Like Tree9Likes
Old 01-25-2012, 08:21 AM
  #28216
Trader Rating: 18 (100%+)
Originally Posted by BDRMBULLY View Post
New viper esc motor combo!! When ever they decide to release them lol
I have one on B/O since black friday. Any info anyone?
I asked about these on their Facebook page right before Christmas and they said they were in production and should be at retailers by the 2nd week in January...I decided I didn't want to wait any longer and grabbed my RX8/Tenshock setup and I'm glad now because January is almost over and there's still no sign of the Copperheads.
teknic is offline
Old 01-25-2012, 08:23 AM
  #28217
Originally Posted by cuppcake80 View Post
tekin 550 4.5 or trinity 550 4.5? please help!
Or get more power for less money and get a Tenshock SC411!
teknic is offline
Old 01-25-2012, 08:34 AM
  #28218
chucko's Avatar
Originally Posted by photobrat View Post
I have the TLR lightened chassis coupled with the TLR torque brace on the rear of my truck. I have broke the upper rod end (that attaches to the rear diff housing) three or four times now, seems like the ends are screwed very tight onto the shaft to get it to fit, perhaps causing the problem?? Anyone else have this problem? Any ideas for a solution?
This will not break I use it. its a direct bolt on. hope this helps
http://www.amainhobbies.com/product_...-Chassis-Brace
chucko is offline
Old 01-25-2012, 08:45 AM
  #28219
Trader Rating: 62 (100%+)
Just to clear things up. I believe bill cleared up all the misunderstanding about bce chassis. Everyone is happy.
buckeyenut73 is offline
Old 01-25-2012, 08:53 AM
  #28220
I am always seeing you guys talk the BCE chassis up. Without having to go back and read a few hundred pages can someone tell me the benefits to this chassis over stock? Also, is there any other brace or anything I need to get with it? Thanks for the info.
SC-Racer is offline
Old 01-25-2012, 08:57 AM
  #28221
Casper's Avatar
Trader Rating: 34 (100%+)
If the plastic ends are not all the way screwed in next to the alum rod they tend to break easier. I have broken one end since I started testing the rod. A little thread lock to keep things in place works well.
Casper is offline
Old 01-25-2012, 09:04 AM
  #28222
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
What it comes down to for this truck is any of the lightened upgrade chassis out there work well and are better than the heavy stock chassis. Also, the aftermarket chassis gets rid of the center plastic piece that the center diff is mounted to which makes the CG a little lower and also the driveline angles a little less severe.
On this truck, I have the Bump chassis, and have only tried the bump chassis. It has the option for different chassis braces (stock, Bump chassis brace, RC8 brace, etc.) It also comes with the shorter diff screws required for mounting the center diff without the center plastic piece. It is a nice improvement over the stock in that it just plain handles better and is more responsive.
I've heard similar things about the bce chassis, SNR chassis, and TLR chassis. I have tried chassis from all these brands on my other cars, and I've always like the upgrade.
SEF is offline
Old 01-25-2012, 09:44 AM
  #28223
snwchris's Avatar
Originally Posted by MOE View Post
Anyone have an MMP paired up with the Tekin Pro4 4000? will it work?
I just hooked up my MMP & 4600 last week.
It works fine, there's a slight chance you might have to change the motor direction in the ESC. I had to with mine and now it works great. Wired A-A, B-B & C-C
Hook it up and go thru programming the radio/esc and see what direction it's running.
snwchris is offline
Old 01-25-2012, 09:49 AM
  #28224
Trader Rating: 30 (100%+)
Yes it works and if spins backward just switch outer two wires with the mmp dont forget to run glitch buster or bce to get rid of glitch from servo or receiver pack think i am going to try that witj 800 mah lipo
jewn_beef is offline
Old 01-25-2012, 09:53 AM
  #28225
Does the BCE chassis come with the shorter screws? What chassis brace do you use with the BCE?
Has anybody compared the Bump to the BCE? If so what kind of differences?
SC-Racer is offline
Old 01-25-2012, 09:54 AM
  #28226
Trader Rating: 17 (100%+)
If you are running non-sensored you can do this, but if you are running sensored you have to go into the software and set it to spin the other way.
mavrick0 is offline
Old 01-25-2012, 11:04 AM
  #28227
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Yes it does.
Just use the stock plastic braces. The chassis is stiff enough without upgrading the braces.
I think 99% of the guys that have used the BCE chassis haven't had any reason to look at another.
ChrisAttebery is offline
Old 01-25-2012, 11:30 AM
  #28228
vasidudu's Avatar
Hi there everyone,
just thought I would sum up what I have done to the truck and a couple of details that might give an insight to whoever is wondering what to buy as hop up and/or spares...
ENJOY:
OTHER BRANDS HOPUPS
Jammin Products Light Weight Aluminum Wheel Hex Set (4)
ST Racing Concepts CNC Machined Precision Aluminum Center Bulkhead (Blue)
King Headz CVD Pin Keeper Set (2)
DE Racing Mud Guard Set (TEN-T/SCTE/810)
SNR Graphite Center Plate 3mm
SNR Graphite Front Top Plate 5mm
Full Set of Chris Pins
LOSI HOPUPS
Losi 4mm Carbon Rear Shock Tower
Losi 4mm Carbon Front Shock Tower
Losi Shock Standoff Set (4)
Losi Aluminum Shock Collar Set (2)
Losi Aluminum Shock Top Set (2)
Losi Aluminum Rear Hub Set
Losi Adjustable Front Hinge Pin Holder Set
Losi Adjustable Rear Hinge Pin Holder Set
Losi Front/Rear HD Lightened Outdrive Set (4)
Losi Center HD Lightened Outdrive Set (2)
Losi Front and Rear Shock Spring Set (4) (Gold–Firm) (Ten-T)
Losi Front and Rear Shock Spring Set (4) (Black–Medium) (Ten-T)
Losi Front & Rear Shock Spring Set (4) (Silver/Soft) (Ten-T)
Losi Spur 40T
Losi TEN-SCTE Wheel Set (2)
AKA Racing Enduro Short Course Tires w/Red Insert (Soft) (2)
LOSI SPARE PARTS
Losi Axle Set (2)
Losi Front/Rear CV Driveshafts and Couplers (Ten-T) (2)
Losi Center/Rear Drive Shaft
Losi Center/Front Drive Shaft
Losi Differential Seals w/Gasket & Hardware (Ten-T) (3)
Losi Shock Rebuild Set (Ten-T)
Losi Front & Rear Gearbox Set (Ten-T)
Losi Front Spindles & Carriers (Ten-T)
Losi Rear Suspension Arm Set (Ten-T)
Losi Front Suspension Arm Set (Ten-T)
ESC/MOTOR
Castle Creation Mamba Max Pro SCT
Castle Creation 1415/2400Kv
Castle Creation 1410/3800Kv
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (13T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (15T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (17T)
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (19T)
OFNA 5mm to 3mm Pinion Adaptor (4)
LIPO
Turnigy NanoTech 6.0 2s (3)
And to finish, fresh from the grill... My new body:
PS: did I say I was having a LOT of fun with that thing ;-)
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-scte_small.jpg
vasidudu is offline
Old 01-25-2012, 11:37 AM
  #28229
BDRMBULLY's Avatar
big long list like that and you take a pic of the shell??? lol wheres the GOODS???
BDRMBULLY is offline
Old 01-25-2012, 11:41 AM
  #28230
vasidudu's Avatar
AAARRRGGGHHH,
It's coming up... Right in the middle of rebuilding...
V
vasidudu is offline
