Like Tree9Likes
Old 01-09-2012, 07:28 PM
  #27316
Trader Rating: 38 (100%+)
Does anyone know of a shock rebuild kit for the SCTE shocks that don't include all the extra parts I don't need? I would like just the o-rings. I thought there was another brand of o-ring that would work, but I can't remember who makes them, not losi.
mattnin is offline
Old 01-09-2012, 07:31 PM
  #27317
Dano628's Avatar
Originally Posted by adubaz7 View Post
Here is the video not the best quality done on a Phone but good enough to see the track.
His truck handles very well it is all stock with Fantom 4.5 it is easy to drive and sticks well to the track but I cannot run his truck as fast as mine best lap with his is a 25.8 and with mine I have gotten a 24.9 but it is on the edge alot more so I am trying to keep the speed mind is capable of with the stability of stock I have noticed that setup at full weight is not the same as setup on a light weight truck like mine.
http://www.youtube.com/watch?v=P_pAe...ature=youtu.be
Nice looking track !
Dano628 is offline
Old 01-09-2012, 07:38 PM
  #27318
[QUOTE=adubaz7;10147249]
Hey guys I am looking for some help with my setup please give as many setup changes as possible to fix my problem.
Problem is on my track we have two straights both with a high speed corner at the end they are short but fast sections my issue is that when I let of the throttle to setup for the corner the rear of the truck washes out/over steers I have tried all I can to keep this from happening and I am at a loss please give me some ideas
Put the battery as far forward as it will go, it will really help on fast off power sweepers.
Jedev is offline
Old 01-09-2012, 07:48 PM
  #27319
Trader Rating: 46 (100%+)
does anybody know of a metric screw conversion for this car? I only ask because every other car I have is metric and it would be nice to have everything I own be metric...if not I'll have to order some more standard tools
anybody?
NitroLuver is offline
Old 01-09-2012, 08:24 PM
  #27320
darryl80's Avatar
Trader Rating: 24 (100%+)
i am looking to put the motor/esc from a hpi savage flux hpi in my losi ten t i am converting to brushless. will that motor bolt up to the motor mount for the losi ten scte?
darryl80 is offline
Old 01-09-2012, 08:25 PM
  #27321
Default Brand new Kit, loose front end and...
I just bought a new RTR SCTE and love it.
There is one complaint right from the box is that is the loose rod ends on the balls. It looks like this is not un-common. What are you recommendation to take all that play out? my plan so far it to order the HA balls and new rod ends.
I race on a indoor clay track, what would you folks change about the stock config? the plan so far is to order up some MC tires and hit the track to see how it runs. I've been reading about the removing the grease from the diffs, what are you putting back in it?
jketron is offline
Old 01-09-2012, 08:30 PM
  #27322
namewasdallas's Avatar
Originally Posted by cuppcake80 View Post
does anyone run the trinity monster horsepower 4.5,do u like it?
when is the rev tek suppost to come out?
thanx
I think you can order the RevTech 4x12 on there website I seen it listed for ordering.
namewasdallas is offline
Old 01-09-2012, 08:31 PM
  #27323
What do you mean by loose like falling out of the rod end? they are suppose to have some movement to them.
Old 01-09-2012, 08:32 PM
  #27324
elex300's Avatar
Trader Rating: 106 (100%+)
I ran front 5k,center 5k,rear 3k diff fluid in mine and it was great. The box setup is great but Dakotahs set up on the Losi site was better. The only thing I changed was moving the front camber link to the top position. It gave me alot more steering there.
elex300 is offline
Old 01-09-2012, 08:54 PM
  #27325
Factory Seal's Avatar
Trader Rating: 29 (100%+)
thanx
those motors have a ton of rip.....you wont be able to get the new 4 poles for a few weeks...all the rest are in stock...
Originally Posted by lowroad View Post
I run the 5.5 and it's crazy insane. 4.5 would be more so. Maybe someday.
Wait for the 4 pole 5mm shaft.....
Originally Posted by Mitten View Post
I run the 4.5, with a LRP Sphere TC, 12t pinion. Gets a little on the hot side after our 8 min. mains. But other than that, no complaints.
how hot?
Originally Posted by Nitewolftracing View Post
I'm looking at trying to get the Revtech 4800kv 4pole am currently in florida and a hobby shop here said they could order one for me and have it in in a few days I'm waiting for them to call me back to make sure its the 5mm shaft not 1/8" shaft if not that I'm gonna run the tekin pro4 4600kv
i talked to Billy today at Trinity....he said he is waiting on the shipment of 5mm shafts.......might be worth the wait though!...i have the 7200kv on order!...
Factory Seal is offline
Old 01-09-2012, 08:55 PM
  #27326
The front end has several mm of play that if you hold one tire and gently move the other tire. I can see the play in the rod ends to the balls.
jketron is offline
Old 01-09-2012, 09:49 PM
  #27327
darryl80's Avatar
good thing about the tork 2200kv setup that comes in the hpi forza flux hp and hpi savage flux hp i would beable to run a pair of 3s lipo batteries in my losi if i went with that setup. plus i am looking alot of insane torque and power. so let me know what you guys think of that setup in a losi ten t truggy.
darryl80 is offline
Old 01-09-2012, 10:07 PM
  #27328
Trader Rating: 75 (100%+)
total over kill, might as well use a 4cell
Chase1472 is offline
Old 01-09-2012, 10:10 PM
  #27329
Trader Rating: 31 (100%+)
[QUOTE=XXXDad;10147838]
Put 3/3/1...... in the difs..... you will not be sorry.... and check your center dif for the outdrive rubbing. Try it you'll like it!
Shocks:
Front> New Black spring #3 piston 32.5 W
Rear> New Orange Spring #4 piston 30 W
Run 27 mm Ride hight
2* camber front and back
Make sure no drag brake.
Sounds like an interesting setup I may give it a try after some testing tomorrow what track do you run at I would like to compare it to the tracks I run at if you have a video I would love to see it, also I asume the oil weights listed are with cut bladders correct?
adubaz7 is offline
Old 01-09-2012, 10:19 PM
  #27330
darryl80's Avatar
what motor/esc would you recemmend to me the smallest lipo i will go is 3s.
darryl80 is offline
