Like Tree9Likes
Old 11-24-2011, 04:19 PM
  #24781
willbe's Avatar
Originally Posted by rcgod View Post
He came in here looking for advice and I gave it to him. But thanks for the update on his soldering skills. I'll make sure and file that away. Lol.
Sorry rcgod, Didn't mean any offense, just trying to help check one other thing off as people read thru the thread.
I know that he and the kids are at his folks for the holidays.
As he said, nothing changed other than moving everything from vehicle to the scte.
willbe is offline
Old 11-24-2011, 04:21 PM
  #24782
Originally Posted by nitro0619 View Post
Dustin evans latest setup uses 3/3/2 in the diffs. I just changed mine to this from 5/5/3 and the springs he uses also i believe blue front purple rear......not sure how the truck will feel now but will see tomorrow nite. Runnin on hard packed indoors
I have been running this setup on a medium size, medium traction track. It works great as long as you have throttle control. Rotates very good and does exactly what you tell the truck to do.
losi b is offline
Old 11-24-2011, 06:06 PM
  #24783
So I finally broke down and got myself a SCTE. I plan on using my MMP I have sitting around in conjunction with my castle 3800kv 1410 motor (with the 3mm shaft). Two questions:
1. For those of you using the 3800 on this truck, what BRAND of pinion gears are you using? It seems like it needs a shorter pinion and the one I have wont work. The stock 3800 shaft doesnt stick out too bad so i really need a short pinion.
2. on 2s lipo, I plan on running this Hog at WCRC, OCRC, and SDRC.... all of which are small-medium sized indoor clay. Im thining a 14t pinion to get a baseline? Please advise.
Thanks!
Fleshgearf150 is offline
Old 11-24-2011, 06:09 PM
  #24784
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Thanks!
1. I use Robinson Racing Pinons, they are hardened, Very little wear.
2. Never raced at any of those tracks Sadly, no input there sorry.
Feint Motion is offline
Old 11-24-2011, 06:12 PM
  #24785
no worries. thanks for the input. so the Robinson pinions are pretty "short" and fit on the 3800 just right? Im assuming youre using the 3800?
Old 11-24-2011, 06:42 PM
  #24786
Yes, Mine fit with no issues on that motor. A sleeve will be needed though.
Old 11-24-2011, 06:46 PM
  #24787
13-15t pinions usually provide a good baseline.
cm.stites is offline
Old 11-24-2011, 07:24 PM
  #24788
K, I think I have a sleeve. Now I know OFNA makes 3mm Mod 1 pinions that obviously dont require a sleeve. Do you happen to know if they fit?
Old 11-24-2011, 07:45 PM
  #24789
Dan
Dan's Avatar
Trader Rating: 68 (100%+)
Yes, they fit fine. I'm running one with a 3800kv Castle motor too.
Dan is offline
Old 11-24-2011, 07:55 PM
  #24790
Panda-PR's Avatar
I know people say buy tekin or buy twice or something like that lol
But i bought a mamba 3800kv for a good price but I really want a motor with more power. I run on a large outdoor 8th scale track and its normally over 90 almost all year, which motor do you suggest? Tekin pro4 4000 or 4600? Other?
I also read about the tenshock sc411 coming out but I think there will be no support if something goes wrong. Planning on using it with MMP. Please advice!
Panda-PR is offline
Old 11-24-2011, 08:02 PM
  #24791
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
I would say the Tekin Pro4 4600.
I have the 4000 and its a BEAST!
But on a large track the 4600 should be good!
thecman26 is offline
Old 11-24-2011, 08:14 PM
  #24792
rcguy76559's Avatar
Trader Rating: 22 (100%+)
tenshock sc411 is not roar approved unless they change some rules in 2012. i would run rx8 pro 4 4600. if roar don't matter then get then tenshock 5200kv
rcguy76559 is offline
Old 11-24-2011, 08:18 PM
  #24793
larlev's Avatar
Viper is another good choice. They should be out Dec.
I have been running the R45/MMP and is a beast. Check into their Copperhead system.....$150 makes it a steal
larlev is offline
Old 11-24-2011, 08:31 PM
  #24794
rcguy76559's Avatar
oh yeah i for got +1 and they got a 5150kv
Old 11-24-2011, 09:19 PM
  #24795
For the 3800, 16t works perfect at OCRC and WCRC. 14t feels slow.
Jedev is offline
