Like Tree9Likes
Old 11-25-2011, 08:47 PM
  #24841
Panda-PR's Avatar
Attention! For those who just bought the pro4 at amain at 156.99!!
Stormer hobbies has them for 114.95!!!
I made a claim to buysafe (you should have received an email from them) hope its get approved and I can get a few bucks back!!
Panda-PR is offline
Old 11-25-2011, 09:13 PM
  #24842
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Your welcome lol
BDRMBULLY is offline
Old 11-25-2011, 09:23 PM
  #24843
cwilkinson's Avatar
What is the buySAFE Lowest Price Guarantee?
If within 30 days of the date you purchase a product guaranteed by buySAFE, you see the exact same product advertised on the same buySAFE merchant's website at a lower published retail price, buySAFE will refund you the difference. It's that simple! Please check the eligibility rules and conditions below before making a claim.
Note: Items purchased through a bundling arrangement, specific promotion, or coupon are not eligible for the Lowest Price Guarantee.
To get paid for the published retail price difference, send your buySAFE guarantee number, your order confirmation email and a proof of the lower price advertised on the website, and buySAFE will send you a check for the price difference (See more details for claim process below). Some terms and conditions apply, see below.
I don't think this is a retail store price match scheme, they're probably gonna shoot ya down That is a real bummer hope it works out for you!
cwilkinson is offline
Old 11-25-2011, 09:29 PM
  #24844
I'm pissed off I just bought a tekin rx8 and pro4 3300kv...Sent an e-mail to stormer. I literally just bought this setup 2 days ago. I hope something can be done because I went with them to order instead of tower. If not that will be my last purchase from stormer, regardless of prices.
FNS156 is offline
Old 11-26-2011, 12:25 AM
  #24845
Suteki's Avatar
Originally Posted by hacker07 View Post
That depends on what you want to shell out for electronics. If you are willing to shell out 3-400 for an RX8/pro 4 right off the bat, then the RTR is not for you. If you were thinking more along the lines of a castle system or Viper copperhead system, then the RTR is perfect and then some for you. The ESC is basically a MMpro and the motor is a 4 pole 2800kv 550 motor and is a monster.
Decided ARR, as I have no problems buying the RX8 / Pro4 if that's going to be the better combo.
My only concern is I mostly have 3S batteries and my understanding is that the motor wouldn't be happy with that. Is there a way to gear for that at all? I'm still confused by the whole kv ratings on motors, my understanding is you want to gear a vehicle for motor temperature and in the end you just end up basically gearing the vehicle to the same sort of specifications and top end due to the motor. What is the difference between the kv systems that being the case?
Suteki is offline
Old 11-26-2011, 03:36 AM
  #24846
Speedy S's Avatar
Trader Rating: 22 (100%+)
Originally Posted by alvinsmith75 View Post
My first shot at freehand airbrushing. My friend rides the Nitrofish Suzuki Pro Stock Bike in the NHRA and he brought me the Nitrofish stickers.
What body is that?
Speedy S is offline
Old 11-26-2011, 05:11 AM
  #24847
rcgod's Avatar
Trader Rating: 32 (100%+)
If you are mostly going to run 3s get the 3300kv motor. That's what it is designed for. You can also run it on 2s with a large pinion (18-20)
rcgod is offline
Old 11-26-2011, 06:44 AM
  #24848
picco007's Avatar
Trader Rating: 98 (100%+)
Originally Posted by cm.stites View Post
if there was alot of traction then you were losing most of the 4wd effect of the truck. i would put 5-3-2 or 5-5-2 to start with.
Can you tell me what going stiffer lube in the diffs and center will do? I felt there was a lot of front traction, the truck felt edgy........
picco007 is offline
Old 11-26-2011, 07:14 AM
  #24849
namewasdallas's Avatar
So I was bored last night and finally got around to taking off all the wires on my truck and upgrading them with the Dean's Wet Noodle Copper wires 12awg. Going to take the truck out today and see if i notice a difference, I think im going to as i took about about 8in. of totoal wire.
Only issue's I had is these are 1600+ strains and they didnt fit the Rx8's bullet tabs like I want. I tryed everything to make them fit like I wanted but i layed them down on top of the posts and there solid.
Uploaded with ImageShack.us
namewasdallas is offline
Old 11-26-2011, 07:29 AM
  #24850
Please let us know how It works for you . Im Very interested .thanks
dany5 is offline
  #24851
Trader Rating: 18 (100%+)
Originally Posted by BDRMBULLY View Post
Heres my hunch. You may have pinched your esc wire under the battery tray????
Im just hoping for the cheapest easiest fix possible for yah lol
Worth a check though!!
Thanks I'll check that out today. I did have a hard time routing the wire from the ESC to the Radio Box as it just barely long enough to reach. I probably need to get one that's a tad longer...With my luck though that's probably not it lol.
teknic is offline
Old 11-26-2011, 07:44 AM
  #24852
thicker fluids in the front and center will make the truck more stable and give it more 4wd effect.
cm.stites is offline
Old 11-26-2011, 07:47 AM
  #24853
for those who may be newer to suspension setup you can always download this and keep it in your tool box http://www.teamxray.com/teamxray/sho...p?file_id=4461
Old 11-26-2011, 08:15 AM
  #24854
i ran 3s 3300kv w 17pinion. on small technical tracks it gets very very hot!
chiatw73 is offline
Old 11-26-2011, 08:20 AM
  #24855
dtr
dtr's Avatar
13 or would be much more appropriate.
dtr is offline
