Like Tree9Likes
Old 12-11-2011, 02:27 AM
  #25591
roblupo's Avatar
I am getting into SCT due to it being so big at my track right now, i got the AE truck but i saw a guy at my track with the new Losi truck and he has never looked good racing but was flat out flying with this truck. So I am thinking I want to send the AE back and get this truck. I already see there is a ton of hop ups for it, is there anything that is a must have right away? I noticed on the toe blocks on this guys at the track the plastic was already pulling out or flexing, so that seems pretty much a must there. Thanks for any info.
roblupo is offline
Old 12-11-2011, 03:09 AM
  #25592
gtsakiris's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Josey Wales View Post
I HAVE A HYPERION EOSO606I CHARGER AND IT HAS A FUNCTION CALLED LIPO DISCHARGE HAS ANYONE EXPERIMENTED OR USED THIS FUNCTION ON ANY OF YOUR CHARGERS REGARDLESS OF BRAND. I AM CURIOUS TO WHY I WOULD NEED TO DISCHARGE MY LIPOS. I NORMALLY USE THE STORE MODE WHEN I PLAN ON STORING MY LIPOS FOR SEVERAL WEEKS AT A TIME. DO YOU GAIN ANY PERFORMANCE ADVANTAGE BY DISCHARGING YOUR LIPOS AND THEN CHARGING TO FULL CAPACITY? ALSO IT SEEMS AS THOUGH THIS CHARGER BALANCES THE CELLS WHILE ALSO DISCHARGING AT THE SAME TIME?
The discharge function can be used mainly for cycling packs when new. Most lipos dont hit their stride until 10th cycle. Sometimes you need to discharge the pack down.
gtsakiris is offline
Old 12-11-2011, 06:19 AM
  #25593
What type of batt connectors is everyone using?
Ec4? Deans? I emagine ec5 is to big?
c.rod is offline
Old 12-11-2011, 06:39 AM
  #25594
mjealey's Avatar
You will want to use dean's. One, they are very efficient. Two, 85% of people use deans so if you ever need one to re-solder at track or use somebody else's battery in an emergency situation you are good to go.
mjealey is offline
Old 12-11-2011, 06:42 AM
  #25595
Trader Rating: 18 (100%+)
+1
teknic is offline
Old 12-11-2011, 06:48 AM
  #25596
I've got ec5's on another truck but that's a different story. I thought the ec5 were the most efficient connector u could use, if u had to use a connector?
But I didn't know if the ec5 was overkill and maybe the ec4 would be better?
c.rod is offline
Old 12-11-2011, 06:50 AM
  #25597
blktransam's Avatar
Trader Rating: 59 (100%+)
ran a few packs through my scte yesturday dialing in my BCE chassis and man am I loving this truck lol so easy to drive its not even funny! gonna be a good year in 2012 I know that much.
blktransam is offline
Old 12-11-2011, 06:58 AM
  #25598
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
You can never have too big of a connector IMO , the EC5 connector is the perfect choice IMO as these heavier cars can pull a lot of juice . If space under the body were a concern then a smaller connector might be needed but there is plenty of room under an SCT's shell .
BashemSmashem is offline
Old 12-11-2011, 08:48 AM
  #25599
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I've been running solid bullets straight to the battery.
DO NOT use the cheap bullets on these trucks though. They don't hold their spring tension for long and then they will cause problems.
ChrisAttebery is offline
Old 12-11-2011, 09:09 AM
  #25600
chucko's Avatar
I got this bad boy down to 5 pounds with everything. IS THAT GOOD ? EC5's on the plug unless you plugging your wires to the battery like mine.. The BEC chassis is the ticket for those that like great flex and longevity. bill has added a screw hole to the bottom for long or short brace bars. the associated buggy brace is a direct bolt on. with only a slight grinding next to the transfer case to fit the hole..
chucko is offline
Old 12-11-2011, 09:17 AM
  #25601
omenwolf's Avatar
Trader Rating: 37 (100%+)
The new hard ball kit is very nice to have in the kit to get that new tight feel back. Since the ball kit didnt come with the steering ones I got the HD 8 steering arm and its the same sixe as the stock one Losa6045 is the #. I also got rid of the blue shock bodies and put on losis new bodies.
omenwolf is offline
Old 12-11-2011, 09:34 AM
  #25602
dtr
dtr's Avatar
4mm solid connectors direct to the batteries, no intermediate connectors.
dtr is offline
Old 12-11-2011, 10:05 AM
  #25603
Stuntbikemike's Avatar
Originally Posted by Mototech View Post
What has everybody been using for center diff shims? I've searched and found the question asked but not answered. I know you can get it with the Ten-T spur but it seems like a waste to spend $5.00 for one shim and a spur you can't use. Spent half an hour at the LHS and couldn't find anything there either.
Any info on this would help. I had the same issue. I just spent the five.
Stuntbikemike is offline
Old 12-11-2011, 10:14 AM
  #25604
Default ten scte
i just bought it last night it will be a week befor i get to see it probly, any how i was wanting to know how that stock esc and motor hold up i cant seem to find any one really talking about it
I bought the rtr off of stormer hobbies for only $449
YardRacer is offline
Old 12-11-2011, 10:43 AM
  #25605
so which tekin motor is everyone pushing these days?
ive kinda decided on the rx8 esc....
just up in the air about motors...
c.rod is offline
