i have ran the 4000 on what i think is small indoor track and it just did not have the motor i wanted. 4600 all the way hell if they made a 5000 i take it
What springs are everyone using? I just switched back from my 1/8th scale shocks, and need more cushion than the stock black ones. Also anyone have input on emulsion style shocks? Are they worth the hassle?
Get the new spring kits. They are much better then the stock "ten" springs. Emulsion are well worth it.
what grease or oil do people use to redo wheel bearings and such,
also im running the novak sc system from my jammin fer now but my batt. packs seem to swell a little.any info would be muc appreciated
I seen this image here on this forum and I tried to PM the person that had this SCT but no reply.
Anyone know where you get these CV boots?
Sorry for dumb questions but i have a 8 year old who will be running a points series coming up this next year i am getting him a losi scte he currently runs only 2wd shortcourse but others all in his class will run 4x4 so figured i better get him one what are things i need to purchase for this rig to make it bomb proof also i do not run sc 4x4 so dont know whats the ticket for motpr speedo combo i know while back evrybody was running the rx8 speedo is that the way to go or will say a mmp sc combo wprk
They are for the Traxxas MT's.
Revo, E-Revo.
Don't bother, boots are too big for the SCTE
Revo, E-Revo.
I have a couple 3s Turnigy 25-30c and they swell up when i was doing speed runs in my mmp/3800 setup in a stadium truck.
Try the Turnigy Nano-Tech 6000mah 65c-130 Lipos from hobbyking thats what alot of people run that dont want to spend a arm and leg on Lipos. I own one and its great.
KingsHead has what you want...aluminum pin holder and CV boots for the ten scte...$17.99 for 2 w boots...replacement boots pk of 4 $5.99.....
the new nano-tech's are much nicer than the older hard cased turnigy's. I have been backordered on the 6a 65-130's for a while. i have a few 50-100c 5.6A, so for now they are good. CHEAP CHEAP ppl. good to go.
I just bought a used SCTE and am trying to put the Phend ROAR nats setup on it. When he lists the shock length is that measuring from the top of the shock to the center of the eyelet? Or is it to the bottom of the eyelet?
Any changes suggested for a tight indoor track?
Whats the min lipo mah and current rating is required for this truck ? I know at my track at least people run 2s lipos.
And i know this is a heavy sc does that affect turning much ?
Like for instance like the stock setup ?
