Like Tree9Likes
Old 03-08-2011, 06:46 AM
  #2446
S/X Runner's Avatar
Trader Rating: 37 (100%+)
Originally Posted by SaladFork View Post
+ YouTube Video
Allow playback on phones please. Thanks Trey.
S/X Runner is offline
Old 03-08-2011, 07:02 AM
  #2447
ffpm46's Avatar
Trader Rating: 175 (99%+)
Originally Posted by hacker07 View Post
5 is a 1.15mm hole which the closest is a 56.
So the stock are # 3 pistons right?
If I drill stock pistons they r now # 5?
I dont have to add any additional holes?
Thank you!
ffpm46 is offline
Old 03-08-2011, 07:04 AM
  #2448
fordmike65's Avatar
Trader Rating: 28 (97%+)
Plays fine on my EVO
fordmike65 is offline
Old 03-08-2011, 07:34 AM
  #2449
DC#14's Avatar
I know I probably should know this but this is my first sct. How do the "number panels" I'll call them... where does the triangle shaped one go? I figured out the other one
DC#14 is offline
Old 03-08-2011, 07:37 AM
  #2450
If I could request one thing on this truck, I'd like to see a full build up manual like what shipped with the 8ight and 8ight-T made available. It makes speccing hardware and rebuilding the more complex assemblies that much easier.
AMorgan is offline
Old 03-08-2011, 07:39 AM
  #2451
xxfile's Avatar
I concur, even if its online @ losi's website.
xxfile is offline
Old 03-08-2011, 07:42 AM
  #2452
I put mine between the number panel and the truck body, to act as a spacer. Without it, it seems you could crush the body or the number panel and cause cracks at the screw holes.
RCJammer is offline
Old 03-08-2011, 08:07 AM
  #2453
Huntweiss's Avatar
Would 3s be to much for a 6.8-7lb truck?
Huntweiss is offline
Old 03-08-2011, 08:26 AM
  #2454
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
No it's not, it's in completely separate bag that just floats around in the box by itself. The bag is TINY. Look in the floor where you opened the box. When I opened my box, my wife said do you need this? She was holding the bag with the motor screws and the servo piece.
Weird mine was in the bag with the manuals.
Sorry. :\
heavyjeffd is offline
Old 03-08-2011, 08:27 AM
  #2455
heavyjeffd's Avatar
Originally Posted by shortcut View Post
I wish that was the case, I've looked until my face turn blue , guess I'll have to make do.
Thanks, Jeff
Sorry man, mine was in the bag, I guess it's different in different boxes.
Old 03-08-2011, 08:30 AM
  #2456
SaladFork's Avatar
Fixed... Had no idea that was an option.
SaladFork is offline
Old 03-08-2011, 08:32 AM
  #2457
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by dirtracer1 View Post
Thanks hacker......I haven't had a chance to play with the truck yet (too much work), but I was thinking 5/5/3 as a start. Our track is outside, clay, sometimes lose/dusty and usually grooves.
For low bite I would really go with 3 in the center.
Thank you!
No additional holes required. Losi sells the the piston pack so you can have all the tuning options. Better then drilling out your only set.
http://losi.com/Products/Features.aspx?ProdId=LOSB2909
The triangles are options in case you don't like the taller square ones is what I was told. Never tried to put them both on at the same time.
Casper is offline
  #2458
mine came in a lil seperate baggy.
spent 15 mins looking for the pinion gear till i looked at the manual and saw the pinion listed under the "required" category...
gotta go back to the LHS today and grab one so i can try this beast out.
you guys running the sidewinder SCT 1410, how do you like it on the SCTE? hows the temps? runtime?
thanks
Kotu100 is offline
Old 03-08-2011, 08:35 AM
  #2459
Thank you!
Correct, there are no more holes, they are all 4 hole pistons. Or you can just buy two of the piston packs and have all the pistons.
Those are just another option.
hacker07 is offline
Old 03-08-2011, 08:36 AM
  #2460
S/X Runner's Avatar
Thanks bro. I'll check it out now.
