have two problems.
1 huge problem I've always had is the rear of my car just wants to slide.I try hitting a little brake before entering a high speed corner and it doesn't help and if I try to just roll through the corner my truck slides out. I lose so much time off the straight because of it.
2. For some reason last night my car just felt slow/ actually was physically slow I didn't have any acceleration and down the straight I didn't have any top speed...First time this have ever happened to me.
Current Setup:
Stock Everything ie. Chassis,shock towers,sway bars.
Shock Setup 35F Black Spring, 30 Rear Orange Spring
Shocks in middle of a-arm both front and rear
Front shock inner hole on tower rear shocks stood all the way up
unsure of ride height(forgot to check it)
camber whatever stock is
diffs 5F 3C 3R
tekin rx8/4600kv pro 4 geared 13/40
Jconcepts barcodes (orange)
Track is med/high bite indoor clay(WC/RC)
Problem 1 is your shock setup. Move the lower mount to the outer hole and the top to the middle. I tried the setup your running and it pushed like crazy and was loose feeling. I would also try a different tire like Aka city blocks or pro line Calibers. I run City Blocks as do most of the people at my track on very hard packed clay/river sand, and topsoil. I'm picking up a set of Calibers for when the track has been watered.
2. I noticed you didn't list lightened out drives. This IMO is the first upgrade to get. If your running stock one they are probably worn and that can severely cut your acceleration.
LosiMadMan is offline
Old 02-02-2012, 04:54 PM
  #28672
Integra's Avatar
Drilled and Countersunk. I prefer the Larger Button Screw Vs the Flat heat Screw.
Charge at 1C for the for 3-4 charges.
Integra is offline
Old 02-02-2012, 05:01 PM
  #28673
Trader Rating: 46 (100%+)
I will try changing up the shocks, I do have the outdrives and they will be installed along with my other chassis and tuning kit when I get my scews. Calibers will not work at west coast( i run the tire that most run there). Either barcodes, suburbs, and some have tried re-bars
NitroLuver is offline
Old 02-02-2012, 05:11 PM
  #28674
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Have you tried Beams? Those are a great tire!
thecman26 is offline
Old 02-02-2012, 05:39 PM
  #28675
You can see from his pictures the top of the screw takes minimal damage and when it's worn you just replace it. The Losi chassis has these holes drilled already you just have to buy the screws. IMO this is a major oversite by all the other chassis makers out there. This is my opinion only and one of the reasons I went with the Losi chassis.
Old 02-02-2012, 06:01 PM
  #28676
thecman26's Avatar
+1, kinda like the Tekno chassis, the chassis shouldn't really be a "wear" item...
Old 02-02-2012, 06:15 PM
  #28677
HighLife420's Avatar
Trader Rating: 49 (100%+)
Well, SCTE take #2 is in full effect. Just got back from the hobby store with brand spanking new RX8 and Pro4 4600kv.
Going to start off 14/40, maybe 10 or so boost...what you guys think? Track is BG clay, outdoor, 140x70 with a approx 125ft straight.
HighLife420 is offline
Old 02-02-2012, 06:20 PM
  #28678
thecman26's Avatar
Those things don't need any boost! They are rocket ships without boost and timing! I have heard that just make them run hotter, not any faster.
Old 02-02-2012, 06:25 PM
  #28679
Really? I would think i would need boost to keep the pro4 up with the 550 can motors...
Good to know, ill try with nothing first and see. Maybe i should go up a tooth in pinon then?
Thanks for the info.
  #28680
big_alex39301's Avatar
Default shock towers
Has anyone tried the STRC shock towers?
big_alex39301 is offline
