I ordered gears from amain were old ones which are just fine I just munched some trying to push the envelope on some wore out pins I now have awhole set of extra built diffs which make it nice encase of emergency... I wouldn't stress about getting new gears I would just keep an eye on your pins so you dont get those gears bound up tighter then a nuns ____ fill in the blank haha
guys I got a question about building turnbuckles for my stadium truck, I just got these titanium turn buckles, I was putting them together and I thought when you put each ball cup on and turn them in opposite direction it would screw them on but when I try this one side will loosen it's self off..
Am i suppose to thread them all the way on first one side at a time then back them out to get the right camber and such?
I've just never put them together I've always just adjusted them while on the truck. I mean its 3 parts so im guesing they have to be threaded all the way on then backed out?
R/C Tech Elite Member
Checked my center diff the other day and re-filled the fluid. When I tighten down the screws it locks up the gears. I don't have any more seals so I can't double up and I tried to cut another seal out and put it in but it just blows the fluid out. I decided to pack it full of grease for the race today and wait for a new cup and seal to re-build it. I see this happening to allot of people, and my diff is built perfectly. I have built a ton of diffs and don't usually run into this problem. It probably wouldn't leak if I could tighten it all the way down.
Also kind of a newbie question but which motor combo seems to have success. I typically run outdoor loose dusty tracks. I have a CC MMP and 3800 installed. Have a Trinity Monster Horse 5.5 as backup.
Also acquired a Tekin Pro4 and RX8. Any comments would be much appreciated.
Thanks in advance.
Those of you with tight diff problems try this first. Take the pins and cross them. Put them on a flat surface. They should both sit flat without any rocking. If the pin was not cut deep enough they can cause the problem you're describing.
If you bought my pins and are having this type of problem please let me know and I will replace them.
Thanks,
Chris
Thanks,
Chris
Will a ARR SCTE purchased and drop shipped directly from Horizon around the first of the year have the lastest revisions or should I pull the center diff out to seal it better? Motor will be here next week, never been run.
I think your tactic of killing us with kindness is definitely going to help get you an answer faster.
Thanks for the help I will try this when rebuilding them tomorrow.
