Like Tree9Likes
Old 11-21-2011, 01:55 PM
  #24616
StPete40's Avatar
Trader Rating: 45 (100%+)
Originally Posted by ChrisAttebery
Hey Guys,
I'm looking for a clean SCTE for my son. If you're thinking of selling your truck please let me know.
Thanks,
Chris
Sent you a PM.
StPete40 is offline
Old 11-21-2011, 03:56 PM
  #24617
Trader Rating: 21 (100%+)
Default backspacing/offset has anyone actually measured it?
I'm looking for the SC wheels w/ the most offset (nitrohouse backspacing). I don't care what you call it I just need an accurate measurement. If someone could please confirm the 34mm nitrohouse lists I would very much appreciate it. I just bought a set of protrac wheels that are listed at 35mm but when they showed up they are actually 32.5mm. If anyone knows of a wheel w/ even more backspacing/offset I would love to hear about it.
mulepic is offline
Old 11-21-2011, 04:16 PM
  #24618
Trader Rating: 23 (100%+)
The scte uses "0" offset wheels. Pretty much no offset. Ive never actually measured it exactly. Yhe new jc hazzard have a little more offset to put it out to maxx legal width. Unless u dont care about legal then try slash 4x4 offset wheels. It will be plenty wide then
nitro0619 is offline
Old 11-21-2011, 04:43 PM
  #24619
I really need the exact measurement. I see nitrohouse lists it as 34mm backspacing but I found out the hard way their measurements are not exactly accurate. So I was hoping someone could/did measure it.
mulepic is offline
Old 11-21-2011, 04:56 PM
  #24620
Talking New SCTE owner
Hey guys,been lurkin around a while and tryin to find my answers in this 1600+ page thread and am gettin sick/dizzy after reading a few dozen pages.
I so far have swapped the grease in the rear/center diff out for oil and need to do the front,i have it at 5k/5k/3k F/C/R and have added a carbon fiber tube down the center for rigidity,i have the tuning kit on its way.
Other than that and maybe a bce or snr graphite chassis what should i do to prep for a smaller indoor clay track?
I recently went to PRCR and just ran it stock besides the center/rear diff oil and i think i was over powered/geared with a pro4 4000kv/13t pinion.
i got spanked by another scte and durango,i also was running stock wheels/tires so i know i could have used some bar codes or wishbones or something.
was hoping to get some help with a quick set up tip/trick?
any help is greatly appreciated,thanks.
bra-tac is offline
Old 11-21-2011, 05:03 PM
  #24621
What length sensor wire are you guys running?
MMor101 is offline
Old 11-21-2011, 05:15 PM
  #24622
10sctrel0v3r's Avatar
im not sure of length but im running what tekin sent with their pro4 4600
10sctrel0v3r is offline
Old 11-21-2011, 05:20 PM
  #24623
elex300's Avatar
Trader Rating: 110 (100%+)
I run on indoor carpet. I have the BCE chassis,swapped out the stock diff pins for Chris pins,swapped stock tires for DE wheels with M3 Suburbs,5/5/3 in the diffs,and moved the battery to the back. I'm using Dakotah's set up from the ROAR Nationals and I think thats about it. The BCE chassis is amazing. I'm gonna switch to the M2 compound suburbs because the M3's wear out after 2 weeks. My SCTE hanldles like a dream. It makes me look like a better driver then I am.
elex300 is offline
Old 11-21-2011, 06:23 PM
  #24624
ChefDementia's Avatar
Trader Rating: 19 (100%+)
125mm, I could almost use a 100. That's with a rx8 and pro4 btw
ChefDementia is offline
Old 11-21-2011, 06:59 PM
  #24625
BmainStar's Avatar
Which tires are you running? I had a traction roll problem when I ran Enduros. Someone I race with suggested going to a rounded profile tire like the stock Eclipse or BowFighters. Since I swapped tires I have NOT traction rolled nearly as much.
Fixed it for you Chris!!
BmainStar is offline
Old 11-21-2011, 07:18 PM
  #24626
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Yes, my brain runs at 120 WPS but I can only type at 45.
ChrisAttebery is offline
Old 11-21-2011, 07:19 PM
  #24627
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
I put 3/4 inch limiters in my shocks to try and lower my ride height for carpet. But the rango is winning at the local track, any suggestions on springs for me i ordered them but they are on B/O I almost just wanna cut a loop or 2 off the stockers. Im using sc10 tires for carpet and still 3 wheeling and traction rolling, i have the schumacher sc tires but i want to eliminate my problems before i mount them up.
BDRMBULLY is offline
Old 11-21-2011, 08:07 PM
  #24628
dtr
dtr's Avatar
I cannot get an exact measurement, since the mounted tyres make it hard, but the Losi stock wheels are closer to 35mm then 34.
dtr is offline
Old 11-21-2011, 08:08 PM
  #24629
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
Okay so I have a set of the 1/8th scale big bores and I just bought a new set of stock shocks for the scte. I want to upgrade my shock towers, but if I do I want to get the right ones. Should I run the stock shocks or buy the taller carbon towers from snr and go with my big bores? My truck is not lightened at all seemed when I tried my stock shocks out before selling them they bottomed out too easy. Also I liked the feel of the big bores better. Anyone have any input on big bore vs stock shock I would really appreciate the help!! Im just an average club racer and need any help I can get in landing jumps, and getting consistent lap times.
SCTRacerX is offline
Old 11-21-2011, 08:14 PM
  #24630
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Anyone know the dimensions of the Vektor 4000 1410 motor? It comes in the new savage xs truck. I know the Flux line that HPI puts in their vehicles are made by castle, but is this the same motor as the 3800 but 4000kv?
KIK is offline
