Like Tree9Likes
Old 01-13-2012, 05:41 PM
  #27556
Trader Rating: 18 (100%+)
Originally Posted by sb7979 View Post
Did you have the "hex" inserts snapped in all the way?
Not sure on what hex your talking about. I did about 6 times take it back apart to make sure the diff pins were seated properly and every time they were.
It all spins freely until I tighten it down I can see the "lower" spider gear (I think it's called) and all 4 spider gears on the pins all spin nicely, but once I tighten down the screws it gets very clicky and hard to to turn.
Pretty sure I'm doing everything right as the front and rear are extremely smooth and I only had to put those together once to get them that way.
Update: I took it apart 2 more times and cleaned and reassembled and still getting the same results...guess I'll go get another gasket tomorrow and try it with 2 gaskets...
teknic is offline
Old 01-13-2012, 05:49 PM
  #27557
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Originally Posted by RC*PHREAK View Post
i've also had zero issues in my SCTE with that servo and an RX8.
ChrisAttebery is offline
Old 01-13-2012, 06:15 PM
  #27558
BmainStar's Avatar
Originally Posted by 65BAJA View Post
I was making a list of spares I would like to have for the SCTE to throw in the tool box and the $ amount crept up pretty fast. This raised a question. How many of you guys who race on a regular basis just buy a whole nother kit as "spare parts"?
That was kinda the deal when parts were not available before.If your local track carries parts don't stock anything! I am serious! This is the most Stout R/C race vehicle I have ever driven or owned!!!End of Feb I will have been racing this truck for one year I have only broken a few rear bumpers and the front bumper mount! No arms,hubs,spindles ETC....Get the Losi carbon towers and go race!!!!!!If I had to carry something I would at least grab the front and rear drive line shafts that go to the center diff!Cheers!!
BmainStar is offline
Old 01-13-2012, 06:48 PM
  #27559
viciousone's Avatar
Default Balancing tires
Just wanted to check to see how many of you are balancing your tires and which balancer you have been using...
viciousone is offline
Old 01-13-2012, 06:52 PM
  #27560
Trader Rating: 28 (100%+)
So I just got my scte and was putting it together tonight and got to the servo. The stock servo horn is way to big for my servo (hpi sf 32tt). Are there other servo horns that come in the kit that im not seeing?
TDI793 is offline
Old 01-13-2012, 06:57 PM
  #27561
You have to use the little inserts. They're on a "tree" and are yellow/white in color.
http://www.amainhobbies.com/product_...kage-Set-Ten-T
If you look at the picture in this link they are in the upper right.
teknic is offline
Old 01-13-2012, 07:02 PM
  #27562
Thank you!
TDI793 is offline
Old 01-13-2012, 07:28 PM
  #27563
10sctrel0v3r's Avatar
so i was just about to grab a set of the updated center drive line shafts with the set screw in it and i started looking at the rebuild kits and found out that you can just buy the updated rebuild kits and put the new updated guts inside your old shafts. i paid no more then $6 for the rebuild and now i dont have to worry about that pin flying out.
10sctrel0v3r is offline
Old 01-13-2012, 07:31 PM
  #27564
Factory Seal's Avatar
Trader Rating: 29 (100%+)
O.k. fellas im confused.....im building the back end of the truck and looking at my inserts...i have #0,1,5...so how do i get to 3 degrees of antisquat?...
Thanks,Donnie.
Factory Seal is offline
Old 01-13-2012, 07:32 PM
  #27565
Thank you!
You might want to look into an aluminum arm for that servo. I had my plastic multi servo arm on and the first day it skipped multiple times so i had to re center it. Once i put an aluminum arm on the servo I havnt had one problem.
naterpatater77 is offline
Old 01-13-2012, 07:37 PM
  #27566
Pvd brett's Avatar
im not balancing, ive run some pretty unbalanced tires before with no probs. ive run them back to back unbalanced and then balanced with no differences. It not like a truggy where balancing is neccessary
Pvd brett is offline
Old 01-13-2012, 07:46 PM
  #27567
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Thanks,Donnie.
I am pretty sure if you use number 0 inserts at all corners it will give you 3 degree toe and 3 degree anti squat .
BashemSmashem is offline
Old 01-13-2012, 07:50 PM
  #27568
namewasdallas's Avatar
Thanks,Donnie.
I never understood this part either or what exactly they did, I just put in the 0's all the way around.
namewasdallas is offline
Old 01-13-2012, 07:58 PM
  #27569
hello,
was just wondering if the team epic monster horsepower 3.5t with rx8
would be to much or would have heat issues?
thanx in advance
cuppcake80 is offline
Old 01-13-2012, 08:12 PM
  #27570
Originally Posted by cuppcake80 View Post
hello,
thanx in advance
Not gonna work and will cook itself quickly .
