its too bad you cant get the tekin pro4 4600kv in a motor/esc combo.
so the tekin pro4 4600kv motor with the tekin rx8 esc would toss my losi ten t around like a rag doll if i go with that setup? also will the tekin pro4 4600kv motor bolt up to the motor mount that i bought.
won't have the low end rip of a decent set up on 3s (like the castle 1415), but yes, it will mount right up to the stock losi mount.
Alvin,
My truck jsut seems like it lacks traction in the rear. Unless I am smooth on throttle the back end kicks out or it just smokes the tires. I've watched the others in my class an they seem to be able to throw their trucks around without losing control. I'm ran Panther Raptor SS tires this weekend on both of my trucks. My 2wd was the most hooked up it has ever been since I bought it. The 4wd was traction rolling earlier in the day. I lowered it to 25mm and it was powersliding around corners and seemed really loose.
I swapped the SC4X 4.5 with a HT rotor for a Pro4 4000k this week. It seems smoother so I'm hoping that will cure most of the problem. I'd still like to smooth out the handling though. I'm thinking moving the weight back will give the truck more rear traction and maybe make it a little more stable overall.
I looked at your setup sheet and I am really close to your setup. I'm using 3 degrees antisquat, outside-outside all shocks, heavy sway bar front and soft rear.
Thanks,
Chris
Thanks,
Chris
those motors have a ton of rip.....you wont be able to get the new 4 poles for a few weeks...all the rest are in stock...
Wait for the 4 pole 5mm shaft.....
how hot?
i talked to Billy today at Trinity....he said he is waiting on the shipment of 5mm shafts.......might be worth the wait though!...i have the 7200kv on order!...
how hot?
Alvin,
Thanks,
Chris
Thanks,
Chris
Give it a try and let me know what you think
Hey guys,
Last saturday race night I was having problems with traction rolling and the car felt really "twitchy" I race at hot rod hobbies and was wondering if any of the setup sheets losi has on their website would be a good setup for a track like that (medium size, outdoor, 1/8th and 1/10th, technical) Also, I just replaced the balls and rod ends and the front ends still feels pretty sloppy, but it feels like its coming from the steering rack, any ideas?
Any recommendations on a body that is a little thicker and more durable than the stock one?
This truck is awesome! I raced it for the first time this past Sunday stock out of the box settings and it finished 2nd in a 10 minute Amain even with my erratic driving.
Just because you have a ton of power,doesnt mean you can use all of it......but,Its "Nice "to know you have some rip in reserve!.................................Especiall y for tha striaght's!
I really like the Associated 1015 servo. I've got several of these now. Its got a lifetime warranty. I had one die and sent in, no questions asked I had a new one about a week and a half later.
R/C Tech Elite Member
Here's the Trick...
Alvin,
Thanks,
Chris
Thanks,
Chris
Hey Chris I have been battling rear traction for weeks now I was about ready to throw my truck in the trash today just so frustrated. I ran my truck all stock except diffs I had setup 5-7-3 and the truck worked great I thought it could be better so when I bought my Bump chassis I went through and lightened alot of parts as well as changed to a pro4 motor and changed my setup completly. After all the changes I tryed it out and it was terrible and I have been battling it ever sence I had tryed every setup possible and my rear end was just loose I could drive it but man what a pain. Tonight I realized the one difference I was forgeting from back when I was happy with the truck, the rear sway bar when it was stock I did the diffs and removed the rear sway bar and when I made all the changes I went thick front sway and thin rear but that was still too much no sway is the way to go for rear traction, it is crazy how much better it handles much less slide out entering corners.
Hey guys,
Jconceprs bodys
The Jconcepts body are much thicker and to me stronger thanthe Proline. Check out the New Chev. body or any Hiflow! Goodluck!
I really like the proline flo-tek body.. good lookin style..
Alvin,
Thanks,
Chris
Thanks,
Chris
