Like Tree9Likes
Old 12-24-2011, 09:03 PM
  #26386
krash'um's Avatar
Originally Posted by A929ryda View Post
I run the RX8 with tekin 4600. Geared 40/15 initially the motor came off the track really hot to the touch it puffed my pro match lipos. Picked up the FTW fan kit. The thing pushes tons of air. Now, with same gearing motor is cool to the touch after a pack ( nanotech). The RX8 runs cooler. Current limiter at 80%
Would you have the part number for the FTW fan kit? I'd like to try that out. Thanks.
krash'um is offline
Old 12-24-2011, 09:28 PM
  #26387
netmaster's Avatar
Originally Posted by oldschoolnewb View Post
Has anyone tried out the Dakotah Phend diff fluid set up. On the set up sheet is says he ran...
7 5 3
I just finished building mine and I have put in the 5 5 3 set up as a base line. I figured I would try that for a practice day, and then try out 5 7 3.
I run 7 5 3 and it works well for me. I like the stability it gives going into turns and how when coming out of the turn it makes the front pull harder, fits my driving style. Here is a video of my truck running those diff weights.
I'm the all black truck. I end up third behind Hupo and Kinwald.
http://www.youtube.com/watch?v=Hp3MdHaaNaY
netmaster is offline
Old 12-24-2011, 09:30 PM
  #26388
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by lowroad View Post
couple shots of the king headz sleeves:
I'm extremely happy with the fit and finish of these pieces.
Mine came today. They're black instead of chrome.......weak.
Yes I know they'll work the same, but it's not whats pictured on their website and they don't hold the same bling value (I figure those boots won't last long and I'm not going to replace them).
RC*PHREAK is offline
Old 12-25-2011, 12:57 AM
  #26389
Brushless420's Avatar
Trader Rating: 176 (100%+)
I hear ya! Same thing happened to me. Ordered them up and was disappointed to see them black. That natural finish would have looked good with my BCE chassis.
Brushless420 is offline
Old 12-25-2011, 05:12 AM
  #26390
Trader Rating: 17 (100%+)
Originally Posted by harleyhoots View Post
I'm installing the TLR kit in my truck. One of the shock collars are very hard to put on. I actually have to use pliers to get it on its so hard. Is there any reason for this. Also when I put the hinge pins through the aluminum hubs they are tight. Is there any way to ream these other than drilling them? I bought the truck used so I am going through it. I changed the diff fluid in it. It still had the original grease. I noticed that the diff pins had grooves in them from the sun gears, are peas replacing these with the Chris pin set ups?
Thanks Brad
If the collar is that tight then you have cross threaded it and have probably ruined the body or collar or both. You should never need a set of pliers to adjust the collars. The o-ring makes them a little tight but if you take the o-rings off the collar should thread on and off with ease as long as your threads are cleaned out of dirt. When I did mine I had to use an xacto knife to clean out the threads to get the collars to go on properly.
mavrick0 is offline
Old 12-25-2011, 07:16 AM
  #26391
chucko's Avatar
are they painted or what.. some pictures would be nice.> Thanks
I was thinking about getting them just for the bling factor but now for get it.
Happy holidays to all.. get a pro match battery you wont have to wait for that slow boat from china...
chucko is offline
Old 12-25-2011, 07:26 AM
  #26392
lowroad's Avatar
Trader Rating: 79 (100%+)
contact king headz? that's kinda messed up. Glad I got the ones I wanted.
lowroad is offline
Old 12-25-2011, 07:33 AM
  #26393
Panda-PR's Avatar
http://www.amainhobbies.com/product_...an-Mount-w-Fan
Panda-PR is offline
Old 12-25-2011, 08:30 AM
  #26394
So Santa just dropped off a few SCTE goodies. What springs are people running with the aftermarket spring kit? Also what swaybars? I also got the TLR tune up kit. What pivots/degree are people running?
Jack & Coke is offline
Old 12-25-2011, 08:33 AM
  #26395
Feint Motion's Avatar
Trader Rating: 24 (96%+)
all depends on your local track conditions.
Feint Motion is offline
Old 12-25-2011, 08:44 AM
  #26396
RC*PHREAK's Avatar
if you read the description on the website, it does say they are black anodized, but the picture shows the polished ones. oh well...
  #26397
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up Promatch good stuff
My Nano went bad after one use....... Go Promatch! It's just my recomendation!
XXXDad is offline
Old 12-25-2011, 08:45 AM
  #26398
RC*PHREAK's Avatar
most people will run black fronts and orange rears, 2.0mm bar up front and 1.8mm bar in the rear. most people run stock settings with the adjustable hinge pin holders (0's all around).
Old 12-25-2011, 08:49 AM
  #26399
XXXDad's Avatar
Exclamation Springs and tuning kit
Black spring front Orange rear. Make sure you pre thred the Alu. caps on and off a few times they go on realllll tight the first few times. The pivot's run all '0's in Front and in Rear 0 in the back and 1 up in the front of rear pivot.
Have fun !
XXXDad is offline
Old 12-25-2011, 08:51 AM
  #26400
scracer68's Avatar
I bought 4 promatch 6000mah packs and 3 of of them puffed the first week of use.
scracer68 is offline
