Like Tree9Likes
Old 01-02-2012, 08:13 AM
  #26866
Trader Rating: 43 (100%+)
Originally Posted by lowroad View Post
I just got mine saturday (two days ago), so i would think he is all stocked up. Completely worth the wait if not
This will be my forth bce chassis and if i have to wait i will not be happy.
crazysavage is offline
Old 01-02-2012, 08:20 AM
  #26867
lowroad's Avatar
Trader Rating: 79 (100%+)
Well, i gess you could pm him through here or email through the website to check.? He is NITROALM on here.
lowroad is offline
Old 01-02-2012, 09:14 AM
  #26868
Trader Rating: 18 (100%+)
How are you guys attaching your ESC's in your trucks? I have 3 options Standard Servo Tape, Velcro or I also have some of that Kyosho Servo tape that's really thick and squishy.
Just looking for some opinions.
Also, I asked a few pages back and didn't get a response, but what length sensor wires are you guys running? I'm planning on having my solder posts facing the rear of the truck and my Tenshock SC411 motor doesn't come with a sensor wire so I need to pick one up.
teknic is offline
Old 01-02-2012, 11:11 AM
  #26869
myl3s91's Avatar
Well today i ordered my bce chassis! When i switch out the chassis i also want to switch out the grease to oil in my diffs. Running indoor for the winter on carpet, what would be my best bet for diff oils? Also what is working the best as to gluing the diff hex inserts to prevent leaking??
myl3s91 is offline
Old 01-02-2012, 11:14 AM
  #26870
I use 3m double sided tape but for your options that you gave, I would use the Kyosho tape. I wouldn't use Velcro but that's just me. As far as the sensor wire I use the write that came with my Pro4. I can measure is I guess if you want me to.
LosiMadMan is offline
Old 01-02-2012, 11:32 AM
  #26871
cwilkinson's Avatar
Are the diff gear set part # LOSB3569 the new updated ones at amainhobbies yet anybody have some luck?? Or should I order from horizon to be safe?
cwilkinson is offline
Old 01-02-2012, 11:50 AM
  #26872
Trader Rating: 33 (100%+)
Originally Posted by Factory Seal View Post
From this first picture...there is a noticeable gap difference on the bumper...looks twisted......which makes alot look twisted...i thought the right shock was bent....like i stated it could be the angle of the picture....It looks alot better in the Stock trim......if you have a hard impact.....chances are you could have bent something else.......me personally.... i would have to look at everything back there.....but im anal about my stuff.
Im with you.. it looks like the lock nut in the upper right of the tower.. on the inside is angled weird.. but.. hard to tell..
dgrobe2112 is offline
Old 01-02-2012, 11:56 AM
  #26873
ok.. so.. anyone out there.. have any opinion on the losi 22 shock pistons?? guy at the shop is saying he thinks they are better than the ones for the truck.. i only noticed that they are skinnier..
what do you guys reccommend?
I am also trying to get some more low speed steering in the truck.. its super dialed in the high speed sweepers.. but just cant get around the slow sections very well..
i am running the 3/3/2 diff setup.. as well as gold springs in the front.. stock in the rear.. stock sway bars.. and i think the truhe setup..
Got the TLR tuning kit as well..
thanks guys.
Old 01-02-2012, 12:00 PM
  #26874
Casper's Avatar
Trader Rating: 34 (100%+)
thanks guys.
I would recommend the upgrade spring kits. The springs help a lot. For more turn in try moving the bottom of the front shocks in a hole on the arm.
Casper is offline
Old 01-02-2012, 12:11 PM
  #26875
Grandturk's Avatar
thanks guys.
If your track doesn't have a lot of high speed corners, ditch the front swaybar. I dropped mine off for a track that had a ton of 180 turns and it made a world of difference.
Grandturk is offline
Old 01-02-2012, 12:35 PM
  #26876
It would be nice if my iPhone didn't load all the setup sheets blank.
Old 01-02-2012, 01:10 PM
  #26877
Thats what i was thinking.. that may be the first thing i do..
Old 01-02-2012, 02:11 PM
  #26878
Default Tire Compound Question
I bought some Jconcepts Rebars for my build. I thought that I was getting the medium compound rebars, but I accidentally ordered the super softs. The track that I will be running at is maintained as a smooth blue groove surface. Will these super soft rebars be good for that type of surface, or should I get some harder tires?
oldschoolnewb is offline
Old 01-02-2012, 02:14 PM
  #26879
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Better to have too much traction instead of not enough. They'll probably be worn down by the end of the race but that's racing.
JEFFs SC10 is offline
Old 01-02-2012, 02:49 PM
  #26880
Feint Motion's Avatar
Trader Rating: 24 (96%+)
picked up a RX8, waiting on my Pro4 4600kv to arrive! cant wait!
Feint Motion is offline
