Like Tree9Likes
Old 01-14-2012, 04:23 PM
  #27601
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Panda-PR
+1 on the MT-4. No problems and is very light and not too bulky
+1,000,000. MT4 is the best thing since sliced bread along with the BCE Chassis
alvinsmith75 is offline
Old 01-14-2012, 04:45 PM
  #27602
Kevin_M's Avatar
I have my scte and bought the Tekin pro 4 4600 and the RX8 seems to be out of stock and my guys at LHS tell me that the RX8 is going to get redone. What other ESC could i use to get racing or should I wait for the updated RX8?
Kevin_M is offline
Old 01-14-2012, 05:22 PM
  #27603
namewasdallas's Avatar
I really like the looks of the MT4 hopefully I can find a used one for a reasonable price. I hope by spring to be a proud owner of a BCE chassis, they look sweet but I like how they shave a decent amount of weight off the truck which makes the biggest difference on these trucks.
namewasdallas is offline
Old 01-14-2012, 05:26 PM
  #27604
Trader Rating: 18 (100%+)
MMP, Hobbywing SCT-Pro, Hobbywing Xerun 150A, Havoc Pro SC (has to be x-drive model). Probably many others, but those are the ones I'm familiar with.
teknic is offline
Old 01-14-2012, 05:30 PM
  #27605
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Arrow Hobbywing o7E-C-Xerun-120A-SD
Hobbywing 07E-C-Xerun-120A-SD
Let me tell you... i'm a Teakin Fan... I love them... I have 5 tekin's... but ... but.... my new ESC the Hobbywing is just flat out Awsome. Man for like $125 its almost a nobrainer. Smooth , so powerfull, and I beat it down in my SCTE and it never ever failed ! Most of the top guys at my track run them... I was like... a Hobbywing?? Are you sure... so I spent my money and ... man.... i'm so happy!
XXXDad is offline
Old 01-14-2012, 06:23 PM
  #27606
KalEl63's Avatar
I thought I would just throw this in here instead of starting a new thread as it is relevant to this (sort of). I have been reading people are using the 6000mah or 6600mah Nano Tech lipos with the Tekin combos in their SCTE I am just wondering if my Turnigy Accucel 6 would handle charging these?
I think the Turnigy Accucel 6 only charges up to 6000mah?
Sorry if it is a stupid question.
KalEl63 is offline
Old 01-14-2012, 06:38 PM
  #27607
scracer68's Avatar
Default Castle 1415 vs Tekin Pro4
For anyone who has used the Castle 1415 on 3s and the Tekin Pro4 on 2s in their SCTE, wich motor has the most power? Also how large of a pinion can I use with the 1415 on 3s without having heat issues.
scracer68 is offline
  #27608
goehm's Avatar
Trader Rating: 45 (100%+)
The short answer is: yes it can charge them without a doubt. No charger has a mah limit. Mah is battery capacity, so the higher mah then simply the longer it'll take to charge it. People buy higher wattage/amperage chargers so they can charge the higher mah packs quicker.
goehm is offline
Old 01-14-2012, 07:12 PM
  #27609
omenwolf's Avatar
Trader Rating: 37 (100%+)
I have run the 1415 on 3+4s and the tekin 4000 on 2s and the 1415 definatly has more grunt by far. I have the 1415 currently on 20t and I run on 2and 3s and temps never get over 130 with the 3s
omenwolf is offline
Old 01-14-2012, 07:23 PM
  #27610
Yes it will charge them, it'll take over an hour though since those are 5A chargers.
teknic is offline
Old 01-14-2012, 07:27 PM
  #27611
scracer68's Avatar
Thanks buddy.
Old 01-14-2012, 07:48 PM
  #27612
FYI. I have run my 6.6nanotechs for two race weekends now and after a 10 minute main, when I put my packs on charge they have been having between 25 and 27% still left in them. These things are flat out awesome.
Old 01-14-2012, 07:58 PM
  #27613
KalEl63's Avatar
So just selected 6.0 lipo balance on the chargers and it will charge it full with a 6000mah will that also charge the 6600mah fully too?
KalEl63 is offline
Old 01-14-2012, 09:05 PM
  #27614
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
you can't compare the power of two systems that use different voltages. the 3s system is just going to have more rip (assuming the motors are decent). my 810 on 3s with the 1415 just rips. massive low end that a 2s system just can't produce.
most chargers come with a maximum mah they will charge pre-set to 5000mah. you can either adjust that or once the charger shuts off at 5000, you can just start it up again.
RC*PHREAK is offline
Old 01-14-2012, 10:54 PM
  #27615
I'm considering purchasing a new esc. I have been looking at the Orion R series controllers, but I'm torn between the R8pro and the R10pro. I will more than likely be using a Novak 4.5 550 motor, but currently have a castle 1410.
What are your thoughts?
Tacticalmonk is offline
