Like Tree9Likes
Old 12-08-2011, 07:02 AM
  #25441
chucko's Avatar
so sorry !!!!!!I have looked at 500 pages trying to find the part number to run the long brace rod on the BCE chassie,, can someone post the part number for me please Thanks
chucko is offline
Old 12-08-2011, 07:13 AM
  #25442
Integra's Avatar
Originally Posted by Roger View Post
Hello everyone. Has anybody ever heard of the motor mount made from eliterc ??? Heard many stories from various racers at my local track ( NorCal Hobbies ) about the stock motor mount bending fairly easily. All of them said to upgrade the motor mount if I can. Alot of them recommended the motor mount made from elite rc. Here's the website:
www.elitercd.com
Anybody have an experience with these motor mounts ? Thanks for your help.
Last time i checked He was going out of business....So if you want a Elite mount, I would act fast.
Integra is offline
Old 12-08-2011, 07:16 AM
  #25443
Panda-PR's Avatar
Default Servo voltage
Haven't found an answer but just in case:
Is there a way to increase the voltage from the bec (on an rx8 or external bec on a mmp/mmm) that goes to the servo? I understand it drops the voltage to 6v but I have a HV servo and wouldn't hurt using that extra torque/speed.
Panda-PR is offline
Old 12-08-2011, 07:36 AM
  #25444
Grandturk's Avatar
Originally Posted by Lucid View Post
yep
on big air i stay wide open on the throttle till i reach the peak of the jump. then i tap the brakes to level it out if i need to
It's going to vary on setup, motor and brake settings, but I try to keep on power right to the top of the jump and just barely tap the brakes to downside if I can. Even at lowered brake strength, too much brake will nose my truck down and lawn dart. Other than that, my truck jumps pretty level.
I do have a bad habit of getting back on the throttle a little too early, but I've also found that ballooning the tires helps absorb the big jumps as well.
Grandturk is offline
Old 12-08-2011, 07:41 AM
  #25445
Trader Rating: 19 (95%+)
I don’t recall any way of increasing the output on an RX8. On the MMP you definitely can change the output of the BEC with the castle link software. Also you can hook up the external BEC from castle to the same castle link and adjust that as well for those who have them. I have never owned an MMM so I can’t answer that, though I suspect it is the same.
Also the RTR ESC has that option as well, being an MMP rebadge.
RedDevil13 is offline
Old 12-08-2011, 08:03 AM
  #25446
Integra's Avatar
Originally Posted by RedDevil13 View Post
I donít recall any way of increasing the output on an RX8. On the MMP you definitely can change the output of the BEC with the castle link software. Also you can hook up the external BEC from castle to the same castle link and adjust that as well for those who have them. I have never owned an MMM so I canít answer that, though I suspect it is the same.
Randy @ Tekin has a Diagram of how to get 7.4 to your Rx, BUT you have to be running a 2x 2S set-up like the dingo and Snake.
Integra is offline
Old 12-08-2011, 08:11 AM
  #25447
rcgod's Avatar
Trader Rating: 32 (100%+)
If you have a hv servo and receiver that can handle the voltage you can run direct off of the battery or balance plug to receiver and disconnect the red wire from the esc to receiver.
rcgod is offline
Old 12-08-2011, 08:23 AM
  #25448
Ok trying to decide what motor. I'm going to be racing on a small indoor track, and I mean small. I want to get a pro4 ad I don't know what version The 4000, 4600, or The 3300. I was leaning towards the 4600 but I'm not sure why because I'm not clear on the differences in the kv.
LosiMadMan is offline
Old 12-08-2011, 08:24 AM
  #25449
elex300's Avatar
Trader Rating: 106 (100%+)
Can anyone point me in the right direction for stopping the droop screws from eating my chassis?
elex300 is offline
Old 12-08-2011, 08:28 AM
  #25450
rchoi's Avatar
MMP you can chang it up to 7v
MMM 5.5 fixed (not sure about 5.5 but its below 6v and its fixed)
if you are running 3Cell you sould get external bec to bump up the voltage.
but if you are mainly with 2C then you will not benifit that much from your hv servo and you also need to adjust your driving style along with your 2 cell voltage drop/usage...maybe you will benifit hv servo if you set voltage cut off at 3.7v per cell.
since this is scte thread and many people run 2cell mainly. i would personally get something that performs best at 6v.
rchoi is offline
Old 12-08-2011, 08:34 AM
  #25451
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Hmmmmm havent heard of this before ? Do tell !
BashemSmashem is offline
Old 12-08-2011, 08:35 AM
  #25452
Panda-PR's Avatar
Thanks! Being a newb to electric I went and bought that hv servo and now realized that it wasn't needed. Its only giving around 120oz so I'm looking for around 170oz and lower than .15sec
Panda-PR is offline
Old 12-08-2011, 08:36 AM
  #25453
Roger's Avatar
Thanks Integra. I'll purchase one of them today at my LHS.
Roger is offline
Old 12-08-2011, 08:38 AM
  #25454
chucko's Avatar
I used 10/32 X 1/2 buten head screws. ground a grove in the end and grinded the head round and replaced the droup screw.. thats one way hope this helps
chucko is offline
Old 12-08-2011, 08:41 AM
  #25455
rchoi's Avatar
wow~ i wanna see 2x 2c setup~!!!!! are they running 14v? or 10k mah
thanks
remy
rchoi is offline
