Like Tree9Likes
Old 01-18-2012, 08:00 PM
  #27901
namewasdallas's Avatar
Originally Posted by lowroad View Post
Put that thing under the driveshaft!
Pretty sure this is a 100mm sensor wire, but it's also a 550 motor, so a tad longer I guess. I'm under 6lbs with a nano-tech, stock body, wheels and tires with this set-up.
what ESC is that because Im thinking of buying a BCE but I have a rx8-pro4 so im trying to quess at what my weight will be the pro4 is ligther then the 550 u have but my esc might weight more or less that'd be sweet if I was under 6lb's RTR if I get the BCE
namewasdallas is offline
Old 01-18-2012, 08:02 PM
  #27902
Originally Posted by cuppcake80 View Post
does anyone know when that revtec motor is shipping?
also is there much difference between the tekin redline 4.5 & the trinity monster horse power 4.5?
thanx in advance
I talked to RevTech 2 weeks ago it was shipping on the `1st/2nd of this month. Its a 1/8 shaft and not 5mm FYI think someone said there comming out out with a 5mm shaft. 4800kv looks pretty sweet 2-4s caibable
Old 01-18-2012, 08:03 PM
  #27903
POWESKULL's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Feint Motion View Post
Did mine the same way, but used a 4" sensor wire.
4in sensor wire is perfect, looks tight in the pics, but it has enough slack.
My sensor wire pulls out with little force so how do you make sure it does come loose?
POWESKULL is offline
  #27904
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by myl3s91 View Post
I didn't have any issues with the center diff screws being too long, which two screws are long? The ones that go into the plastic or metal?
metal
looks like the hobbywing SCT Pro with the fan taken off.
RC*PHREAK is offline
Old 01-18-2012, 08:06 PM
  #27905
POWESKULL's Avatar
Is the REVTECH sensored or sensorless?
Old 01-18-2012, 10:40 PM
  #27906
myl3s91's Avatar
Originally Posted by RC*PHREAK View Post
metal
I did notice those did stick out a little bit so i did what was recommended and they are perfectly flush. One other one i notice sticks out a HAIR is a the black screw that holds down the battery tray, i think its cause it is right where the chassis bends.
myl3s91 is offline
Old 01-18-2012, 10:51 PM
  #27907
Scooby Horton1's Avatar
Sensored
Scooby Horton1 is offline
Old 01-18-2012, 11:45 PM
  #27908
vasidudu's Avatar
Default Pro-Line Trencher
Hi there all,
Question: will the Pro-Line Trencher SC M2 2.2"/3.0" fit on losi stock wheels?
Thanks for the feedback.
Best,
V
vasidudu is offline
Old 01-18-2012, 11:52 PM
  #27909
myl3s91's Avatar
I just noticed and searched the scte forum and my screws on the motor mount are too long for the BCE chassis. I switched them out for two in the front diff. Should i get new screws or is that okay? ALSO the battery tray screw seems to be a little too long as well is this another screw that is replaced?
myl3s91 is offline
Old 01-19-2012, 05:08 AM
  #27910
lowroad's Avatar
Trader Rating: 79 (100%+)
It's the hobbywing sct pro without the fan. Get the BCE you will NOT be sorry.
lowroad is offline
Old 01-19-2012, 05:23 AM
  #27911
Trader Rating: 24 (100%+)
Guys, what is the best lube for the pivot balls? I just installed the new LOSI HD ball set with dry lube and they are very tight after a night of practice.
jetcam2 is offline
Old 01-19-2012, 05:30 AM
  #27912
lowroad's Avatar
Originally Posted by vasidudu View Post
Hi there all,
Best,
V
Yeah, why not?
lowroad is offline
Old 01-19-2012, 05:41 AM
  #27913
cavg's Avatar
I accidentally ran my sct pro without the fan running, and after a pack it was too hot to touch. Measured 140 but felt like alot more.
By the way..
Don't take this the wrong way but damn it disturbs me that you don't have any problems with your sct-pro. That means there might be some shit on my end that could be causing my issue with the brake delay.
The only thing i can think of right now is that the compatibility between the rx and the esc could be the cause of this. Is that even possible though? Anyway i have been planning on getting another radio sooner or later, so i bumped up that to be sooner and will see how it works out. Sanwa MT4.
cavg is offline
Old 01-19-2012, 05:46 AM
  #27914
lowroad's Avatar
By the way..
Im using the same rx's since i use the mx3s. Let me take this thing out in the street today and go max to max and see if I can detect any brake delay if I am actually looking for it. Never noticed before for sure. With the 550 and a16t pinion I haven't needed a fan.
lowroad is offline
Old 01-19-2012, 06:06 AM
  #27915
cavg's Avatar
I'm uploading a vid of it now.
Funny thing is, now when I shot it i noticed that i could get near instant braking if i paused shortly at neutral. Although i have tried changing the neutral range to no avail.
Forgot to add that my current radio is the FlySky GT3B.
cavg is offline
