I heard this is as close as you can get to the grease from Losi.
http://www.amainhobbies.com/product_...artDiff-Grease
Personally i think all the aftermarket chassis are better than the stock chassis. They each have their own flex characteristics but i think the biggest difference between all of them is the color! Just pick your favorite color and go width that chassis, bce for raw aluminum, jammin for black, bump for grey, tlr for green, and snr for carbon fiber. I'm pretty sure all of the above listed chassis can also be tuned with different rear braces as well. Basically don't think u can go wrong with any of them...but for the record I love my bce!
is anyone testing or planning setup with tenshock 5200kv 4pole motor?
please share the results~
Can someone please explain the adjustable hinge pin set up for front and rear
... the instructions make no sense as to which insert to use to have 3 degrees of toe or any other setting. It gives you an insert number, hole location and angle of 12, 11, 10, 9 and 8. How does the angle number given relate to degrees of offset. I guess you are supposed to just know this stuff, but I am really confused and these instructions in my opinion are horrible!! any help would be greatly appreciated...
That is the exact diff grease from inside the diffs and its LOSB3590.
The numbers you are giving is the front and 0's from and rear would give you 10, you can then go up by 2 degrees and down by 2 degrees by changing the inserts out.
The rear have some that go vertical, the front and some that go horizontal, the rear. The front adjust anti-squat, the rear adjusts toe.
The SC411's, and SC401's are both great motors. Our race group just ordered up 10 of the new SC411's
The Viper VX4 motors are awesome as well!
can we please talk about the chassis some more
