Like Tree9Likes
Old 12-19-2011, 01:06 PM
  #26116
Originally Posted by spider882009
Dear LOSI,
Thank You for sending me a new body!!!
Chad
Glad you got it ok and I appreciate you letting me know about this issue. We are working to resolve it 100%.
hacker07 is offline
Old 12-19-2011, 01:27 PM
  #26117
rchoi's Avatar
Originally Posted by Casper
That is normal.
wow...good to hear this is normal but
i never had a car that have wobble diff cups, how do they do that??
rchoi is offline
Old 12-19-2011, 01:29 PM
  #26118
Casper's Avatar
Trader Rating: 34 (100%+)
Other then people noticing it and complaining they wobble, nothing else has come from it. No extra wear or performance issues etc. Really kind of one of those, if it ain't broken don't fix it. I have not looked into the wiggle enough to know exactly where it is coming from so not sure. It does not seem to be a problem at all though.
Casper is offline
Old 12-19-2011, 01:46 PM
  #26119
rchoi's Avatar
you say so i feel comfortable now
rchoi is offline
Old 12-19-2011, 02:07 PM
  #26120
Ridley's Avatar
My center diff out drive cups wobbles...should i replace the bearing?
or is this normal play?
They always do that. It's because of poor fitment between the outdrives and steel inserts in the diff cups. If you replace the outdrives with the HD units, before you wear the inserts out, it will eliminate most of the play.
The only downfall to the wobble really, besides noise and vibration, is it will eventually lead to the diff leaking due to the o-rings wearing out prematurely.
Ridley is offline
Old 12-19-2011, 02:12 PM
  #26121
Trader Rating: 22 (100%+)
anyone have the part # for the diff o rings?
Honu is offline
Old 12-19-2011, 02:20 PM
  #26122
R/C Tech Elite Member
JayL's Avatar
Originally Posted by porkchop
ok guys these black rims are killing me
is there a yellow rim that fit the scte besides the de ones
why don't you like the DE ones?
I am trying to choose my rims and need some reasons
JayL is offline
Old 12-19-2011, 02:40 PM
  #26123
Ridley's Avatar
The DE ones are CRAZY flexible!! But, they are also crazy light as well.
Ridley is offline
Old 12-19-2011, 03:27 PM
  #26124
goehm's Avatar
Trader Rating: 45 (100%+)
I have mostly DE and like them, but as others have pointed out they're flexible and tend to not run very true. I gave the ProLine ProTrac's a shot this past weekend and I like them a lot.
I read that you have to trim the inside ribs for the fronts or else they'll rub - though I have yet to do that. Amain has a video that you can view that details this, it's embedded in the product page on their site.
goehm is offline
Old 12-19-2011, 03:46 PM
  #26125
JayL's Avatar
I have the DE in my right hand and a JC in my left, sqeeeze, switch hands, sqeeze, have friend try,
they seem to have very similar amount of pressure required to flex. I wonder if one "returns" straight better
they are ugly but the stock AE sc10 4x4 rims fit no rubbing
JayL is offline
Old 12-19-2011, 05:08 PM
  #26126
yfzracer912's Avatar
I am running the Aaron Lane Setup on a tight indoor dirt track and its working fairly well except for the fact that the rear end tries to pass the front end once in a while. I am running 5-5-3 and was wondering what changes I could do to help fix this. I went from 2.5 toe in the rear to 4 toe and it seemed to help a bit. If I went to 7k in the center diff would that help the front end pull more? Or should I play with my rear shocks?
yfzracer912 is offline
Old 12-19-2011, 05:35 PM
  #26127
Trader Rating: 18 (100%+)
I'm pretty new to setups / tuning so sorry for all the dumb questions, but on the Phend and Lane setups it says to run the rear camber link in the 2-B locations. Currently my truck is 2-A (stock), if I move my link to the B location will I need to adjust the length of the links (I'm assuming so)? Just want to be sure because currently I have a camber gauge so I'll just leave it where they're at until I get one if that's the case.
Also, I switched my rear shocks over to the Phend setup with 32.5, emulsion, 27mm ride height, etc and it seems like the truck wants to bottom out a lot...is this normal?
teknic is offline
Old 12-19-2011, 06:26 PM
  #26128
Casper's Avatar
Are you running the new springs?
Did you set the ride height. Actually I think going thicker in the center will make that worse.
Bottoming out is not bad unless it bounces. Tuning the shocks stiff enough to not bottom out will really effect the handling in the bumps and turns in a negative way. IF you move the camber link to a new hole you have to reset the camber to 1-2 deg.
Casper is offline
Old 12-19-2011, 06:48 PM
  #26129
hello,
what does someone think about putting the pro4 4600 on my havoc prosc?
will it be as fast as with an rx8?
will i have heat issues ext.?
thanx in advance!
cuppcake80 is offline
Old 12-19-2011, 06:49 PM
  #26130
10sctrel0v3r's Avatar
u-joints
10sctrel0v3r is offline
