Like Tree9Likes
Old 01-01-2012, 04:31 PM
  #26821
Nitewolftracing's Avatar
Originally Posted by Ridley View Post
40C is plenty adequate if it's a true 40C A 40C/5000mah should be good for 200 amps.
Hopefully a Venom 40C 5000mah roar approved hard case one is really a 40C lol otherwise I dont have real batteries and will find out quick lol
Nitewolftracing is offline
Old 01-01-2012, 04:37 PM
  #26822
Originally Posted by Packfan View Post
The guy that is usually up front and wins runs Gens Ace 40C 5000mah packs and has no problems.
X2 I have some and no problems so far with this or my nano-tech 6000
dany5 is offline
Old 01-01-2012, 04:44 PM
  #26823
Can someone tell me how the stock medium springs compare to the spring kit .
dany5 is offline
Old 01-01-2012, 05:08 PM
  #26824
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
The new springs are really nice compared to the stock ones. The new ones have a more progressive action to them compared to the old ones. Also the new springs allow you to lower the rear of the truck unlike the stock springs.
I recommend using them.
kjohnsiii is offline
Old 01-01-2012, 05:18 PM
  #26825
Trader Rating: 22 (100%+)
Where can I find the ratings for the new springs?
Honu is offline
Old 01-01-2012, 05:34 PM
  #26826
Trader Rating: 18 (100%+)
I am new to 4/4 SCTE racing and wondering which discharge rate lipo I should use. We have an 80 x 40 track, I will be racing larger tracks this summer. I have a GTB2 with a 5.5, 550 can motor. I have heard different recommendations on which c rating lipo's to use. Most that I have are 40c. I am being told to run a higher "C" rating in the 4/4 over the 2wd. Thanks
Due to waiting on my nano-techs from China I was running my Havoc Pro / 4.5 combo on a Punch RC 5400 35C pack and it did fine. There are quite a few guys running the 5000mAh 40C Gens Ace at my track and they do well also.
teknic is offline
Old 01-01-2012, 05:36 PM
  #26827
Feint Motion's Avatar
Trader Rating: 24 (96%+)
I'm going to be getting a tekin rx8 w/ the pro4 4600kv this week. 1st sensored system, will I be disappointed?
Feint Motion is offline
Old 01-01-2012, 05:45 PM
  #26828
dfsc10's Avatar
im taking the front diff apart and putting oil in it for the first time, i cleaned all the grease out and put 5k diff fluid in it and putting it back together and when i spin the diff its gritty and dosnt feel right and when i put it in the truck when i turn the wheels it feels like its grinding 1/4 way in the turn of the wheels. ive only done the front diff so far and its done right any of you guys have this problem or is it normal?
dfsc10 is offline
Old 01-01-2012, 05:46 PM
  #26829
I have the kit, just wanna to know we're the stock ones fall compare to the kit ones . Are the stock ones stronger or softer. Thank
dany5 is offline
Old 01-01-2012, 05:47 PM
  #26830
10sctrel0v3r's Avatar
nooo
10sctrel0v3r is offline
Old 01-01-2012, 05:51 PM
  #26831
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Rears
2.7 rate Red springs
3.0 rate Orange springs
3.3 rate Silver springs
3.6 rate Green springs
Fronts
3.9 rate Blue springs
4.2 rate Black springs
4.5 rate Purple springs
Factory Seal is offline
Old 01-01-2012, 05:54 PM
  #26832
Originally Posted by Factory Seal View Post
Rears
Fronts
Lol you beat me to it .
dany5 is offline
Old 01-01-2012, 05:58 PM
  #26833
Well not to shabby since i didnt even know we were 'Racing'.......
I'm to used to hearing....Less than five!......Boop!
Old 01-01-2012, 06:06 PM
  #26834
[QUOTE=Factory Seal;10109521]Well not to shabby since i didnt even know we were 'Racing'.......
My transponder is always on. Lol
dany5 is offline
Old 01-01-2012, 06:09 PM
  #26835
Trader Rating: 31 (100%+)
I have read similar posts many times now and it seems like everyone says it is assembled correct but what is the problem and then responses come up suggesting two paper gaskets this makes no sense to me I may be wrong but if the diff was smooth before the diff came apart why would more gap be needed when reasembled. I have rebuilt many diffs on 1/8th scales and several times on my SCTE and also other short course 4x4s and I have ran into similar issue where I pull it apart and clean out old oil/grease then rebuild with new oil and sometimes it seems very tight sometimes it does not spin so I know I made an error so I pull it apart and first make sure the cross pins are both seated flat to flat if that is correct then I know the crown gear on the bottom of the diff case or the crown gear on the top/cover outdrive side is not pushed on far enough I pull the crown gear off clean all the oil under make sure the pin is center and push the gear back on and ones it is lined up I push very hard some diffs even require taking a socket and smacking a couple times to seat it all the way in. After doing these things I have always had smooth diffs and have never ran two gaskets and I rave built 100 plus diffs and my diffs on my scte at least 5 times each.
I am not trying to call any one out here just giving my experience with these issues.
I hope this helps some
adubaz7 is offline
