Like Tree9Likes
Old 12-12-2011, 02:02 PM
  #25696
Originally Posted by vasidudu View Post
Hi all,
Do anyone know the max size for pinion with stock motor mount?
I am running a 19T and would like to try and see if 20T makes such a big difference. Though it looks like I do not have much room to run a 20T...
Have a MMP 2400 Kv with 2s.
Prior to going to 3s (and go down a couple of Tsss...), I would like to see if 20T suits me.
Thx for the feedback.
Best,
V
20T is the highest you can go with the stock mount.
hacker07 is offline
Old 12-12-2011, 02:23 PM
  #25697
dtr
dtr's Avatar
Originally Posted by teknic View Post
Be aware that the stock black springs are different form the blacks in the new shock kit, team setup sheets usually refer to the kit springs.
dtr is offline
Old 12-12-2011, 02:30 PM
  #25698
Default sway bar kit sizes
I have put the thickest sway bar on the front like on the losi set up sheets. The set up sheets for the rear say to use the 1.8mm bar. There are three bars in the sway bar kit. Is the 1.8mm bar the smallest one or the middle sized one?
oldschoolnewb is offline
Old 12-12-2011, 03:09 PM
  #25699
porkchop's Avatar
we just talked about this last night lol
the big black front bar
and the smallest black rear bar will give you what you want
porkchop is offline
Old 12-12-2011, 04:07 PM
  #25700
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Speaking of shock springs.......i bought the kits and they are color coded.....so,on the factory setup sheets like Lanes......
It states..... Fronts Black(new spring)...They are all black?....Rear Orange(new spring)...New orange colored or the marked ones i have?
so is there a newer set than i purchased 5 weeks ago?......
Thank's!
Factory Seal is offline
Old 12-12-2011, 04:08 PM
  #25701
vasidudu's Avatar
thank you sir,
V
vasidudu is offline
Old 12-12-2011, 04:24 PM
  #25702
dtr
dtr's Avatar
Thank's!
There has not been any mention of newr spring kits, and considering how long ago those setups were posted, they must refer to the colour coded black spings you have.
dtr is offline
Old 12-12-2011, 05:41 PM
  #25703
thank's.......
Old 12-12-2011, 06:02 PM
  #25704
ae-Dan's Avatar
Trader Rating: 39 (100%+)
is the stock body 0.030 or 0.040 thick??
ae-Dan is offline
Old 12-12-2011, 06:32 PM
  #25705
goose ae's Avatar
Trader Rating: 19 (100%+)
Do I need a castle link to program the rtr speed controller or can it be done another way.
goose ae is offline
Old 12-12-2011, 06:48 PM
  #25706
Panda-PR's Avatar
There's the castle link program card. You'll be able to do some changes at the track with it but its not as accurate as going in with the field link on a pc but it works ok
Panda-PR is offline
Old 12-12-2011, 06:53 PM
  #25707
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by nitro0619 View Post
Are u running ur shocks w/ bladders or emulsion style w/ the m2c pistons?
Emulsion.
rcgod is offline
Old 12-12-2011, 07:57 PM
  #25708
Trader Rating: 31 (100%+)
Guys that run there shocks with no bladders what is the advantage to this also is there a disavantage to no bladders also is there o-rings needed if the bladders are not used?
adubaz7 is offline
Old 12-12-2011, 08:25 PM
  #25709
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
watch this video!!
KIK is offline
Old 12-12-2011, 10:18 PM
  #25710
eddomak's Avatar
Just a quick note on this, I think the above post got product names the wrong way around (in case someone needs to do the right searches etc).
The castle-link is the straight USB interface (computer required).
The field-link is the program card interface (computer optional).
The program card also doubles as a castle-link as it has a mini-USB port that you can plug your computer into for some more fine-grained control, so there is no need to buy both.
I bought the program card and use it for some general changes trackside, but also use my PC to program it and save some profiles.
eddomak is offline
