Like Tree9Likes
Old 11-23-2011, 09:03 AM
  #24721
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Does Losi make the rear Diff bearing parts the key into the gear box out of AL like they do with the 8th scales?
Bigedmond is offline
Old 11-23-2011, 09:20 AM
  #24722
Arigato's Avatar
The diff bearing carriers do key in to the gear box and they appear to be plastic.
Arigato is offline
Old 11-23-2011, 09:27 AM
  #24723
Casper's Avatar
Trader Rating: 34 (100%+)
No they don't at this time nor do I think they have plans to do so.
Casper is offline
Old 11-23-2011, 09:42 AM
  #24724
namewasdallas's Avatar
Has anyone had issues with the motor mount screws I can tighten them down but then I cant slide the motor in the motor mount it gets hung up on the slider so I can never have the inside screw closeist to the center diff tightend all the way, or the front of the can on the motor is binding against the motor mount..
I've tryed leaving it loose then sliding the motor in and cranking it down then doing the outside screw but then I can mesh the the pinion and spur because it doesnt move. So currently have to have it as tight as I can get it slide it in mesh the spur and then crank down the outside screw. I haven't had a issue yet cause the top screw keeps the motor in place, but it has a little up and down play..
I was thinking of taking the center diff off the truck to try and figure a way to get that inside one cranked down but im not sure if there's a way. This happened with my Tekin pro 4 and castle 3800kv, It's almost like it was shaved a couple thousandths to much so it the front of the motor is binding on the aluminum motor mount.
namewasdallas is offline
Old 11-23-2011, 09:55 AM
  #24725
EricInNeenah's Avatar
Default Timing
Originally Posted by mo View Post
If you get too low on the gearing, it feels like you lose power overall. I needed a little bit more power to clear a long triple, that wasn't meant to be a triple , but I didn't want to gear up a tooth so I added a little timing instead and that did the trick. Sometimes you can use a little timing as a cheat to go up 1/2 a pinion size.
thanks for the input,I might try that . everyone else thats answered said theres no noticeable difference. Its getting cold up here so we can do things to motors that we normallly cant in the hot summer
EricInNeenah is offline
Old 11-23-2011, 10:23 AM
  #24726
cobraman's Avatar
Thumbs up
I mounted a Tekin Pro 4 4000kv with no problem, but when I mounted a 4600 I experienced the same issue you describe. I just placed two thin washers between the motor and the mount so I could tighten down on both screws. Doing so didn't cause any issues with gear mesh or alignment at the spur/pinion.
cobraman is offline
Old 11-23-2011, 11:11 AM
  #24727
R/C Tech Elite Member
JayL's Avatar
replacing my scews with a Tonys Screws kit:
the body mounts have issues: LOSA6236 is not listed in the manual , I know they are 2-56x1/2" button head but I cannot find them in the Tonys kit either
also
LOSA6256 the manual lists as 4-40x1/2" with they obviously are not, they are also 2-56x1/2, also not in my Tonys kit
are these sizes correct and did you get them in the tonys kit?
JayL is offline
Old 11-23-2011, 01:26 PM
  #24728
My SCTE should be here Friday and I hadn't really thought much about my wheels/tires.
Currently I have quite a few sets of SC wheels/tires that are mounted on Slash Front offset wheels due to me previously having a Jammin and Nexx10.
Running these on the SCTE will they make it wider or narrower?
Thanks in advance.
teknic is offline
Old 11-23-2011, 01:57 PM
  #24729
dtr
dtr's Avatar
Wider, you will have problems with body clearance.
dtr is offline
Old 11-23-2011, 02:01 PM
  #24730
Thanks for the trick I'll have to find some washers and see whats going to work.
Happy early thanksgiving,
we just got hit with snow so now more running my truck outdoors and our indoor dirt track is still having issues with getting permits from the city... I may have to run on carpet in the open class at this other shop which isnt fun cause there's like 2 tiny wooden jumps.
Old 11-23-2011, 03:46 PM
  #24731
Integra's Avatar
Originally Posted by MMor101 View Post
What length sensor wire are you guys running?
You can Run As low as 100mm if you choose. I prefer Super Soft Wires Vs the Stock Stiff jobby's you get with most motor's/ESC's.
While it may not seem like a problem, In reality it is. You have somewhat removed the Ability for the motor to dissipate heat into the Center diff mount and In turn To the Chassis. I would advise you get the proper length screw's and loose the washer's. Remove the Front bell and mount up the Slider and you'll be guaranteed to have the proper length screw's.
Integra is offline
Old 11-23-2011, 04:00 PM
  #24732
Originally Posted by Mototech View Post
Anyone having to go up in shock oil after converting to emulsion? With the same weight oil I had to go up one spring to get the ride height the same. Even then the collars were 3/4 of the way down. Checked for binding with the shocks off and there is none. Thanks.
Anyone?
Mototech is offline
Old 11-23-2011, 04:16 PM
  #24733
omenwolf's Avatar
Trader Rating: 37 (100%+)
Anyone?
That sounds about right, you probably had some rebound in your shocks before.
omenwolf is offline
Old 11-23-2011, 05:27 PM
  #24734
cobraman's Avatar
Thumbs up
[/QUOTE] While it may not seem like a problem, In reality it is. You have somewhat removed the Ability for the motor to dissipate heat into the Center diff mount and In turn To the Chassis. I would advise you get the proper length screw's and loose the washer's. Remove the Front bell and mount up the Slider and you'll be guaranteed to have the proper length screw's.[/QUOTE]
You may be correct about the heat dissipation, but it has nothing to do with the correct length of screws, but rather a slight tolerance variance that causes the motor/slide mount to bind with the fixed portion of the motor mount and not allow it to slide all the way in for proper gear mesh.
I have many packs through mine with the thin washers and have no heat issues, so for me it works.
cobraman is offline
Old 11-23-2011, 05:56 PM
  #24735
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Just spent 100$ replacing wear and tear parts on my truck. Feels good "refreshing Up" to make it feel new again
I have to say, the most worn out parts on my truck was the tie rod balls. They were so worn they fell out of the end rods by them selves lol.
Feint Motion is offline
