I use EC5 plugs they can handle the volts and amps this unit needs
The Wife will never know unless you ask her to dry lol
I use bullets and plug directly into the battery from the ESC. I have one battery that has wires so I put female bullets/tube connectors on it.
I like to take a paper towel while holding the outdrive and stick it in the.diff housing while rotating the gear assy. The grease will transfer to the paper towel , just repeat on clean sections. It will remove the majority. I have done this on my 1/8 scale for years. GOOD. LUCK!!!
i blew 2 rear diffs today, not sure how
even a guide on the link http://www.amainhobbies.com/product_...ow-2-2WD-Slash to show where you need to trim the inside of the wheel. $9.49 on amain
Anybody running the Pro4 3300 on 3s? I am looking to get a new motor and would like to go 3s to keep temps down and runtime up. My local track doesn't care if you run 3s and I was stressing my batterys pretty bad with the castle 3800 on 2s 40c batterys so figured the 3300 would be more efficiant. Just wondering if anyone has experiance with this set up and how it runs.
At practice the other day my truck started making a bad clicking noise under acceleration and braking. I stopped it right away and checked the rear diff and both my pinion gear bearing had exploded. Luckily I stopped when I did because there was no damage to the gears.
I was following a guys 10th scale truck the other day at practice. The guy said he felt like he was being chased by Black Death. My truck is totally black with green skull stickers lol it was funny. I love my truck it's insanely fast but smooth.
what is the best motor & esc combo setup for the losi ten scte?
I gotta ask this. What makes the RX8 so good? Or should I ask why does everyone think it is so good? I have been running castle mmp and mmms for years now and they have been almost flawless. A friend just bought a buggy and since most people on this forum bleed red and black I recommended, against my experiences, that he go with the tekin motor/rx8 combo. Low and behold the rx8 lasted 2 races before going out. This is extremely common for rx8's from what I have seen at our local track. Anyone have any kind of positive response to this?
I know this isnt the tekin forum but get over it.
