Like Tree9Likes
Old 12-07-2011, 08:20 AM
  #25381
dtr
dtr's Avatar
Originally Posted by RedDevil13
Has it ever been confirmed who the manufacturer is for the RTR ESC? there were rumblings about it being a MMP rebadge...?
This post by Ryan could be regarded a confirmation:
Originally Posted by hacker07
That depends on what you want to shell out for electronics. If you are willing to shell out 3-400 for an RX8/pro 4 right off the bat, then the RTR is not for you. If you were thinking more along the lines of a castle system or Viper copperhead system, then the RTR is perfect and then some for you. The ESC is basically a MMpro and the motor is a 4 pole 2800kv 550 motor and is a monster.
dtr is offline
Old 12-07-2011, 08:23 AM
  #25382
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Originally Posted by xxfile
Cant find this on horizons site only on losi's site
+1 Have checked a few sites and no one has them listed yet
Littlejohn Dsgn is offline
Old 12-07-2011, 08:28 AM
  #25383
Asharus's Avatar
Trader Rating: 42 (100%+)
hobby fever has them in stock
Asharus is offline
Old 12-07-2011, 08:40 AM
  #25384
Trader Rating: 19 (95%+)
thanks, I thought there was a post somewhere like that, but I couldnt find it.
RedDevil13 is offline
Old 12-07-2011, 09:02 AM
  #25385
cavg's Avatar
Originally Posted by shark2288
I was running 5-5-3 in my setup and when i throttle it coming out of a turn the front end would push pretty bad. I'm now running 7-5-3 and that it seems a lot better, but when braking into the corner now my front ends wants to push. I can't seem to get both to work at the same time. I'm running black spring in the front, orange in the rear. 32.5 shock weight frt and rear. Emulsion style, 3 piston in the frt and 4 in the rear. 2.0 sway bar frt and 1.8 rear. Its indoor clay , tight and pretty smooth. I'm running super soft megabites. I have barcode greens coming tomorrow and i'm hoping that does it. I moved the battery forward also. I'm trying to get this thing to turn as quick as possible. Anyone have any suggestions? I had someone else drive the car and he had the same problem while braking into a corner.
Going up in front should make it turn less.
Try 5 7 3, and make the front shocks a little bit more vertical.
I went to that from 5 5 3. turns quicker, and best of all, more onpower steering in those low speed 180 corners. The rear does get a good bit looser so have to adjust throttle for that.
cavg is offline
Old 12-07-2011, 09:06 AM
  #25386
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Hey Ryan,
I let my 8yo son drive my SCTE in the novice class a couple weeks ago. He has been driving a SC10 with a 17.5 for about a year and just didn't seem to get the hang of it. The only thing I did to detune the SCTE was turn the throttle EPA down to 65%(~25mph). He we out and won his second heat with it. So, I bought him a RTR for Christmas.
Now for the questions: Will Castle Link work with this ESC? Can the motor and ESC handle taller gearing (on 2s) when he is ready for more speed?
Thanks,
Chris
ChrisAttebery is offline
Old 12-07-2011, 09:09 AM
  #25387
I'm selling my Slash 4x4 and I'm going to buy a Losi SCTe
I wat to get the Losi SCTe + Bump Chassis http://www.nitrohouse.com/p24372/Los...duct_info.html
The electronic will be:
ESC: HobbyWing Xerun SCT Pro
Motor: Tenshock SC411 4000kv
Servo: Savox 1256TG
Radio: FS-GT3B (I already have one)
There are some questions:
- What pinion I need to run with that motor? *The track isn't big*
- What are the must have hop-ups and spares?
- Which wheels: JC Rulux or DE Racing or Stock Wheels? *I've seen that most people prefer the Rulux, because the DE Racing wheels are very flexible.*
- Tools needed?
- What are the most common issues?
*Sorry if my english was bad*
Cesar676 is offline
Old 12-07-2011, 09:17 AM
  #25388
Registered User
Trader Rating: 25 (100%+)
Originally Posted by porkchop
so when losi going to release a yellow rim this black is getting old.
and no i dont want the de rims they got more flex in them then a gymnist
Here is Yellow wheels.
http://prolineracing.com/wheels/prot...-piece-wheels/
RustyRC is offline
Old 12-07-2011, 09:32 AM
  #25389
omenwolf's Avatar
Trader Rating: 37 (100%+)
Horizons new site sux, they have tons of stuff you cant find. They are on the horizon dealer site as in stock in cali. I ordered 3 sets of the HA balls and they will be at the shop on Friday.
You want me to hold you a set Scott?
omenwolf is offline
Old 12-07-2011, 09:41 AM
  #25390
That would be great I will be in this weekend or early next week with my wish list Time to gear up for the Cabin Fever race
Old 12-07-2011, 09:44 AM
  #25391
Toiffel's Avatar
Trader Rating: 52 (100%+)
Anyone running a Havoc Pro and 4.5 Ballistic?? What gearing is being used ??
Thanks!
Toiffel is offline
Old 12-07-2011, 09:54 AM
  #25392
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Servo: Savox 1256TG
- Tools needed?
if it's a small track, i'd start with a 15 tooth pinion.
hop ups/spares: the TLR tuning kit is nice and has most of the hop ups you'd want to do other than the HD outdrives and spring kits. you can wait a bit on those until your stock outdrives start to wear. i'd get the spring kits right away. for spares, i bought a bunch of spares (like arms, spindles, carriers, etc) but have never used any of them. the only parts i've replaced have been the front center driveshaft, rear bumper, pivot balls, and steering rack. the truck is very durable and i don't think you need to keep a bunch of spares around unless it's going to take a long time to get parts.
i think the stock rims are the best ones out for the truck. i'd just get those.
i'd get a decent set of hex drive wrenches like these: http://www.amainhobbies.com/product_...h-Set-US-Sizes
i think the most common issue you would see with the new trucks (that have updated diff pins) will be the front center driveshaft coupler. make sure you keep that coupler well greased which is supposed to help.
your english is fine!
RC*PHREAK is offline
Old 12-07-2011, 10:16 AM
  #25393
Grandturk's Avatar
Thanks!
I am, BBQ
I've been running a 12T at Critters and 14T during the summer at CRC - big 8th scale track. Temps are low 120 at most on motor with 12T. I think I may have been as high as 180 with the 14T outdoors in the summer.
Grandturk is offline
Old 12-07-2011, 10:22 AM
  #25394
Originally Posted by ChrisAttebery
Hey Ryan,
Thanks,
Chris
I ran the esc at 100% with the motor geared at an 18 on 2s and had very good lap times and in 110 degree weather, the motor never got over 185. So, in normal temps and given its a 4 pol which are usually safe up to about 200, you could gear it up but it would be stupid fast at that point. As for the castle link...yep.
hacker07 is offline
Old 12-07-2011, 10:23 AM
  #25395
Casper's Avatar
Trader Rating: 34 (100%+)
Servo: Savox 1256TG
- Tools needed?
Your english is way better then a lot of poeple on here!
I would get the TLR tuned kit as it has a lot of great parts for tuning and added strength for a great price.
Other things that don't come in the tuned kit are the spring kits really help with performance.
Lightened outdrives are nice as they are stronger and lighter. (replace when stock ones wear out!)
Shock piston sets for tuning.
I would say those are the high points for upgrades.
Then you can look at an upgrade chassis that will be stronger and lighter.
Casper is offline
