5k/5k/3k is a pretty good starting point. Some use 5k/3k/3k if you want to have more control during initial acceleration or if the track is bumpy and blown out.
If you want to know how changing the oil viscosity in each diff affects your car, google search "jq theguide" or "Hudy set up guide" and download the .pdf of each and read up on diff tuning. Keep a copy in your tool box so you can reference them at any time if you forget what the different car settings can potentially do.
As far as changing the oil, that depends on how much you run or race or how much you like to maintain your car. For this car, I maintain the diffs regularly (I used to run twice a week and change them every 3 weeks or before big races).
Most of the slop left in the system is in the servo saver post. Ryan is always working to make the car better.
Thank You!!!
This should help me out alot!!! Most of the time I need to write stuff down for me!!! My friends set my truck up for me on sunday!!! And I won 2 qualifiers and the A-Main!!! I don't catch on very quickly. But when I have the right set up I win!
Hi there everyone,
just thought I would sum up what I have done to the truck and a couple of details that might give an insight to whoever is wondering what to buy as hop up and/or spares...
ENJOY:
OTHER BRANDS HOPUPS
Jammin Products Light Weight Aluminum Wheel Hex Set (4)
ST Racing Concepts CNC Machined Precision Aluminum Center Bulkhead (Blue)
King Headz CVD Pin Keeper Set (2)
DE Racing Mud Guard Set (TEN-T/SCTE/810)
SNR Graphite Center Plate 3mm
SNR Graphite Front Top Plate 5mm
Full Set of Chris Pins
LOSI HOPUPS
Losi 4mm Carbon Rear Shock Tower
Losi 4mm Carbon Front Shock Tower
Losi Shock Standoff Set (4)
Losi Aluminum Shock Collar Set (2)
Losi Aluminum Shock Top Set (2)
Losi Aluminum Rear Hub Set
Losi Adjustable Front Hinge Pin Holder Set
Losi Adjustable Rear Hinge Pin Holder Set
Losi Front/Rear HD Lightened Outdrive Set (4)
Losi Center HD Lightened Outdrive Set (2)
Losi Front and Rear Shock Spring Set (4) (Gold–Firm) (Ten-T)
Losi Front and Rear Shock Spring Set (4) (Black–Medium) (Ten-T)
Losi Front & Rear Shock Spring Set (4) (Silver/Soft) (Ten-T)
Losi Spur 40T
Losi TEN-SCTE Wheel Set (2)
AKA Racing Enduro Short Course Tires w/Red Insert (Soft) (2)
LOSI SPARE PARTS
Losi Axle Set (2)
Losi Front/Rear CV Driveshafts and Couplers (Ten-T) (2)
Losi Center/Rear Drive Shaft
Losi Center/Front Drive Shaft
Losi Differential Seals w/Gasket & Hardware (Ten-T) (3)
Losi Shock Rebuild Set (Ten-T)
Losi Front & Rear Gearbox Set (Ten-T)
Losi Front Spindles & Carriers (Ten-T)
Losi Rear Suspension Arm Set (Ten-T)
Losi Front Suspension Arm Set (Ten-T)
ESC/MOTOR
Castle Creation Mamba Max Pro SCT
Castle Creation 1415/2400Kv
Castle Creation 1410/3800Kv
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (13T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (15T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (17T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (19T)
OFNA 5mm to 3mm Pinion Adaptor (4)
LIPO
Turnigy NanoTech 6.0 2s (3)
And to finish, fresh from the grill... My new body:
PS: did I say I was having a LOT of fun with that thing ;-)
ENJOY:
OTHER BRANDS HOPUPS
LOSI HOPUPS
Losi Spur 40T
LOSI SPARE PARTS
Losi Axle Set (2)
ESC/MOTOR
LIPO
Have yet to install HD outdrives F/C/R.
Will also check all diff and rebuild with Chris Pins and go 3/5/2 or 3/3/2.
Also waiting on King Headz CVD Pin Keeper Set.
Same for DE Racing Mud Guard Set.
Have rebuilt shocks 30W F/R. Awaiting HARD & SOFT springs set.
Will probably go soft all around
Installed SNR front plate (8mm) and diff plate (4mm).
Installed CNC Machined Precision Aluminum Center Bulkhead (Blue)
Installed Jammin Wheel Hex Set.
Installed Full TLR.
HUDY servo arm.
For the moment it is still on the MMP SCT 14/15 2400Kv 19T.
Lots of Torque on 2s. Pretty nice on our new 1/8 track.
Awaiting on CC 1410/3800Kv with 13/15T.
New body not finished yet.
Me likey,
V
I finally got a chance to run my new SCTE setup today. I started with the Phend/Lane setup and then made the following changes:
F: purple spring, 3/32.5, Middle/Outside position, +2 turns out
R: orange spring, 4/30, Outside/Outside position, stock length
+2 kick up/caster in the front
Battery tray 1/2" back from the stock rearmost position. Basically a 50/50 F/R distribution.
The truck drove great. The 4600 is definitely easier to drive. The suspension changes gave the truck a little more on power steering and made it less twitchy compared to my last setup.
I'm still new to this truck. Are the rear diff cups supposed to move around a lot? It seems totally different from the front diffs.'I've read thriugh the manual and searched online. Just trying to confirm if this is normal or not
Yep, I have a lot of play, and this is on my new one. I just bought another 4x4 and retired my old race truck. Everything else is tight. Is Ryan working on a new part, if so do you know how much longer.
I swapped out my outdrives in the center diff to the lightened ones and after re-assembling everything correctly it's real tight and there seems to be a spot that catches. I'm sure it's assembled correctly. Did it a few times. I'm curious, would there be a downside to taking out the small shims that sit behind the spider gears? I'd rather do that then double the gasket.
Hey guys,
Ive been out of R/C for a little while now, but am deciding to come back in, and Im thinking of picking up a Losi Ten SCTE, But I am a little shaky on which motor/esc system to choose. Im mainly going to be using this for bashing around in the front yard (neighbours have slash 4x4's) and some track use (Not actual racing, just going there to practice/etc..), and of course offroad bashing.
Im thinking:
Tekin rx8 esc
Tekin 5.5 550 motor
With a 3s 5000mah 40c Lipo?
The other route I was thinking was going with the Castle 2400kv system..
Any thoughts?
Im thinking:
Tekin rx8 esc
Tekin 5.5 550 motor
Any thoughts?
