Like Tree9Likes
Old 01-16-2012, 12:17 PM
  #27691
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Originally Posted by roblupo View Post
I have a Novak 4.5 ESC and motor, 13 tooth and 14 tooth pinion gear running 5000mamp batts with 40-65c and can not make the 10 min mains. Anyone have any suggestions ? Running truck stock with diff fluid in it instead of grease. 5/5/3 in it.
Turn your current limiter down to like 80% also from my experiance if you are on a large outdoor track it just aint gonna happen. Tried all last summer to make more then 8min and it just would not happen. Lucky for me Mains were 7min
Littlejohn Dsgn is offline
Old 01-16-2012, 12:21 PM
  #27692
Trader Rating: 33 (100%+)
5000mah just wont do it for 10 mins.. lipo cutoff wont allow it.. i run 8 mins on outdoor with 5600 and after the main.. i gotta put just over 4k back in the battery.. running hard the whole time..
i ran a 10 min main this weekend.. same battery.. made 10 mins.. but died before i could make a half lap to my pit area.. also.. for the last 2 or so minutes i was half throttlling.. no more triple.. cuz 2nd place dumped out right at 8.
dgrobe2112 is offline
Old 01-16-2012, 12:31 PM
  #27693
Nano Tech 6.6's should get you there with room to spare. They are on BO though. The 6.0 Nanos should do it too and they are in stock but only in the international warehouse.
65BAJA is offline
Old 01-16-2012, 12:38 PM
  #27694
Casper's Avatar
Trader Rating: 34 (100%+)
I run my pro4 with a 13T pinion and it runs between 140-150 all day long. I run ty's setup for ESC settings. (10 advance timing)
Casper is offline
  #27695
Even a 6.0 might be pushing it depending on track size, and to make 10min you will need to control that throttle finger too.
Old 01-16-2012, 01:01 PM
  #27696
spider882009's Avatar
Trader Rating: 7 (89%+)
Smile Dumping!
Im running a REVTECH 6000 mah and after a 10min main Im only having to charge it abut 3300 or so!!! I keep hearing about all the batteries dumping after 8 min... Ten Min main I make it all the way and I have about 4 other guys running REVTECH 6000 mah batteries... The one guy has won 4 out of the last 5 weeks in a Ten min main!!!
spider882009 is offline
Old 01-16-2012, 01:15 PM
  #27697
BQRacer's Avatar
Trader Rating: 29 (100%+)
Just moved and going to start racing at crcrc. Was wondering what a good starting point setup would be for the truck? Thanks
BQRacer is offline
Old 01-16-2012, 01:35 PM
  #27698
Whats your track like? On the huge 1/8th I run on we are wot on 95% of the track. I just raced indoors on a small tight track and had about 12 min of practice on the same pack that I could not make 8min on outside.
Old 01-16-2012, 01:36 PM
  #27699
Trader Rating: 19 (100%+)
Several of us runnin there and all use a little bit different setup than the next. Biggest improvement ive made is a bump chassis. Make sure u come out to race friday nights as thats when we all run pro4
nitro0619 is offline
Old 01-16-2012, 01:49 PM
  #27700
Benny 13's Avatar
+1 on this setup. never see anything over 130's
Benny 13 is offline
Old 01-16-2012, 02:53 PM
  #27701
Trader Rating: 18 (100%+)
Got to run my truck today for the first time since changing the diff grease out for 3-3-2 and wow I'm able to carry so much more speed in the corners now...I also laid my front shocks down so that may be helping too.
Find out tomorrow at racing if I've dropped my lap times or not...hopefully!
teknic is offline
Old 01-16-2012, 03:23 PM
  #27702
Originally Posted by lowroad View Post
No one said you did. As i said, if you have to go spektrum ..get the R pro. Just skip the S.
I was just saying because you said to avoid Spectrum all together.
LosiMadMan is offline
Old 01-16-2012, 03:31 PM
  #27703
I the same setup on a indoor small track, timing at minimum and was rolling off the track in the high 170's. I had to drop to a 12t to get the temps down.
For the last couple of weeks I've been searching for more off power steering. I've went as far as removing the front sway bar and that helped alot, but I could use more. I'm running 5,5,2 with the shocks in the stock config with stock oil.
Old 01-16-2012, 03:32 PM
  #27704
Thumbs up E-Scale
Both Tracks I run on are 1/8 Scale hard packed!!! Very Smooth Groove!!! The main classes @ my track is E-Scale... The indoor track is huge! Similar to track in NJ! Im in Westren Pa! Don't have many indoor choices here!!! The nicest track is in Sarver, Pa
Old 01-16-2012, 03:44 PM
  #27705
lethal19's Avatar
so to avoid the spectrum should someone go with the Futaba 4PL if they are on a budget and want to stay around 250?
lethal19 is offline
