Like Tree9Likes
Old 11-22-2011, 12:37 PM
  #24676
mo
mo's Avatar
Originally Posted by hcollins
What pinions are most of you running on the Tekin 4600?
Really depends on the size of the track. On a small indoor track, approx 90ft straight, I run a 13 pinion with 10 degrees timing in the speedo. On the outdoor tracks with about 120 to 150 ft straight, I run 15 tooth with 0 timing in the speedo.
mo is offline
Old 11-22-2011, 01:24 PM
  #24677
myl3s91's Avatar
Default HELP PLEASE
Okay, so i just got my tekin 4pole 4600 kv, rx8, and new roller... I go to mount the motor, and notice their are 6 mounting holes, which two are larger. I would like to know the reasoning for this before mounting my motor. ALSO are their included mounting screws with the roller? If so the ones i tried screw in to a certain point then seem to bottom out, i was afraid to tighten anymore. note**These were mounted in 2 of the smaller holes out of 6. Any info would help as i cant wait to hit the track.
myl3s91 is offline
Old 11-22-2011, 01:37 PM
  #24678
DBL15's Avatar
you need shorter screws mate the holes are only so deep
just remember to lock tight those screws in so they dont come lose
DBL15 is offline
Old 11-22-2011, 01:39 PM
  #24679
myl3s91's Avatar
You would think losi would supply the proper mounting screws or at least 2 different sizes in a roller, as people will be picking different motors and esc's... Anyways has anyone else had this issue installing your tekin 4pole???
myl3s91 is offline
Old 11-22-2011, 01:41 PM
  #24680
Trader Rating: 18 (100%+)
I don't have the motor so I'm not 100% sure, but they probably have 3MM and 4MM mounting holes basically it's just more options and like the previous guy said the holes are only so deep so you need to make sure you get the proper length screw so you don't strip the holes out.
teknic is offline
Old 11-22-2011, 01:45 PM
  #24681
myl3s91's Avatar
Yes i now know why their are different sized holes. Now i want to know if anyone else has had this SAME issue with their losi and what screws/holes they used!?
myl3s91 is offline
Old 11-22-2011, 01:49 PM
  #24682
myl3s91's Avatar
I'm almost sure that the included 10mm screws included with the roller are too long and my solution is to get smaller screws. LOSA6267-6mm screws. If you have had this motor and roller with the same issue , hit me up so i dont go crazy thinking i have another 1 in a million problem!!
myl3s91 is offline
Old 11-22-2011, 02:03 PM
  #24683
DBL15's Avatar
i didn't use the mounting screws that were provided i used my own screws that i had spare from another kit
i think they need to be 8mm not 10mm in length if i remember correctly might be 10mm instead of 12mm something like that
DBL15 is offline
Old 11-22-2011, 02:18 PM
  #24684
myl3s91's Avatar
Thanks for the info, im going to bring my motor and mount in tomorrow and find something that will fit. Also did you use the big holes or small holes?
myl3s91 is offline
Old 11-22-2011, 02:24 PM
  #24685
Evilgies's Avatar
I,m looking for a setup for a race held on loose sand which is very bumpy with easy turns and small jumps.
Who can help me?
Evilgies is offline
Old 11-22-2011, 03:13 PM
  #24686
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
http://www.losi.com/ProdInfo/Files/L...uhe-Cactus.pdf
Or this one but with 5/3/2 diff oils
http://www.losi.com/ProdInfo/Files/L...atChampion.pdf
ChrisAttebery is offline
Old 11-22-2011, 03:46 PM
  #24687
Default Shocks
What shocks are racers upgrading on the 10 SCTE???
Losi23 is offline
Old 11-22-2011, 05:01 PM
  #24688
Trader Rating: 24 (100%+)
Has anyone tried the Jammin chassis for the SCTE??
jetcam2 is offline
Old 11-22-2011, 05:23 PM
  #24689
chucko's Avatar
I tried the big bore losi 8th shocks and it added weight.. the stock shocks with the spring sets will keep you light.
chucko is offline
Old 11-22-2011, 05:28 PM
  #24690
DBL15's Avatar
standard size hole with lock tight has not moved a bit very happy with the install
stock shocks are 100% fine just add the new springs to them black front and orange rear and your good to go IMO
no big bores required at all
DBL15 is offline
