Like Tree9Likes
Old 12-07-2011, 10:25 AM
  #25396
Originally Posted by cavg
Going up in front should make it turn less.
Try 5 7 3, and make the front shocks a little bit more vertical.
I went to that from 5 5 3. turns quicker, and best of all, more onpower steering in those low speed 180 corners. The rear does get a good bit looser so have to adjust throttle for that.
Thanks, I'll try that tonight. I hope between that and the tires, i should be dialed in.
shark2288 is offline
Old 12-07-2011, 10:45 AM
  #25397
Toiffel's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Grandturk
I am, BBQ
I've been running a 12T at Critters and 14T during the summer at CRC - big 8th scale track. Temps are low 120 at most on motor with 12T. I think I may have been as high as 180 with the 14T outdoors in the summer.
Thank you sir, I will pass the information to a couple of friends !!
Toiffel is offline
Old 12-07-2011, 11:16 AM
  #25398
Originally Posted by RC*PHREAK
if it's a small track, i'd start with a 15 tooth pinion.
hop ups/spares: the TLR tuning kit is nice and has most of the hop ups you'd want to do other than the HD outdrives and spring kits. you can wait a bit on those until your stock outdrives start to wear. i'd get the spring kits right away. for spares, i bought a bunch of spares (like arms, spindles, carriers, etc) but have never used any of them. the only parts i've replaced have been the front center driveshaft, rear bumper, pivot balls, and steering rack. the truck is very durable and i don't think you need to keep a bunch of spares around unless it's going to take a long time to get parts.
i think the stock rims are the best ones out for the truck. i'd just get those.
i'd get a decent set of hex drive wrenches like these: http://www.amainhobbies.com/product_...h-Set-US-Sizes
i think the most common issue you would see with the new trucks (that have updated diff pins) will be the front center driveshaft coupler. make sure you keep that coupler well greased which is supposed to help.
your english is fine!
Originally Posted by Casper
Your english is way better then a lot of poeple on here!
I would get the TLR tuned kit as it has a lot of great parts for tuning and added strength for a great price.
Other things that don't come in the tuned kit are the spring kits really help with performance.
Lightened outdrives are nice as they are stronger and lighter. (replace when stock ones wear out!)
Shock piston sets for tuning.
I would say those are the high points for upgrades.
Then you can look at an upgrade chassis that will be stronger and lighter.
Thanks for the help
Cesar676 is offline
Old 12-07-2011, 11:19 AM
  #25399
wcrase101's Avatar
Originally Posted by porkchop
so when losi going to release a yellow rim this black is getting old.
and no i dont want the de rims they got more flex in them then a gymnist
I would love to see white rims!!!!!!!
wcrase101 is offline
Old 12-07-2011, 11:21 AM
  #25400
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I'd recommend a 15 or 16T pinion with that motor. It will have all the power you can handle in the infield even when geared at 16/40.
Originally Posted by Cesar676
I'm selling my Slash 4x4 and I'm going to buy a Losi SCTe...
- What pinion I need to run with that motor? *The track isn't big*
ChrisAttebery is offline
Old 12-07-2011, 11:23 AM
  #25401
Good to know. Thanks Ryan.
Originally Posted by hacker07
I ran the esc at 100% with the motor geared at an 18 on 2s and had very good lap times and in 110 degree weather, the motor never got over 185. So, in normal temps and given its a 4 pol which are usually safe up to about 200, you could gear it up but it would be stupid fast at that point. As for the castle link...yep.
Old 12-07-2011, 01:19 PM
  #25402
Registered User
Trader Rating: 25 (100%+)
Default Yellow and White rims
http://www.amainhobbies.com/product_...ow-2-2WD-Slash
http://www.amainhobbies.com/product_...te-2-2WD-Slash
remove the webs to prevent them from rubbing at FULL STEERING LOCK on the front wheels only.
RustyRC is offline
Old 12-07-2011, 01:37 PM
  #25403
cavg's Avatar
NOTE: These wheels are compatible with the Losi TEN-SCTE, but minor trimming of the inner support webs will be required to prevent rubbing.
I think we need pictures of this trimming.
cavg is offline
Old 12-07-2011, 02:48 PM
  #25404
Registered User
http://www.youtube.com/watch?feature...v=O6Kg7W0rzZI#!
RustyRC is offline
Old 12-07-2011, 03:01 PM
  #25405
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
There you go
What a waste of time that was. He meant the webs on the inside of the rims not the wheel wells
BDRMBULLY is offline
  #25406
Trader Rating: 18 (100%+)
Originally Posted by Toiffel
Anyone running a Havoc Pro and 4.5 Ballistic?? What gearing is being used ??
Thanks!
I run this combo, but I have the older 4.5 HV model motor. I think they're pretty much the same though as far as gearing. I run a 14t right now and my motor/esc both temp at around 140 degrees after a 7 minute run. I'm going to try a 15t and see how that does. Just got the truck so haven't had much time to mess around with it.
I did read that if you have the High Torque version of the motor with the longer rotor most people seem to run 16t.
teknic is offline
Old 12-07-2011, 03:25 PM
  #25407
Lucid's Avatar
keep in mind, this rotor is no longer made anymore and drops the KV rating of the 4.5 5000kv down to about 3800kv
so when you gear up to the 16t and high torque you dont actually gain any speed, and maybe minimal torque
I ran a GTB2 4.5 geared at 13t all summer on a 1/8 scale track and did well with it
Lucid is offline
Old 12-07-2011, 03:26 PM
  #25408
Actually with the HT rotor you can run up to a 19T pinion.
Old 12-07-2011, 04:19 PM
  #25409
Registered User
minor grinding the webs to prevent them from rubbing at FULL STEERING LOCK on the front wheels only.
RustyRC is offline
Old 12-07-2011, 04:22 PM
  #25410
Trader Rating: 35 (100%+)
In looking at the diagrams in the manual, I see that there is supposed to be a shim on the center diff between the spur gear and the rear bearing. It is labelled as B3570 in the attached image. I don't have this on mine. I'm not sure if it was never there, or if I lost it while doing a teardown. Regardless, is this an important piece? Do you guys use it?
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-shim.jpg
kazuaki is offline
