Like Tree9Likes
Old 11-28-2011, 05:44 PM
  #24976
Trader Rating: 22 (100%+)
nope. it's just the way you want it to look.
Honu is offline
Old 11-28-2011, 05:56 PM
  #24977
My scte, rx8 and pro4 are on the truck, prob be here in a few days and I'll probably know more bout how it goes together once i read the manual and look at it all. it looks like you solder your wires to the esc, but i am hoping that i can use some bullet style plugs on the other end possibly? I wanna be able to swap motors. If it doesnt come with something like that, i wanna look in to it. i dont want to have to unsolder.
AgroAMG is offline
Old 11-28-2011, 06:06 PM
  #24978
10sctrel0v3r's Avatar
you will end up soldering wires to your motor. im not to sure if you can run bullets into the esc or not. i read in here somewhere where someone did something with some bullets on the rx8 esc. if i were you i would just use the bullets in the wires.
10sctrel0v3r is offline
Old 11-28-2011, 06:28 PM
  #24979
Ah! That makes sense! Like the slash 4x4, the bullets in the wires. DUH. I'm totally cool with that. I'll do that. It'll all make sense when I get it too... I'll probably head down to my LHS too to discuss stuff before i commit to it all.
AgroAMG is offline
Old 11-28-2011, 06:34 PM
  #24980
namewasdallas's Avatar
solder wires to the motor and have bullets coming off and do the same to the esc, SO U can plug and play with different motors. Just keep the wires short as possible. Long wires are no good at all.
namewasdallas is offline
Old 11-28-2011, 06:43 PM
  #24981
we all have those moments, hopefully they have what you need
Old 11-28-2011, 06:54 PM
  #24982
Josey Wales's Avatar
Talking hot setup
Originally Posted by SoCal Jared View Post
I run the EXACT same setup, less the Savox.
I love the pro4/RX8 combo with my nano techs.
Are you also direct soldering everything? I go straight to the battery with bullet connectors soldered on the ends of each wire. BTW what kv pro4 are you using
Josey Wales is offline
Old 11-28-2011, 07:24 PM
  #24983
Trader Rating: 35 (100%+)
Originally Posted by Speedy S View Post
Getting ready to install new rx8 and tekin motor. Does it matter if the wires run over top of the motor or come behind the motor?
Tekin folks recommend soldering the motor this way:
http://www.rctech.net/forum/electric...ml#post9752429
Apparently this decreases the strain on the motor tabs.
Stanford55 is offline
Old 11-28-2011, 07:38 PM
  #24984
retsoorkcuf's Avatar
Default jammin chassis
Has anyone tried the jammin chassis im up in the air over jammin or bump and honestly i like the jammin cause it comes anodized black
retsoorkcuf is offline
Old 11-28-2011, 09:21 PM
  #24985
myl3s91's Avatar
Hey there, I am thinking of getting the JConcepts Double Dee's mounted on the JConcepts Rulux wheels. Would this be recommended for indoor? What are most racers using as to wheels and tires?
myl3s91 is offline
Old 11-28-2011, 09:37 PM
  #24986
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Your just looking for a DNF because eventually one of them plugs are gna just melt off. Direct solder is the best. Period!!!
If you have the pro 4 why would you wanna swap it to something else anyway?
BDRMBULLY is offline
Old 11-28-2011, 09:49 PM
  #24987
KingdomRacer's Avatar
I agree direct solder is the best, period.
But, In the past I have never had a bullet connection ever melt on me from the esc to motor. When I used to do that type of connection I would only use 6.5mm bullets which maybe gave me different results.
KingdomRacer is offline
Old 11-29-2011, 12:25 AM
  #24988
jconcetps barcodes
indoor clay
Old 11-29-2011, 12:42 AM
  #24989
Default run time
Originally Posted by thecman26 View Post
Dittos here except for the servo.... Great setup!
what are your current run times with the 65c nano's?
and what esc/motor combo ARE YOU RUNNING?
what gearing?
Old 11-29-2011, 12:46 AM
  #24990
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
what gearing?
I have gotten 12 minutes, indoor, HIGH traction, smooth clay, with MMP/Pro4 4000 geared 15/40 (battery took almost 5400 back in, did not hit cutoff yet though!) Will be putting in my RX8 soon though!
thecman26 is offline
