Like Tree9Likes
Old 12-20-2011, 10:30 AM
  #26161
lowroad's Avatar
Trader Rating: 79 (100%+)
get the durango nuts. 4mm, serrated, black, and CHEAP.
about $2 for ten pretty much everywhere.
http://www.amainhobbies.com/product_...ock-Nut-Set-10
lowroad is offline
Old 12-20-2011, 11:13 AM
  #26162
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Got a pack of those on their way in the order I just placed ... looked like a good deal.
Littlejohn Dsgn is offline
Old 12-20-2011, 11:27 AM
  #26163
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Ridley View Post
Normal, yes, as they all do it stock. Designed that way, prolly not as it's only detrimental...just sloppy manufacturing tolerances. The HD units are the lightweight and hardened units linked below. They have a slightly larger shaft and reduce most of the wobble. They also last FAR longer than the stockers. One of the MUst BUY mods IMHO. They also make them for the front and rear, I'd buy all 3 sets if I was you as all 3 wobble, it's just easiest to see in the center diff.
The play is rarely in the holder, but if yours is loose around the bearing, I'd just use a stocker to replace it. I don't have much good to say about STRC, and once the center diff doesn't vibrate all around, the stock plastic support is just fine.
http://www.amainhobbies.com/product_...Outdrive-Set-2
The stock losi diff holder gets pretty hot during a race, goes through allot of heat cycles. The aluminum one is better.
kjohnsiii is offline
Old 12-20-2011, 11:31 AM
  #26164
Trader Rating: 35 (100%+)
Those are a good deal for flanged locknuts, but they aren't serrated. I continued to have issues with wheel nuts loosening until I got the ones that are serrated to dig into the wheel a bit.
kazuaki is offline
Old 12-20-2011, 12:00 PM
  #26165
Integra's Avatar
Imo there's no need for an Aluminum Holder.
Integra is offline
Old 12-20-2011, 12:18 PM
  #26166
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
You can always serrate them yourself with a dremel cut wheel
BDRMBULLY is offline
Old 12-20-2011, 12:36 PM
  #26167
Panda-PR's Avatar
This ones:
Haven't lost one!
Panda-PR is offline
Old 12-20-2011, 12:37 PM
  #26168
Ridley's Avatar
Same here
All the aluminum does is wear and make another sloppy bearing location. The plastic keeps the bearing firmly in place, and last, well, a long time as I have over a year on mine and it's going strong
Ridley is offline
Old 12-20-2011, 01:29 PM
  #26169
Originally Posted by 10sctrel0v3r View Post
yours have cracked too?!?! damn i thought i was the only one. i have way more less race days on mine then you do and they have the same kind of cracks your describing. might have to get ahold of jc concepts and get a refund or new wheels
I had 3 out of the 4 wheels do this on my truck and contacted JC and sent the pictures and supposed to have a new set coming to me. just wish the tires on them werent a wash
black05stxjt is offline
Old 12-20-2011, 01:33 PM
  #26170
R/C Tech Elite Member
JayL's Avatar
I have had better luck with the Losi Serrated Wheels nuts.
http://www.amainhobbies.com/product_...ut-Set-6-Black
I have tried both sets of the Durango ones and lost a nut during Qual's.
The stock HPI Blitz ones are my second choice, the flange is too big for some wheels.
I would like to try the M2C Steel serrated ones
JayL is offline
Old 12-20-2011, 01:53 PM
  #26171
Registered User
Trader Rating: 25 (100%+)
Get the Pro-line ProTrac wheels, trimming on webbing on front wheels and never look back.
http://prolineracing.com/wheels/prot...-piece-wheels/
RustyRC is offline
Old 12-20-2011, 01:58 PM
  #26172
BradS's Avatar
Default Screws?
What is the size of the screws that go into the diff cases from bottom through the chassis? Can't seem to find these on exploded view.
BradS is offline
Old 12-20-2011, 02:08 PM
  #26173
Stock is 8-32 x 3/8", but I have changed mine to 8-32 x 1/2" because the short ones don't seem to seat as far into the diff housing as they should.
kazuaki is offline
Old 12-20-2011, 02:56 PM
  #26174
lowroad's Avatar
uh, they are. I have them on the scte right now.
lowroad is offline
Old 12-20-2011, 02:58 PM
  #26175
lowroad's Avatar
Originally Posted by Panda-PR View Post
Ah yes, those ones. Still $2 for ten, still flanged AND serrated, and those are what I have . I knew I wasn't crazy, just posted the wrong link.
lowroad is offline
