Like Tree9Likes
Old 03-09-2011, 06:26 PM
  #2626
gotaslash4x4's Avatar
Location: In a barn, in a field, in the country, just north of nowhere
Default You guys are teasing the cra p outa me
Won't get my new truck in the garage till Monday. keep posting the set up help. Seems like I'll have to change nothing.
gotaslash4x4 is offline
Old 03-09-2011, 06:53 PM
  #2627
drs92's Avatar
Trader Rating: 44 (100%+)
Any hyper boys that jumped to the losi? This truck is very tempting but I drove the hyper and fell in love...Wondering if anyone ran both Will a sidewinder sct 3800kv 4 pole be enough in the truck?
drs92 is offline
Old 03-09-2011, 06:54 PM
  #2628
is anyone having trouble with the pinion lining up with the spur?
my pinion has a little big of a longer neck on it so it is only engaging the front half of the spur towards the front of the truck.
just wondering if anyone else has seen this...not sure which make of pinion it is...i got it with the electronics in a trade.
thanks.
skyler hays is offline
Old 03-09-2011, 07:06 PM
  #2629
anyone thinking about a chassis wrap/protector for this beast? I'm waiting for my esc and motor to get delivered and started to think there must be something to put on the bottom to protect it. I know Upgrade RC has some body wraps, but did not see anything for the chassis of this truck.
ohiorck is offline
Old 03-09-2011, 07:24 PM
  #2630
Cult Racing's Avatar
Trader Rating: 42 (100%+)
I put the team associated protective sheet on mine here:
Cult Racing is offline
Old 03-09-2011, 07:28 PM
  #2631
Jpm1's Avatar
Whilst were on the subject of protection does anyone make an overtray for this truck yet to stop some of the mud?
Jpm1 is offline
Old 03-09-2011, 07:30 PM
  #2632
Trader Rating: 31 (100%+)
Default 8ight titanium turnbuckles
I ordered the 8ight titanium turnbuckles and 4mm ends for the truck...to make a long story short, the ends only fit the rear long turnbuckles. I just realized this is the set i bought and it says for the 8ight:
2 - 4mm x 60mm Titanium Turnbuckles (Steering)
2 - 5mm x 60mm Titanium Turnbuckles (Front Camber)
2 - 5mm x 70mm Titanium Turnbuckles (Rear Camber)
I guess i need some 5mm ends as well...anyone know what length i need to buy?
flysullivan is offline
Old 03-09-2011, 07:41 PM
  #2633
SaladFork's Avatar
thanks.
Hotbodies pinions work the best IMO... the AE ones I tried are to long. The Ofna ones also are a little long but do mesh, but if you are anal about meshing 100% get the HB's.
SaladFork is offline
Old 03-09-2011, 07:44 PM
  #2634
BmainStar's Avatar
Originally Posted by SEF View Post
Here's the vid of my Losi SCTE at Revelation Raceway. I took a box stock truck, filled the diffs with 442 and used Casey's setup. Had the Slash and Jammin, and this was the best truck out of the box There's a few changes I want to make to plant the rear end a little more, but overall amazing truck.
On this track, I was using a 2650 motor on 3s geared with a 16 tooth pinion. This setup works great on large tracks, but is too on/off, and I would prefer a 4.5 on 2s for smaller tracks. Had way too much fun
http://www.youtube.com/watch?v=ccgFQaty0IM
Great vid, Thanx for sharing,new layout seems a bit more Short Truck friendly ,may have to go out to Rev wit the Losi and give it a spin!
BmainStar is offline
Old 03-09-2011, 07:46 PM
  #2635
Trader Rating: 90 (100%+)
thanks.
I'm using a Novak pinion/Ballistic 4.5. My solution was to dremell the top of the set screw down so it would go forther down the hole and then dremel a groove in the motor mount for my hex wrench so I can tighten the set screw as low as possible. A ball wrench would mork but I don't think you could get enough torque on it. I now have 100% contact with the spur.
b121774 is offline
Old 03-09-2011, 07:52 PM
  #2636
BashemSmashem's Avatar
Castle pinions are a perfect fit and work great .
BashemSmashem is offline
Old 03-09-2011, 08:01 PM
  #2637
Default HELP!!!
Old 03-09-2011, 08:04 PM
  #2638
drs92's Avatar
What type of gearing should I go with on a small indoor track with the sidewinder sct 3800kv combo
drs92 is offline
Old 03-09-2011, 08:38 PM
  #2639
SaladFork's Avatar
14T-16T
Old 03-09-2011, 08:39 PM
  #2640
ae-Dan's Avatar
Trader Rating: 39 (100%+)
anyone know what the stock shock set up is (oil wt. and springs and pistions)???? thanks
ae-Dan is offline
