Like Tree9Likes
Old 12-08-2011, 08:46 AM
  #25456
Registered User
Trader Rating: 25 (100%+)
Originally Posted by LosiMadMan View Post
Ok trying to decide what motor. I'm going to be racing on a small indoor track, and I mean small. I want to get a pro4 ad I don't know what version The 4000, 4600, or The 3300. I was leaning towards the 4600 but I'm not sure why because I'm not clear on the differences in the kv.
4000.
RustyRC is offline
Old 12-08-2011, 08:49 AM
  #25457
Roger's Avatar
Originally Posted by RustyRC View Post
4000.
Roger is offline
Old 12-08-2011, 09:38 AM
  #25458
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Roger,
I've been running my TEN/SCTE mount for close to a year without any problems. I would use a 5-40 cap head screw with a thick washer to make sure it doesn't move though.
Chris
Originally Posted by Roger View Post
Hello everyone. Has anybody ever heard of the motor mount made from eliterc ??? Heard many stories from various racers at my local track ( NorCal Hobbies ) about the stock motor mount bending fairly easily. All of them said to upgrade the motor mount if I can. Alot of them recommended the motor mount made from elite rc. Here's the website:
www.elitercd.com
Anybody have an experience with these motor mounts ? Thanks for your help.
ChrisAttebery is offline
Old 12-08-2011, 09:52 AM
  #25459
Roger's Avatar
Originally Posted by ChrisAttebery View Post
Roger,
Chris
Thanks brotha Chris. I should have my car ready this weekend or the beginning of next week. I'll take pics of it when im done. After being out of the racing scene for 3 years, I totally forgot how fun it is.
Roger is offline
Old 12-08-2011, 03:03 PM
  #25460
elex300's Avatar
Trader Rating: 106 (100%+)
How often should I change the seals in the diff? Been running my kit 6 nights a month for 3 months. I change the fluids every 3 weeks in fact I just did it a week ago and noticed some leaking in the center between the outdrive and the bearing. Also how soon before doing a total diff rebuild (Gears and all)?
elex300 is offline
Old 12-08-2011, 03:53 PM
  #25461
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Originally Posted by elex300 View Post
Can anyone point me in the right direction for stopping the droop screws from eating my chassis?
There are a few ways...the best and easiest is to drill and tap the arms for bigger droop set screws...4-40x4mm..See page #1 for this info...
Factory Seal is offline
Old 12-08-2011, 04:36 PM
  #25462
10sctrel0v3r's Avatar
not the arms but the chassis
10sctrel0v3r is offline
Old 12-08-2011, 04:46 PM
  #25463
Registered User
Do you mean that part B3542 with nut looking piece? Tap it out and replace it.
http://www.amainhobbies.com/product_...Hardware-Ten-T
RustyRC is offline
Old 12-08-2011, 04:50 PM
  #25464
elex300's Avatar
No,the clear orings.
elex300 is offline
Old 12-08-2011, 05:01 PM
  #25465
so,you drill and tap the CHASSIS and put in a set screw for the arm to ride on??.......
glad i bought the BCE........
Old 12-08-2011, 05:12 PM
  #25466
Will it be sufficient if I decide to go to a larger track evey once in a while? Can you give me a quick run down of the difference in the kv. This is my first experiance with brushless tech.
LosiMadMan is offline
Old 12-08-2011, 05:13 PM
  #25467
Registered User
O rings comes with kit.
RustyRC is offline
Old 12-08-2011, 05:43 PM
  #25468
goehm's Avatar
Trader Rating: 45 (100%+)
Yea. The idea is to let the screw rest on something other than the chassis. That said, aren't most running full droop (limited by shock) now anyway? So the easiest way is to turn each counter clockwise until they fall out (or at least not touch the chassis).
goehm is offline
Old 12-08-2011, 05:52 PM
  #25469
thats what i have seen....i just started working on mine....in that case i guess no screws required if you are not over extending the shock shaft to the point of breakage....inside or out....i wouldnt assume that the shock travel could act as your droop limiter.....still must be using the screws a bit....
Old 12-08-2011, 07:10 PM
  #25470
porkchop's Avatar
ok i have the carbon towers on my truck is there something i can use for shock mounts beside the stock ones and not have to drill my towers
porkchop is offline
