Is there any " how to " links about maintenance and mods on this truck in a RTR version ? Any secrets to keeping the shock sock from slipping off ?
I fixed the broken rear drive shaft and back and running. Things a blast to drive
Anyone else been using these Lipos in thier SCTE? Any Problems with them or am I the only one?
Two minutes into the first heat of the Day. Battery is only 6-8 cycles old. Thank God the closest Marshall knew what he was doing and saved my Car.
I read a lot of bad things about them lately!!!
ok wth are you guy doing to these orion packs?
i got 8 of them now i bought more just because your having issue and i have not a one
I bought 2 to try them out. Luckily no damage from the one that went poof.
Ran the other with no problems for the rest of the day.
Once they wear to a point they dont seem to contaminate anymore. I mean u can use new shims everytime u refill w oil but the u will have the same problem everytime u take them back apart. I dont see a way around this issue really
i am looking for a good pair of 2s lipo batteries for my truggy what should i get?
I was just hoping there was an alternative out there.
That seems to be the issue. I had to reuse mine due to the fact my LHS did not have any in stock. When I opened my center diff up, the clear fluid that I put in was a grey ,thick gooey mess. I'm guessing it was due to metal shavings.
Replace the shims every time is the only alternative ive managed to find. The Shims Will wear away to NOTHING if you leave them long enough.
